oil gauge fluctuate
Discussion in '2nd Gen Tundras (2007-2013)' started by Muggs, Oct 8, 2015.
  1. Oct 8, 2015 at 7:59 PM
    Muggs
    Muggs [OP] New Member
    2013 Tundra TSS
    I recently had an oil change at a local Toyota dealership and to make a long story short they forgot to install the gasket to the filter. After several miles driving i had a huge oil leak which caused my engine to knock. The dealership had it towed in and said no damaged was done however they wanted to do another oil change after a 100 miles. When the change was done they found shavings in the oil but not the filter, it was taken back after another 100 mile and i was told no shavings was found in the oil or filter. Now my oil gauge fluctuates from a little less than half to 3/4 and the knocking sound is gone. Is it normal for my gauge to fluctuate? Should i be concerned with this? Will damage occur in the near future due to this problem?
  2. Oct 8, 2015 at 8:06 PM
  3. Oct 8, 2015 at 8:22 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  4. Oct 9, 2015 at 4:14 PM
    15whtrd
    15whtrd Mr. Blonde
    I'd be so pissed! I'm sure they took some life out of the motor with that one.
    tibadoe likes this.
  5. Oct 9, 2015 at 5:23 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    First off...the gasket is attached to the filter and it's not removable. Pretty sure they are full of shit and never snugged the filter. Losing all the oil in 100 miles is indicative of a massive fucking leak.
    Second of all, shavings in the metal like you are describing is not normal.
    Third, rod knock, even for a minute, is detrimental. There is no way to tell that the rods, sleeves, seals, etc are fine without tearing down and inspecting. Just because there is no new shavings with your new oil change doesn't mean jack shit.
    Fourth, oil pressure fluctuation is normal as has already been pointed out.
    Your dealer to your engine has effectively been the equivalent of a mother snorting massive amounts of meth while pregnant.
  6. Oct 9, 2015 at 6:04 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Pretty sure he's talking about the o ring type gasket that goes around the plastic filter housing. When you buy a new filter it comes with two new gaskets. One for the OD of the filter housing and a smaller one for the drain plug on the housing.
  7. Oct 9, 2015 at 6:32 PM
    jberry813
    Lake Tahoe
    How a dealer fucked that up is beyond me.
    No wait...dealer. Makes perfect sense. :cookiemonster:
    ST3VE and mdavis like this.
  8. Oct 9, 2015 at 7:36 PM
    mdavis
    Michael
    Rock Hill, SC
    Exactly why I'm not taking Toyota up on their free maintenance. I'll do it myself and know it's done right. Wish I had some one like @LOTSOFTOYS to work on my truck when I took it to the dealer. Seems he really enjoys working on tundras.
  9. Oct 9, 2015 at 8:17 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    You don't have to be afraid of the dealer? In all reality the best technicians to work on Toyotas are at the dealer. Who else works on more Toyotas and knows them better?
  10. Oct 9, 2015 at 8:31 PM
    jberry813
    Lake Tahoe
    Me. :D
    LOTSOFTOYS[QUOTED] likes this.
  11. Oct 9, 2015 at 8:35 PM
    :jellydance:
  12. Oct 10, 2015 at 5:56 AM
    mdavis
    Michael
    Rock Hill, SC
    I completely understand and any major work I can't do myself, it will go to the dealer. I just know usually the ones doing oil changes are the younger guys that are forgetful or don't really care about someone else's vehicle.
  13. Oct 10, 2015 at 5:56 AM
    mdavis
    Michael
    Rock Hill, SC
    Yep, pretty jelly.
    T-Rex266[QUOTED] likes this.
  14. Oct 10, 2015 at 8:06 AM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    Just another reason I do my own oil changes. I hope they gave you a free 8yr/125k warranty for that screw up.
