Oil Filter Housing Cap ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by zebian2, Mar 27, 2019.
  1. Mar 27, 2019 at 9:47 AM
    zebian2
    zebian2 [OP] New Member
    Jamy
    I’m looking to change my oil on this new to me Tundra
    I’m buying the proper wrench for the job.
    Now do I need the oil Filter Housing Cap at all?
    Thank you
  2. Mar 27, 2019 at 9:50 AM
    marlin39a
    marlin39a I’m a dumbass.
    I would replace the plastic one with a factory aluminum.
    Ajkkane and JoshuaA like this.
  3. Mar 27, 2019 at 9:54 AM
    zebian2
    Jamy
    I guess I need to look to see if mine already replaced.
    Is it easily spotted?
    Thank you
  4. Mar 27, 2019 at 10:03 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    yes shiny metal versus black plastic. I a m glad that I had a replacement the first time I did mine. the dealership put it on the with 120+ lbs of torque. I had a cheap cast filter wrench that broke. When one made of solid steel it took a 2' cheater bar and my neighbor holding my legs to get it off. Dealer offered to replace the plastic one I destroyed but I had not use for it.
  5. Mar 27, 2019 at 10:09 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Aluminum on left, plastic on right. The threaded end will be pointed upward, vertically mounted. Typically hidden by front skid plate which has to be removed.
  6. Mar 27, 2019 at 10:31 AM
    zebian2
    Jamy
    120 lb of torque?
    That’s insane.
    What’s the proper torque?
  7. Mar 27, 2019 at 11:07 AM
    AK 6.7PSD Replacement
    AK 6.7PSD Replacement New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    Is the factory aluminum (okay, don’t laugh but...) a dealer parts department item? I want to ditch the OEM skid and also replace the plastic part with the aluminum but didn’t see the aluminum oil filter cap on Amazon...
  8. Mar 27, 2019 at 11:28 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s from a Venza. You just have to switch over the perforated tube from your original to the new aluminum.
    TXRailRoadBandit73 likes this.
  9. Mar 27, 2019 at 11:35 AM
    Trooper2
    JR
    15whtrd likes this.
  10. Mar 27, 2019 at 11:41 AM
    marlin39a
    These are on eBay for about $18.00 with free shipping. You have to take the perforated filter holder from the plastic one, and swap it to the metal one. Also the drain cover has to be swapped over.
  11. Mar 27, 2019 at 11:41 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Oil filter housing: 18 ft-lb
    Oil filter housing drain plug: 9 ft-lb
    Oil pan drain plug: 30 ft-lb
  12. Mar 27, 2019 at 11:42 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  13. Mar 28, 2019 at 12:59 AM
    TTund16
    TTund16 New Member
    @JohnLakeman ,
    @JoshuaA ,
    For the filter, is the specified torque for the plastic since the OEM housing is plastic?
    Would it be different for the metal housing?
  14. Mar 28, 2019 at 3:20 AM
    JohnLakeman
    Plastic or aluminum, oil filter housing torque value only "needs" to be 18 ft-lb to keep it secure, not to develop the full strength of the housing material. Spin-on filters used by other OEM should only be hand-tight plus a quarter turn to compress the housing gasket and keep it secure. Now, with the educational system being what it is, a typical OEM torque specification for a spin-on filter is 18 ft-lb.
    Torque value of 18 ft-lb is typical for any OEM aluminum oil pan drain plug or oil filter housing. Example: C6 Corvette LS3 cast aluminum oil pan with steel drain plug, GM specified torque 18 ft-lbf. That's probably more than it needs to be, but how are they going to tell a guy in technical school to "just snug it up by hand with a 8" end wrench plus a quarter grunt"? Idiots are going to use an impact wrench anyway.
    Don't be misled by the torque value of 30 ft-lb on the oil drain plug. That is for a steel drain plug in a steel drain pan. That's probably also more than needed, but that's what mother Toyota specified.
    TTund16[QUOTED] and JoshuaA like this.
  15. Mar 28, 2019 at 6:37 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I’m using Toyota OEM filters and rings so I’m assuming the ring gasket should be the same compression.
  16. Mar 28, 2019 at 9:50 AM
    JohnLakeman
    If you have the housing o-ring properly positioned, the o-ring does not seal against a face inside the housing recess. The compression of the o-ring seal in this case is unaffected by the torque value. The o-ring seals on the BORE of the filter housing recess much like a hydraulic cylinder piston does.
    The housing has what appears to be a big sloppy loose o-ring groove, (and that's where) the o-ring should be positioned(, not on the step face at the end of the housing). Toyota filters have an illustration on the outside of the filter box showing exactly how to mount the o-ring, and a warning about getting it positioned incorrectly.
    Edit: Post corrected for future readers. Should not go by my memory.
    Ericsopa, TTund16 and JoshuaA[QUOTED] like this.
  17. Mar 28, 2019 at 10:21 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    do the metal ones not include the tube?
  18. Mar 28, 2019 at 10:23 AM
    marlin39a
    It does, but it is too short to support the Tundra filter element.
    TTund16 and 15whtrd like this.
  19. Mar 28, 2019 at 10:24 AM
    Trooper2
    JR
    Yes, but it will be too short for our filter. The tube from the plastic housing needs to be transferred to the Aluminium housing.
  20. Mar 28, 2019 at 10:29 AM
    15whtrd
    15whtrd Mr. Blonde
    ^^^ what they said
    Trooper2 likes this.
  21. Mar 28, 2019 at 10:38 AM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    When I did mine I lightly pushed it to a tilt and with a little more pressure in snapped out without any damage at all and reinstalled it the same way.
  22. Mar 28, 2019 at 11:20 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Thanks, never noticed, however I do have the O-ring on per the box illustration, I’m OCD like that.
  23. Mar 28, 2019 at 7:24 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Funny mine were the exact same length.
  24. Mar 29, 2019 at 1:43 AM
    TTund16
    TTund16 New Member
    So you didn't have to bend the little tips or flaps to get it out?
  25. Mar 29, 2019 at 5:11 AM
    Trooper2
    JR
    I had to bend the tabs with a screw driver just a bit to remove. Then rebend when in Al. housing.
    15whtrd likes this.
  26. Mar 29, 2019 at 6:22 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    When getting ready to transfer the tube/spine from the OEM plastic to the Toyota aluminum filter cap it's a good idea to a have full fresh can of brake cleaner to douche everything. Cuzzzzzzzzzzzz itz gonnaz beez uz oileez mezz.
  27. Mar 30, 2019 at 5:48 PM
    zebian2
    Jamy
    So what is the advantage of having the aluminum housing instead of the original Toyota plastic one?
  28. Mar 30, 2019 at 6:00 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Eliminating the risk of breaking the plastic one or the removal specialty tool. Especially when you have oil service done at the dealership and they put the cap back on with a locomotive air gun and 300 pounds of air.
    Aluminum = strong
    Plastic = weak
    monaco730, Black Wolf and Trooper2 like this.
  29. Mar 30, 2019 at 7:54 PM
    Trooper2
    JR
    definitely stronger, never had issue with plastic on tundra or volvo that had plastic one. the AL. will be more durable gor sure. a few on here reporting breaking tabs on plastic one, probably over tightened.
  30. Mar 31, 2019 at 11:55 AM
    zebian2
    Jamy
    What is the part # for genuine Toyota oil filter housing wrench please?
    Thank you
