Oil filter/Front Skid/Front Cat Plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ghost Rider, Jul 21, 2023.
  1. Jul 21, 2023 at 11:32 AM
    Ghost Rider
    Ghost Rider [OP] Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I know this has many threads on it, especially on when/how/what oil to change/replace and all that.
    But, since I am getting under the truck for the first time (I had my Taco fiend change it for me last time due to I was overseas and it was due), he told me last time he had to drop both skid AND front plate to get to the oil filter, and also dropped the oil pan while he was at it.
    I have the Fomoto drain value that I am installing this time when I get the oil out. The question is: Do I have to drop both skid AND front plate in order to access the oil filter? I know the drain plug is accessible via the cutout on the plate (I have the Valhalla set), but can you technically get the oil filter out without making a mess on the plate? Or just remove the front skid and do it that way, quick and un-dirty?
  2. Jul 21, 2023 at 12:25 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    A comment not an answer as I don't have the Valhalla skid.
    I do my own oil changes and drop the stock skid plate. I want to be able to look up there and around and have just a general look around at the bottom of the engine, belt, etc. Every oil change is a nice interval to do that at.
    2mchfun likes this.
  3. Jul 21, 2023 at 12:44 PM
    Ghost Rider
    Ian
    Cypress, Texas
    Right, that would make sense, as a general eyeball would be better than not looking at all.
    Just not a fan of dropping 1/8 steel plates, not matter how many....lol
    Guess it is heavy equipment weekend then...
  4. Jul 21, 2023 at 1:52 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Cut a door in the plate
  5. Jul 24, 2023 at 5:59 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Mine actually came with that door (though, haven't figured out which size Allen wrench I need to open it with, but that's the easy part)
    So I guess the next question is, is there a way to "remove" the filter without dropping the plates and using the door/gateway?
    I know the filter remover adapter has a square at the bottom for torquing it open/shut, but with the plate being pretty far off, any tool/extender you guys use to make the job easier?
  6. Jul 24, 2023 at 6:14 AM
    All you need is the MotivX tool kit. You drain the filter with it and then remove it. You won't get more than a drop or 2. I have the RCI engine skid plate and the Fumoto and MotivX work very well.
    Wallygator likes this.
  7. Jul 24, 2023 at 6:22 AM
    Ghost Rider
    Ian
    Cypress, Texas
    You mean this guy?
  8. Jul 24, 2023 at 6:26 AM
  9. Jul 24, 2023 at 6:28 AM
    Abrown3912
    Abrown3912 New Member
    2021 Crewmax
  10. Jul 24, 2023 at 6:42 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Thanks guys. Guess Amazon will be delivering this afternoon so hopefully I can get it done after work today.
  11. Jul 27, 2023 at 1:56 PM
    Ghost Rider
    Ian
    Cypress, Texas
    Finally took care of it today ( I know.....)
    Couple of things for myself:
    1. Put the damn truck on something first, ramp, pump, anything. I had maybe 2 inch clearance to work with and on a decline on my driveway (stupid way to die, I know....) Super hard to leverage any kind of strength to turn wrench, which leads to...
    2. Tools. The above set is excellent, I have it and took a bit to figure out what to do with it (I though the funnel was to drain the filter part out....lol) Also, I got the Fomoto installed, so draining will be easier and less messy. Get the wrench extender for the filter part. Don't over tighten, hand-tight and 1/8 turn more.
    3. Towels. You never know, I walked away to grab a tool, failing to realize the oil was draining faster than I thought, so it dripped onto the skid plate and cat plate, causing all sort of mess on the ground.
    4. Visual check on everything while the hood is up. Still need to change out the air/engine filters, but that's the easy part....
    Damn, I will be sore tomorrow....
    g6t9ed likes this.
  12. Jul 29, 2023 at 7:07 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    I bought my kit last week and it arrived yesterday, have about 100 more miles until I hit 30000 and my next self service
    Ghost Rider[OP] likes this.
  13. Jul 29, 2023 at 8:09 PM
    Ghost Rider
    Ian
    Cypress, Texas
    I would say hit it. 100 miles is close enough.
    I was actually over by close to 300 miles because short of proper tools and just time.
    Houston heat/sun ain't joking....
    roughfisher[QUOTED] likes this.
  14. Jul 30, 2023 at 6:55 AM
    roughfisher
    JP
    Northern Minnesota
    I know the 100 miles is insignificant, just have to find the time. With traveling for work every week it might take me until the end of the summer to get there. Plus I'll be swapping out the factory front skid for an RCI to match my tranny and cat guards so would like to do that at the same time while I have everything apart. Also have to install my 6112/5160 kit when I have the chance, I've got my work cut out for me LOL
  15. Jul 30, 2023 at 3:37 PM
    Ghost Rider
    Ian
    Cypress, Texas
    Yea, that's gonna take a while....
    My next change will also involve transmission flush, around 30K miles, so yea, gonna have to drop both skid and front plate, both 1/8 steel, so not looking forward to that.
    I talked to my Taco fiend, might hit his house since his driveway is longer and actually flatter, no need to kill myself over the slop and weight....
