Oil filter housing cap TIGHT
Discussion in '2.5 Gen Tundras (2014-2021)' started by DCLarston13, May 16, 2022.
  1. May 16, 2022 at 2:28 PM
    DCLarston13
    DCLarston13 [OP] New Member
    2020 Tundra Magnetic Gray TSS
    So like many others here I got free oil changes with my truck, and I took advantage of them. But in the past 40 years I have always done my own oil changes as I started my career at Sears Auto center in 1981. I know how FUBARed some shops can make your car. But it a Toyota at a dealer so I thought it should be ok. Fast forward to today and start to do my own oil change on the Tundra. I own 6 cars and do all my own work, so I am no stranger to oil changes. My home shop is pretty well equipped as well. I go to remove the oil filter using a tool I got at Autozone (yes I know but they had it on the shelf) well it broke, then the strap wrench wouldn't move it, nor would my oil filter pliers. So I filled the engine with 8 qts for now. Not the best plan but I have to have the car ready tomorrow.
    Heres what gets me, the front skid plate bolts looked like they have never been removed, and they were tight, this combined with the tight filter housing makes me wonder if they were even doing filter changes at the dealership.
    Anyway I ordered the Lisle 61040 tool today I may try it as soon as I get it and if it works I should only loose about a quart of oil.
    Is there a metal replacement for that plastic housing?
  2. May 16, 2022 at 2:40 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Yea, there is a metal replacement. Search on Amazon for aluminum tundra filter housing.
  3. May 16, 2022 at 2:49 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I just dealt with this situation the other day. F:censored:ing grease monkey dealer techs need to put away the impact wrench.
    Luckily my secret Santa on here had already gotten me the metal housing so I was ready to go after destroying the plastic one.
    WILLINH, Ely010606, AZTundra and 3 others like this.
  4. May 16, 2022 at 2:54 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Yup same. Needed a long breaker bar and cracked the housing removing it after dealers “free” oil change. Replaced it with metal housing and torque to specs. Have to exchange the short inner support one the metal housing for the longer one in our trucks. BL - our forum members routinely note no one will take care of your truck like you will.
  5. May 16, 2022 at 2:55 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Here's the metal replacement part # 15620-31060. Don't forget to swap out the inner tube from the original canister. Good luck.
    ATV25, WILLINH, panicman and 2 others like this.
  6. May 16, 2022 at 3:05 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Damn Jake! Luckily I had changed mine early on, dealership NEVER changed the filter after about 4 changes. It was on real tight.
    TRDFerguson[QUOTED] likes this.
  7. May 16, 2022 at 3:34 PM
    AZBoatHauler
    So.Arizona
    Getting oil on the new garage floor?!? :eek2:
    If you only had some cardboard boxes laying around…
  8. May 16, 2022 at 3:41 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If only... I thought I was going to get away without spilling any oil since I already had the Fumoto installed and had the filter housing drain tool. Then by the time I was done cursing out Big Two Toyota's service center, I had forgotten to put anything down for the drippings. It all cleaned up pretty well though.
  9. May 16, 2022 at 4:07 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Stuff like this forced me to start doing my own oil changes. Too much risk of some random idiot ruining engine by forgetting to tighten oil filter or pan bolt.
  10. May 16, 2022 at 4:19 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I was going to let Toyota do the free oil changes. I am thankful guys posted their experiences so I didn’t have to go through that.
  11. May 16, 2022 at 5:42 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I went through the same thing. I knew the dealer was changing the filter because one skid plate bolt was missing and one was not original. Fortunately I had a metal filter cap ready to go. I broke one filter wrench. It was a cheap cast one. I bought a better one. One thing I learned is don't insert your extension on the inside of the filter cap nut. Use a socket on the nut. I had to use a 2' cheater bar and have my neighbor hold my legs. I gave the dealer 0s on the survey and service manager called me. He gave me 2 new skid plate bolts and offered to install them. I said no thanks you all will never touch my truck again. He also offered to replace the filter cap.
  12. May 16, 2022 at 6:26 PM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    I do all my own. Dealer hasn’t touched mine except for the fuel pump recall.
  13. May 17, 2022 at 11:48 AM
    Rocko9999
    Rocko9999 New Member
    My drain plug on the housing is stuck-any ideas how to loosen it?
  14. May 17, 2022 at 11:55 AM
    Taco-Spike
    Two Trucks
    tap it several times with a hammer / wrench and see if that helps. If not, keep fighting the good fight. Wear gloves, I've torn a hole in my hand before trying to get one off.
