Oil Filter & Brake Pads
Discussion in '1st Gen Tundras (2000-2006)' started by 1kTyy_1, Jun 24, 2021.
  1. Jun 24, 2021 at 4:39 PM
    1kTyy_1
    1kTyy_1 [OP] New Member
    2001 Toyota Tundra SR5 V8 4.7L 2WD
    Going in road trip soon. Want to replace oil filter and brake pads, which brand do you recommend?
  2. Jun 24, 2021 at 4:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oil filter should be OEM. You can find at wally world for about $7.
    Pads will have to be recommended by others. I think @Lil Steve has recently done some brake work.
    1kTyy_1[OP] and Lil Steve like this.
  3. Jun 24, 2021 at 4:54 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    2nd on the Toyota filter.
    I've always had good luck with ceramic brakes. Centric, Wagner, Powerstop, or Raybestos are all decent choices.
    Lil Steve and Tundra2 like this.
  4. Jun 24, 2021 at 5:01 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I like my powerstop z23’s and fancy cryo rotors. no dust after 2k miles.
    Lil Steve, 1kTyy_1[OP] and Tundra2 like this.
  5. Jun 24, 2021 at 6:13 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    My front rotors were slightly warped so I went for the Power Stop Z36 package and replaced my OE 13WE calipers with their 13WL's. I wasn't initially impressed because the braking surface area of the WL pads isn't any larger than the WE's but after several months of driving with some towing I have no ragrets. Dont forget to properly adjust your rear brake shoes as well.
    https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-826#post-2048444
  6. Jun 24, 2021 at 6:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Jun 24, 2021 at 6:26 PM
    Lil Steve
    Gilbert, AZ
    1kTyy_1[OP] and Tundra2[QUOTED] like this.
  8. Jun 24, 2021 at 6:33 PM
    1kTyy_1
    Thank you for all of this helpful information. Cowboys winning super bowl
  9. Jun 24, 2021 at 7:06 PM
    We have a strict "No crack" policy here.
  10. Jun 24, 2021 at 7:43 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
  11. Jun 24, 2021 at 11:46 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Tundra2[QUOTED] likes this.
  12. Jun 25, 2021 at 12:59 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Lspv sends extra fluid to rear brake cylinders when you're carrying heavy loads.
    When you lift the truck the rear axle (where the LSPV arm mounts) is farther from the valve which means even less fluid is going to the rear cylinders than before. I think? Perhaps someone else can "fact check" me.
  13. Jun 25, 2021 at 8:20 AM
    1kTyy_1
  14. Jun 25, 2021 at 8:27 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    In order to celebrate my first purchase of mobil 1 oil, i bought a mobil 1 filter. So far its as good as fram…i mean, oil your seals, and clean machined surfaces. Get a good idea of where your oil leaks are, degrease and clean everything, then you can trace leaks easier. Definately worth it while the skidplate is off.
    206768305_10159202917735275_349023570827_5e28f77075341be22177cfedc3636794f65d4d3d.jpg
    on my titan, dad cut a window for oil changes in the skidplate, meant to add a door, never did. On the tundra, it looks like a window in the side of the skid plate might work. I dont like these little filters. Anyone know of a bigger replacement?
  15. Jun 25, 2021 at 8:55 AM
    Lil Steve
    Gilbert, AZ
    Sirfive[QUOTED] likes this.
  16. Jun 25, 2021 at 9:31 AM
    I have used the Mobil1 gargantu-filter for several years now. Holds an extra half quart of oil. Better cooling. No complaints. I usually use Pennzoil Full Synthetic Platinum or something. Used Mobil-1 last time cause they had a sale. 5qts for $14. Bought them out.
    bmf4069, tunyota and Sirfive like this.
  17. Jun 25, 2021 at 9:32 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Syn blend is a scam.
    FirstGenVol and tunyota like this.
  18. Jun 25, 2021 at 9:43 AM
    tunyota
    Yes, I have been using Mobil-1 and Bosch filters on our 3 vehicles for several years now. They are usually available at the local automotive stores so they are easy to find and acquire if you don't want to wait for the shipping. I haven't personally used these pads as the ones on the truck have plenty of life in them still but will upgrade to these when the time comes.
  19. Jun 25, 2021 at 9:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Couldn't agree more. I'd run conventional oil before I ran a blend again.
    tunyota and Sirfive[QUOTED] like this.
  20. Jun 25, 2021 at 9:45 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    50/50 antifreeze is also a scam.
  21. Jun 25, 2021 at 10:32 AM
    A decidedly convenient scam, I mean, who wants to mix their own antifreeze and water?
  22. Jun 25, 2021 at 10:35 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So you mean I can finally quit cutting that last quart in half? It's so messy...
    KNABORES[QUOTED] likes this.
  23. Jun 25, 2021 at 10:35 AM
    Yes!!
    bmf4069[QUOTED] likes this.
  24. Jun 25, 2021 at 10:47 AM
    KneeYa
    KneeYa New Member
  25. Jun 25, 2021 at 10:48 AM
  26. Jun 25, 2021 at 10:57 AM
    tunyota
    KneeYa likes this.
  27. Jun 25, 2021 at 11:01 AM
    KneeYa
    KneeYa New Member
  28. Jun 25, 2021 at 11:11 AM
  29. Jun 25, 2021 at 11:14 AM
    Professional Hand Model
    Hand Protectors
    False. Beats mixing Distilled Water and the Pure Shtuff any day. Price wise its a little more, but worth it.
  30. Jun 25, 2021 at 11:16 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Since moving to the desert i keep a jug of room temp distilled water handy at all times.
