Oil filter for Synthetic
Discussion in 'Performance and Tuning' started by wildduk, Mar 26, 2024.
  1. Mar 26, 2024 at 1:41 PM
    wildduk
    wildduk [OP] New Member
    Atlanta
    2006 DC 2WD
    I’m switching to 5w30 synthetic on my ‘06 DC. Was looking at rock auto to order a filter. Looks like there are filter specific to synthetic oils.
    Should I order one of those or doesn’t it matter?
    thx
  2. Mar 26, 2024 at 2:09 PM
    blenton
    blenton New Member
    Doesn’t matter. Any good filter will work fine with conventional or synthetic. Any garbage filter will be equally as poor at filtering conventional as synthetic. :)
    vtl, Chad D. and Xcumminsguy like this.
  3. Mar 26, 2024 at 5:07 PM
    Xcumminsguy
    Xcumminsguy New Member
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Yup, filters are not synthetic specific.
    Leo's first likes this.
  4. Mar 27, 2024 at 6:25 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Use Toyota filter - reasonable price at Walmart.
    WILLINH, Oey12, baraynavab and 2 others like this.
  5. Mar 27, 2024 at 6:30 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    You can get an OEM oil filter from Walmart or the dealer, the dealer will be slightly cheaper but only by $1 each. I usually just buy a case from the dealer
    WILLINH and Leo's first like this.
  6. Apr 19, 2024 at 10:11 AM
    wildduk
    Atlanta
    2006 DC 2WD
    What brand is OEM. Headed to walmart soon….
    thx
  7. Apr 19, 2024 at 11:26 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    WILLINH likes this.
  8. Apr 19, 2024 at 11:40 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Toyota
    WILLINH and Toyotoholic like this.
  9. Apr 19, 2024 at 12:00 PM
    Xcumminsguy
    I picked up a box of the oem’s for 40.00 for a case of 10 from my local dealer.
  10. Apr 19, 2024 at 1:04 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
  11. Apr 20, 2024 at 10:10 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Toyota OEM filter is da best. Buy it in bulk and keep on saving a buck or 2. or but it from Walmart almost the same cost.
  12. May 18, 2024 at 4:46 AM
    DMBfan
    DMBfan 2015 Tundra SR5 CrewMax
    What makes the OEM filter the best? AMSOIL makes the best oil and their filters are ranked in the top 5. If OEM is the best please let me know. Gonna do an oil change soon.
  13. May 18, 2024 at 4:52 AM
    Most of us simply use the OEM Yota filter. In my case now, a Nissan filter. As mentioned, grab a few at Wally World or hit up your Yota dealer. Best is relative.
    WILLINH likes this.
  14. May 18, 2024 at 4:55 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    In all honesty who ranked AMSOIL the best? For me personally it’s not about the best (which is very subjective to say the least) but what works reliably without fail…hence OEM parts. I learned my years ago to stick with OEM parts ALWAYS when it comes to Toyotas and Hondas. A few good mechanics I have had over the years have also given me the same advice.
    kirkb, Black Wolf and WILLINH like this.
  15. May 18, 2024 at 5:04 AM
    DMBfan
    I'm in the NEK. When temps fall to bone chilling temps, AMSOIL maintains it's viscosity. My mechanic only uses AMSOIL for this reason. He also said it doesn't leave as much gunk in the engine when he compares engine flushes against other oils.
    Since I want to do my own oil change (0-20) I have been looking at Liqui Molly, AMSOIL and M1. Looking for a great filter in the meantime.
  16. May 18, 2024 at 6:23 AM
    Orions Dad
    2007 Tundra 4.7L
    Amsoil doesn’t make oil filters they don’t even make their own oil there are only a few companies that process base oil ( shell, chevron and Mobil) that is sold to blending companies. Companies such as Amsoil will give their minimum requirements to the blending companies they have contracts with than is sent to Amsoil for distribution
    As long as you do oil changes when you should you will be good there is very little difference between brands
    Retired...finally likes this.
  17. May 18, 2024 at 7:33 AM
    DMBfan
    I know they purchase the Synthetic, the additives and blending are done by other companies and in-house as stated on the bottom of the bottle. It's still a top-notch synthetic. It's that "little difference" (blending and additives) that matter. If it means less internal wear/tear then I'd spend the extra amount. Their website lists an oil filter for my truck. It also lists a Wix filter. So, I would imagine that is the company whos making their filters. It's not "the same" filter though. I don't mind spending more on a fluid change knowing I was using a product that exceeds many testing standards. I'd rather use it than a $2 brand.
