Oil filter
Discussion in '2.5 Gen Tundras (2014-2021)' started by High Sierra, Apr 23, 2022.
  1. Apr 23, 2022 at 8:09 PM
    High Sierra
    High Sierra [OP] New Member
    2015 SR Tundra double cab
    Bed topper
    I just changed my oil today , as I was done I realized I didn’t remember seeing the small cylindrical metal strainer attached the cap as I installed the new filter . I found it in the old filter later . Does anyone know if not having that part is a problem ?
  2. Apr 23, 2022 at 8:14 PM
    BMET
    BMET New Member
    2018 Tundra Limited
    I would correct it. That piece might keep the filter from collapsing.
    Just me.
  3. Apr 23, 2022 at 8:15 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    In short, yes. Not having it in there could cause the filter to collapse on itself.
    WILLINH likes this.
  4. Apr 23, 2022 at 8:16 PM
    X2
    WILLINH likes this.
  5. Apr 23, 2022 at 8:17 PM
    High Sierra
    Bed topper
    Great . Makes sense .
  6. Apr 23, 2022 at 8:19 PM
    High Sierra
    Bed topper
    Do you think I could just insert the piece into the filter . Don’t know what happened to the pieces that connect it to the cap .
  7. Apr 23, 2022 at 8:21 PM
    TILLY
    Massachusetts
    There's no tabs on the bottom of the tube?
  8. Apr 23, 2022 at 8:24 PM
    High Sierra
    Bed topper
    No . I put the aluminum Dorman on it after breaking the factory cap .
  9. Apr 23, 2022 at 8:29 PM
    TILLY
    Massachusetts
    The tube should have I believe 4 tabs on the bottom of the tube that slides into 4 slots on the bottom of the cap.
  10. Apr 23, 2022 at 8:43 PM
    High Sierra
    Bed topper
    It’s fixed . I pulled the cap off and the other pieces were still attached to the inside of the cap . The “strainer” slid right back on . We’re all good . Lost maybe 1/2 quart of oil
    BMET and HulkSmurf14 like this.
  11. Apr 23, 2022 at 8:50 PM
    TILLY
    Massachusetts
    I don't understand. What pieces were still attached? There should only be the tube, the cap, and a spring. :monocle: But maybe Dorman is different from stock. :notsure:
  12. Apr 23, 2022 at 9:21 PM
    High Sierra
    Bed topper
    The spring and cap that the tube attaches to were still in the main cap . The tube had just come off
    TILLY likes this.
  13. Apr 24, 2022 at 8:35 AM
    Mr Badwrench
    Mr Badwrench New Member
    Does anyone else have a problem seating the new filter all the way to the base of the center tube? Does it need to be all the way to the base, or does it just need to cover the holes in the tube? The higher end filters give me this problem (toyota, Mobil etc..)
  14. Apr 24, 2022 at 9:56 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    It should seat without any issue. Double check that inner perforated tube to make sure it is installed correctly.
