Oil Filter Housing Can't Screw Off!
Discussion in 'New Member Introductions' started by tundratrent, Nov 7, 2023.
  1. Nov 7, 2023 at 5:46 PM
    tundratrent
    tundratrent [OP] New Member
    Trent
    2010 Toyota Tundra SR5
    BDS Suspension 4.5" Lift Kit
    So I have a 2010 Toyota Tundra SR5 that I'm changing the oil on. What I thought was going to be a simple thing but the oil filter housing as seen in the pics below is screwed on sooo extremely tight that even my custom wrench has broken the tabs on the housing! So now I need to find a tool or solution that will have the power to grip around the oil filter housing giving me enough leverage to twist it off. I've tried every tool and all the muscle I have along with my two other friends trying but still didn't budge. It's like the previous owner who sold me this truck welded the stinking filter on, crazy! I even tried my hammer drill, didn't work.
    Any of you experienced Tundra pros have an ideas? I bought a new oil filter housing so I don't care about cracking/breaking the housing that's on there. Thank you!
    Close up image of my filter housing:
    https://photos.app.goo.gl/7zhXiwfn5kNxmbpQA
    And the image of the housing wrench (whatever you call it) to try to unscrew it but not working:
    https://photos.app.goo.gl/iAojgY48LFwEhvDt5
  2. Nov 7, 2023 at 6:00 PM
    Burdturger
    Burdturger New Member
    Try an oil filter strap wrench
    tundratrent[OP] likes this.
  3. Nov 7, 2023 at 6:06 PM
    tundratrent
    Trent
    You have a recommendation of an oil filter strap wrench with a long handle to provide enough room to twist it off?
  4. Nov 7, 2023 at 6:14 PM
    tundratrent
    Trent
    Thinking of trying this "boeray 15 Inch Heavy-Duty Ratcheting Chain Wrench Reversible Oil Filter Tool Pipe Fittings Tools Fit Max 8 Inch Diameter"
    https://amzn.to/40qomqx
    Just hope the chain metal doesn't bend after putting so much force on it. Anyone try this?
  5. Nov 7, 2023 at 6:27 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Chain wrench should work. May have to slip a pipe over the handle adding leverage. Your filter wrench is junk. Throw it away and buy the Motiv wrench. You’ll also need to get a new filter housing. Just make sure it has the longer pipe inside. These housing seal at the prong and only need to be snug. Unfortunately the grease monkeys at many dealers and quick change places use an impact to overtighten them
    FrenchToasty and tundratrent[OP] like this.
  6. Nov 7, 2023 at 6:29 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    It sounds like the previous owner didn't change the oil at all.
  7. Nov 7, 2023 at 7:08 PM
    tundratrent
    Trent
    Yeah the previous owner was a dealership so crazy stuff! And that's a great idea to slip a pipe over the handle adding leverage, thank you! I bought a new filter housing already so we're good there. Just need to get the old one off. I'll try tomorrow and see if these ideas work!
  8. Nov 7, 2023 at 7:11 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I have giant channel locks that I use for dumb situations like this. Haven’t failed me yet.
  9. Nov 7, 2023 at 7:29 PM
    tundratrent
    Trent
    That's an excellent idea, giant channel locks, especially if I use the pipe trick over the handles for leverage since this filter housing is in a tough spot. It's right behind the BDS lift kit bar. I'll have to find a giant channel lock tool big enough, any suggestions? If not I'll hunt around.
  10. Nov 7, 2023 at 8:26 PM
    ZPhilip
    Philip
    West Chester, PA
    I think I have these
    https://www.amazon.com/Channellock-480-2-Inch-Capacity-20-Inch/dp/B00004SBCX
  11. Nov 7, 2023 at 8:30 PM
    Welcome from NY.
  12. Nov 7, 2023 at 9:17 PM
    texmln
    texmln New Member
    This happened to me with a Sequoia that I stupidly took the two years of free oil changes on. On the last oil change the dealer had to have used an impact gun as I couldn't remove the filter housing with a breaker bar or my own impact gun when i went to do my own first oil change. I took it back to the dealer and watched while FOUR techs used a four foot breaker bar to break it loose. They really had to work at it with two pulling, two pushing and just barely broke it loose after numerous attempts. It took forever since I first had to wait while every tech in the building came over to show the guys with the previous failed attempt "how it's done", only to not get it done. Needless to say, I had very little confidence in the plastic filter housing after that and replaced it with a metal one.
    bulldog93 likes this.
  13. Nov 8, 2023 at 8:47 AM
    Durobumps
    Durobumps Made in the U.S.A.
    Plastics Guy
    Tucson, Arizona
    Are we Active now?
    Use TRON10 for 10% Off and Free Shipping
    I had the same issue and ended up using channel locks. Make sure you got a good grip and take it slow.
  14. Nov 8, 2023 at 8:49 AM
    AZBoatHauler
    So.Arizona
    I’m terrified thinking how long it’s been since the filter was changed.
  15. Nov 8, 2023 at 8:59 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
  16. Nov 15, 2023 at 12:23 PM
    tundratrent
    Trent
    I'm happy to say I finally got off this crazy oil filter thanks to all of your help! It ended up being the Ratcheting Chain Wrench that did the trick to grip it tight enough with the breaker bar for leverage. Glad that's done phew!
    thearborbarber, bfunke and TILLY like this.
  17. Nov 15, 2023 at 5:36 PM
    bfunke
    South Carolina
    Thanks for posting the followup
