Oil filter
Discussion in '2nd Gen Tundras (2007-2013)' started by Optic15, Nov 16, 2023.
  1. Nov 16, 2023 at 10:10 PM
    Optic15
    Optic15 [OP] New Member
    SF Bay Area
    2011 White Tundra SR5
    Level kit Morimoto XB headlights & fog lights LED light bar behind bumper KMC XD wheels 18” 34” Cooper Discoverer tires Pioneer double din head unit 10” subwoofer - x2 Back up camera trunk latch
    Just curious to know, for any of you that change your own oil. Do you change your filter every change or every other? I changed mine out last oil change about 5k ago. I use mobile 1, which claims to have a filter life of 10k miles. Usually I do both oil and filter every time but it’s cold and rainy now, and I’m feeling a bit lazy to drop the skid plate for access.
  2. Nov 16, 2023 at 10:43 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Ricos, shawn474, Optic15[OP] and 2 others like this.
  3. Nov 16, 2023 at 11:21 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    :rofl:My line for that is “That’s like taking a shower and putting the same skid-marked ginch back on afterward.” Strangely similar.
    OHwendTrd[QUOTED] likes this.
  4. Nov 17, 2023 at 2:46 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    If you were going to change anything more often, it would be the filter. The opposite. Change the filter every 5k, oil every 10k, for example.
    However, I would change both every 5k.
    If you're having your oil tested and they say it's still good out to 10k, maybe squeeze it out to 7500 safely, if more frequent changes are inconvenient.
    You're a new member and this is a new thread, so you may not be aware of what this thread is inevitably going to become. Before that happens, I just want to say that a lot of people have their oil tested and the results suggest their oil will easily continue to perform well out to 10k. But this is about filters and I would never feel good about running a filter for 10k. I don't care if it cost $200 and has racecars on the box.
    So, just do 5k changes, both oil and filters and recycle your used oil.
    :thumbsup:
  5. Nov 17, 2023 at 5:03 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    I've heard of skipping filter replacements on train engines (many years ago) but never passenger vehicles. For $4-5 I'll go ahead and change the filter every time.
  6. Nov 17, 2023 at 5:04 AM
    Change the oil and filter every 5,000 miles.
    bfunke and vtl like this.
  7. Nov 17, 2023 at 5:28 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It is time for seasonal fluid change: beer to brandy/port. I tend to run heavier mechanic fluids November to April.
  8. Nov 17, 2023 at 6:05 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    I don’t see any issue at all with changing just oil at 5k
    10k oci is fine - so just doing oil at 5k is even better
    I got 300k on my
    Tundra and it saw 10-11k oil changes its entire life
  9. Nov 17, 2023 at 6:26 AM
    Talon2006
    Talon2006 New Member Vendor
    https://talonsgarage.com/products/toyota-tundra-engine-skid-plate-2007-2021
    Or if you want another choice you can go with ours, for $225 with our black Fridays sale for 10 gauge powder coated steel, and our 1/4" aluminum option is $305.99.
    • We provide better coverage.
    • It is a two piece design for more strength and to make it easier to install, or remove if you need to get in there for maintenance.
    • Still has access hole to drain the oil, and a filter access door.
    We also strongly recommend a Fumoto valves to make the oil change easier. The one I like best is the version with the nipple on it that you can attached a hose too. It is the only way I have been able to do a mess free oil change. This is a example on a 4 runner i found on the internet, but the concept is the same.
    As far as changing the filter ever oil change, I do on any truck I own.
  10. Nov 17, 2023 at 7:27 AM
    Fumoto F133N long nipple with the RCI skid.
    Talon2006[QUOTED] likes this.
  11. Nov 17, 2023 at 9:39 AM
    Optic15
    SF Bay Area
    Appreciate the input y’all guess I’ll get over my laziness and just replace the filter as always lol
  12. Nov 17, 2023 at 9:53 AM
    Your engine will thank you for it. :D
  13. Nov 17, 2023 at 10:22 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    No problem for me. I just turn my underwear inside out.
    thedoodab1des, OHwendTrd and Ricos like this.
