Oil & Filter Change
Discussion in 'General Tundra Discussion' started by UPDave, Aug 1, 2019.
  1. Aug 1, 2019 at 9:03 PM
    UPDave
    UPDave [OP] New Member
    PA soon to be Texas
    2019 Tundra SR 4X4 White
    Can I scream? Reading the owners manual learning about the new wheels. Noticeably absent was any information on changing the oil or filter. I had to look it up on line. Scream!
    My Tacoma, you popped the hood and the filter was right there in your face. No need to fuss under the engine, slip right under with no jack needed and pull the drain plug. Used to take all of 20 minutes.
    Had no idea the Tundras were using a canister system, that’s on the bottom, under a skid plate, that requires a special wrench. What a pain. Ugh!
    Rob's Inferno likes this.
  2. Aug 1, 2019 at 9:33 PM
    AZTundra
    Paul
    Phoenix, AZ
    Welcome from AZ.
    Medic343 likes this.
  3. Aug 2, 2019 at 6:03 PM
    swampy02
    swampy02 New Member
    2019 Tundra TRD Sport
    Welcome from PA! Wait til you see the plastic housing for the oil filter and then the cherry will be if you break a fin off that housing. It is a real treat.
  4. Aug 3, 2019 at 9:18 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Worst vehicle i have owned as far as ease of changing the oil and filter.Still love the truck
  5. Aug 3, 2019 at 9:25 AM
    15whtrd
    15whtrd Mr. Blonde
    I must be the minority. While it isn’t as easy as some vehicles I’ve owned. It isn’t difficult. I’ve got the proper tools like the filter wrench and a specific filter drain tool that works better than the plastic one that comes with the filters. ( I upgraded to the aluminum canister) It does kind of suck I had to buy a few extra tools but now that I have them it’s no big deal. I have the skid plate off in one minute and reinstall in about two minutes. Although it would be much easier with a standard filter.
  6. Aug 3, 2019 at 12:38 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Agreed. I don't even drain the filter housing. Spin it off like a standard spin on. Wipe er down, pop new filter in and spin it on.
    15whtrd[QUOTED] likes this.
