Oil drain valve - Fumoto
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by soloshairtrigger, Nov 6, 2016.
  1. Nov 6, 2016 at 2:41 PM
    soloshairtrigger
    soloshairtrigger [OP] New Member
    G
    2019 Black TRD Pro
  2. Nov 6, 2016 at 2:50 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Search fumoto... bunch of threads on it
  3. Nov 6, 2016 at 2:53 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Stay away from those things. they leak and not worth your engine. I never understood these, is it really that hard to remove a drain plug every 5000 miles?
    soloshairtrigger[OP] likes this.
  4. Nov 6, 2016 at 2:56 PM
    I have used them for years, no issues.
  5. Nov 6, 2016 at 2:58 PM
    Do you change the oil on the Tundra?
  6. Nov 6, 2016 at 3:09 PM
    davesnothere
    davesnothere New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    Haven't installed mine yet as I got it after oil change, but love the fact that that you can hook a hose to it and it doesn't get all over your wheel and stuff. That stuff comes out some force.
  7. Nov 6, 2016 at 4:04 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    So what are the best after market ideas to facilitate an effective oil change?
    2014+
    I can't remember all of the stuff I've seen;
  8. Nov 6, 2016 at 4:07 PM
    Isn't that a damn fact!!!
    I have been using the same fumoto valve on several Toyota vehicles now. Not sure which one it will go on next, the Lexus or Tacoma.
    My diesel will get one too. I made that mistake once on my 05 cummins and had 2.5 gallons of black filthy oil all over my driveway. Never again. After my free oil changes are up, fumoto valve will be ordered.
  9. Nov 6, 2016 at 4:18 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have one. Works great. No leaks.
  10. Nov 6, 2016 at 4:28 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I love mine. I've had zero issues with it and the same goes for 3 years of oil changes on my FJ Cruiser when I had that. Below is how easy my oil changes are now..
  11. Nov 6, 2016 at 7:56 PM
    csuviper
    Broomfield, CO
  12. Nov 6, 2016 at 8:38 PM
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    I've used them and like them. I had one on my Honda insight as the oil pan was magnesium and a pain in the ass if overtorqued or stripped. I will eventually put one on the tundra. Never had a leak or a drip and I've used them on several cars and trucks. FuMoto and speed bleeders and life is good!
  13. Nov 7, 2016 at 2:58 AM
    Tundraplatinum
    2016 Platinum CM
    All the time. professional technician for 21 years. seen many of these leak or break off over the years.
  14. Nov 7, 2016 at 3:02 AM
    Tundraplatinum
    2016 Platinum CM
  15. Nov 7, 2016 at 4:41 AM
    davesnothere
    Dave
    Down South, Texas
    NewImprovedRon likes this.
  16. Nov 7, 2016 at 6:57 AM
    These are just ball valves. Will they leak over time? Sure. I don't know what that time limit is. My current one has a "few" oil changes on it without failure. A good guess with mileage on 3 different vehicles, my current fumoto valve has 58 oil changes on it.
    The breaking off, sure. I'll go with that. Do I have one of these fumoto valves on my Jeep? No, there is a pretty good chance a rock will catch it and rip it off. Most average Joe doesn't Offroad their 40k dollar truck really hard. Same thing goes for my new 60k truck.
    The fumoto valve is for the person that changes the oil themselves, plain and simple. I wouldn't put one on for a local shop tech. They have hard enough time not stripping out oil pans, swapping out the wrong oil or not refilling. I can't imagine an oil tech trying to figure out a ball valve drain plug.
    SoCalRandy, Hoff, Smoofers and 2 others like this.
  17. Nov 7, 2016 at 9:19 AM
    Quadruple dipped.
    Guess I am a multi-dipper
  18. Nov 7, 2016 at 4:45 PM
    Tundraplatinum
    2016 Platinum CM
    Look again bro.... that things amazing, it's made soft metal sheet coated in rubber you form it however you like and it stays where you put it. and who cuts up milk jugs anyways?
  19. Nov 7, 2016 at 4:53 PM
    Tundraplatinum
    2016 Platinum CM
    I was just informing people that these leak. do it yourselfer or not it's not worth paying $30 for a valve then blowing up your engine, you could blow it up for free. no need for a quick release oil drain, just sounds dangerous
    B737 likes this.
  20. Nov 7, 2016 at 6:47 PM
    To each their own I guess. Even if they did leak, a person that isn't a complete moron is going to see there is fluids leaking
    Personally, you're the first person I have ever heard complain about them. I'm on many sites that have discussed this very topic, and a Mod on a rather large diesel site.
  21. Nov 8, 2016 at 10:53 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have had one on my Tacoma since the free oil changes ended. The only thing negative I can say is it takes longer to drain the oil. The wait time is made up on the back side because I can drain straight in to an empty jug. I just cap the jug an done. Now I would be concerned on a vehicle where the valve was exposed. Fortunately on the Tacoma it is well protected by the skid plate.