  15. May 17, 2022 at 11:58 AM
    Rocko9999
    I gave up and just removed the entire housing. It's like the last person who changed it JB welded it to the housing. No good way to grip that thing without risk of cracking the housing.
    Buckaroo and Taco-Spike[QUOTED] like this.
  16. May 17, 2022 at 2:24 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I don't use that small drain plug on the oil filter housing. I just remove the housing with a drain pan in place. Works fine.
    Rocko9999[QUOTED] likes this.
  17. May 17, 2022 at 3:27 PM
    Old.Ski.Bum
    Old.Ski.Bum New Member
    Paul
    2021 Luna Rock TRD PRO
    I’m reluctant to have the dealer do oil changes too. I’ve passed on the 2 free changes. I’ve had them rotate tires, but that is all.
  18. May 17, 2022 at 4:16 PM
    Rocko9999
    It seemed fine to me as well. Wasn't any messier than normal filter IMO.
  19. May 17, 2022 at 5:11 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    The dealer I used can't get those right either. One day after a rotation my TPMS light came on. Door sticker states 46 lbs because I have BFGs. All tires had 30. I was not happy that I had to get the compressor out.
  20. May 17, 2022 at 6:35 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    If you get the aluminum filter housing, I'd suggest just taking the part number to the dealership and know you're getting the real deal. Lot of fake/replica stuff on Amazon.
  21. May 17, 2022 at 6:55 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    Because of past experience I always use a torque wrench when tightening the filter housing drain plug and the filter housing itself.
    WILLINH and WBW like this.
  22. May 17, 2022 at 8:37 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    The key is to ensure the seller is a Toyota dealer. There are several on Amazon that are bona fide dealers, like Toyota of Miami, Conicelli, etc.
  23. May 17, 2022 at 8:47 PM
    TILLY
    Massachusetts
    I've seen fake Toyota filters before, but never seen a fake Toyota Aluminum canister. Can anyone here verify they bought one?
  24. May 18, 2022 at 8:33 AM
    Rocko9999
    Any benefit to the aluminum housing?
  25. May 18, 2022 at 9:37 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    I haven't bought a fake, but there are off brand (aftermarket) ones that are often labeled to make them seem like OEM. I'm not aware of anyone finding a fake that is trying to pass as genuine (ie in a Toyota box)
    Its less brittle and stronger than the plastic housing, so you stand a better chance of getting it off if over tightened. Additionally the plastic one see to gets stuck more easily, likely due to heat cycles. In a nut shell, it just reduces the chance of problems.
  26. May 18, 2022 at 12:31 PM
    kevine0001
    kevine0001 New Member
    Kevin
    Same experience here when I did the first oil change on CPO RAV4 that we got for my daughter. One of the plastic tabs broke on the housing so ordered aluminum one for it and changed it with next oil change.
    I still have one free toyota oil change, scheduled for 5/28/22 and I have the metal housing. So in a few months when I do the first one myself, I'll be replacing it with the alum one. If the plastic OEM one is still useable, I'll save it as a spare. Interesting though that your skid plate bolts were that tight. I wonder how many times filters are NOT changed....
  27. May 18, 2022 at 5:20 PM
    PA452
    PA452 New Member
    I haven't heard of someone getting a fake filter housing in particular, but I've seen and heard of lots of cases of people getting fake/non-genuine products of other types from Amazon. My take for something like this, why take the chance when you can just know you're getting the real deal from the dealership, plus you get a record then that you bought a genuine part.
    I saw someone post here at some point that they bought from Amazon then took that part to the dealer for them to verify it was genuine. So what was saved by buying from Amazon?
    TILLY likes this.
  28. May 18, 2022 at 5:28 PM
    PA452
    PA452 New Member
    Off topic but funny story about fakes on Amazon... On another forum I follow, earlier this year a guy posted that he had bought a Kershaw knife from Amazon, put it away and didn't use it for some time. Eventually he pulled it out to use it or start carrying it or something, and one of the side scales fell off. So he called Kershaw, they said send it in and they'd fix it. He sends it to Kershaw, they get back in touch with him and let him know it wasn't a genuine Kershaw knife, it was a fake probably made in China.
    So Kershaw told him the indicators, what to look for to spot those fakes. A bunch of guys following the thread then checked their Kershaw knives they bought from Amazon and discovered theirs were fakes too.