  18. May 18, 2024 at 9:51 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Not that oil has ever been discussed on this board, but I believe you will be hard pressed to find any examples of a Tundra (presumably 5.7) engine failure that was due to an oiling problem when oil and filter changes were performed at reasonable intervals.
    I, like many others in here and throughout the world, am using OEM filters that I ordered on Amazon for ~$6 per filter and synthetic oil that I order through Costco for $16 per 5-quart jug when it’s on sale. I have 158,000 miles on my 2018 and it’s still sounding and performing perfect.
    I’m all for good fluids and filters, but these are pretty simple and dumb engines. You’re not looking at an F1 engine here…. Feed it good oil and use good filters. More importantly, do it regularly. 5,000 miles is the standard interval.
    You’re welcome to buy whatever oil and filters you’re comfortable with, but realize many of us will quietly sit back and shake our heads! lol. Just kidding you. Buy whatever you like. You’re not gonna hurt the truck.
    pursuit2550 likes this.
  19. May 18, 2024 at 7:50 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Show me an engine that failed because of the oil or oil filter used, so long as that engine was properly maintained, I will wait. Show me a test done on similar engines for lets say 500k with different oils and see which one had less wear, I will also wait for that report. Point is, you can use a $8 dollar oil or a $20 dollar oil on 2 identical engines and neither one will fail because of the oil used. This has been beat to death already, plenty to read on the subject, here and on the web.
  20. May 19, 2024 at 9:24 PM
    mass-hole
    mass-hole New Member
    Synthetic Filters usually have a synthetic media and are built to cope with the longer oil change intervals enabled by synthetic oil. They can hold more crap before they plug up basically.
    if you still intend to change the oil every 3000 or 5000 miles then it won’t matter. It’s more for when you plan on running a filter 15000-20000 miles.
  21. May 19, 2024 at 9:27 PM
    mass-hole
    No it’s not. Toyota filters are actually pretty poor at filtering in all the testing I have seen.
    Fram Ultra or Endurance as well Amsoil and Purolator Boss are the top filters.
    Saltyhero13 likes this.
  22. May 19, 2024 at 9:54 PM
    blenton
    blenton New Member
    Got any data? Links? Genuinely curious... I've seen a few random tests but all had some bias built in, or a weird test scenario that didn't really make sense in the real world.
  23. May 20, 2024 at 3:18 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Oey12 likes this.
  24. May 20, 2024 at 3:59 AM
    Really
    Oey12 likes this.
  25. May 20, 2024 at 5:40 AM
    Just watched a couple test vids. Not sure about the methodology, but the Toyota OEM filter did not do well at the dust filtration test. Flow rate was great though. Maybe a bad pressure relief valve setup? Can’t believe the filter media is that much worse. Would rather see the test back to back in real world usage to see the difference in filtration in a normal scenario and not on someone’s oil analysis frankenbenchtester.
    baraynavab likes this.
  26. May 20, 2024 at 6:18 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Dust? lol.
  27. May 20, 2024 at 6:30 AM
    Have to watch the video for the test methods. Engines ingest dust and debris through the air intake. First pass at filtering those out is a quality air filter. Whatever gets passed gets into the intake manifold and passes into the cylinders when intake valves open. Then after combustion they are either burned up, exhaled through the exhaust, or get into the oil via the cylinder walls getting squeegeed by the rings and swept into the crank case. In the test, they pour straight dust into the oil tester and let the filters do their thing. The Toyota filter did very poorly at this. Not a real world scenario, more a capability test for the filter medium. Except it’s not a controlled experiment and we don’t know if the bypass valve is opening on the Toyota (which has a unique bypass design compared to the others) during the test scenario. Also not sure the test scenario is anywhere close to typical operating conditions.
  28. May 20, 2024 at 6:38 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Lots of 300k-1 million mile Tundras running around out there, and I bet the majority of them are using the stock oil filter. That’s all I’ve ever used on any Toyota vehicle, the engines were designed for that filter. Are there better options? Maybe, but I just have to much stuff going on in life to be deep researching some things. Let us know what you find out!
    Oey12, bflooks and KNABORES like this.
  29. May 20, 2024 at 6:50 AM
    I run the oversized Mobil M1-301 filter on my FGT. Get an extra 0.5 qts of oil in it that way too. Change annually due to not driving many miles anymore.
  30. May 20, 2024 at 6:43 PM
    mass-hole
    But you had time to make this post.
