Oil changes
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Apr 15, 2018.
  1. Apr 15, 2018 at 3:42 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    I bought my Tundra used this spring with 55000 miles on it. How offen should I change the oil, use to be 3000 miles, but some say 3000-5000 but then I saw 10k 15k. I am using Mobil one. (And now the offer Mobil one Annual protection that might be pushing it a bit.) also if you change it at 10k miles seen something online that said may need to add oil over the 10kis that true (may doesn’t leak any)
  2. Apr 15, 2018 at 3:44 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    I do mine at around 5K. Easy to remember. :D
    GNTundra likes this.
  3. Apr 15, 2018 at 3:45 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I’m fairly certain it’s every 5k miles. However, if you’re using synthetic you could push 7k-10k. For me, I change mine every 5k just for peace of mind.
    Beep88 and nk1794 like this.
  4. Apr 15, 2018 at 3:46 PM
    Every 5k for me, Mobil 1 Full Sythetic 0W-20 , Toyota OEM filter
    71_340, Beep88 and nk1794 like this.
  5. Apr 15, 2018 at 3:47 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Adam, do you like MObil 1 better than Toyota synthetic? Why? Thanks.
  6. Apr 15, 2018 at 3:51 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I changed oil at 1200 miles as my 18 limited is new. I put in Mobil 1 advanced. I plan to change every 5 K or 1 year, as it’s not my only ride. The 2 year maintenance will do every 10K or year.
    I recycle my oil, so I have no problem with using fresh oil. The cost of oil is cheap compared to a new engine imo.
    040Tundra likes this.
  7. Apr 15, 2018 at 3:52 PM
    When I bought my Tundra used at a Honda dealership :spy:, I went straight to a Toyota dealership and they told me they put Mobil-1 in thers vehicles that come in for service, they said it good quality oil, a mechanic friend of mine uses it in all his vehicles swears by it,
  8. Apr 15, 2018 at 3:54 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I’m considering switching from Toyota branded synthetic to the Mobile 1 synthetic. Ive heard really good things about it.
    Also, Royal Purple. I have heard that’s the best stuff but I have no idea. You can’t always believe what you hear
  9. Apr 15, 2018 at 3:57 PM
    I've heard good things about RP too, also there was a thread on here about filters, some members were praising WIX filters
  10. Apr 15, 2018 at 3:58 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I’ll look into WIX, but I like the Toyota filters so far. Thanks for the info.
  11. Apr 15, 2018 at 3:58 PM
    nk1794
    San Jose, CA
  12. Apr 15, 2018 at 4:02 PM
    There is also Mobil-1, K&N, and the Trd PRO filters none of which I have used
    nk1794 and WAtundra4x4 like this.
  13. Apr 15, 2018 at 4:07 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Toyota specs a 10k Interval, I did my first change early at 5k and then started a 10k interval. I'm using Mobil 1 synthetic and a Toyota OEM filter in mine.
    nk1794 and 040Tundra like this.
  14. Apr 16, 2018 at 11:00 AM
    Stig
    Stig New Member
    Toyota/Lexus oil is rebranded Mobil (standard synthetic, not economy, high mileage, etc)
    landphil likes this.
  15. Apr 16, 2018 at 4:32 PM
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    Bought my new Tundra 2 weeks ago. I need to come in for my first service at 5k and then every 10k
  16. Apr 16, 2018 at 5:24 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Change oil every 5K (which is mandatory if you have FFE). Just have Toyota do it, it is about $70.00 and you get an OEM filter, 2 GL of Mobil 1, they check all your other fluids, rotate your tires and you don't have a mess......hard to beat. Oil changes are cheap and the most important thing you can do to prolong the lif of your engine.
  17. Apr 16, 2018 at 5:31 PM
    nk1794
    San Jose, CA
    Hope and pray that they dont over tighten your filter cap like several of us have experienced.
    boostedtrdpro likes this.
  18. Apr 16, 2018 at 5:51 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Do it yourself. The bone heads changing oil at the dealer suck..
  19. Apr 16, 2018 at 6:11 PM
    I agree do it yourself!
    Leo's first likes this.
  20. Apr 16, 2018 at 7:32 PM
    kcaustin66
    kevin
    I had spine surgery about 6 months ago, have not regain all my movement yet. C5 in my not neck has been removed, recovery will be about another year. After a 17 hour surgery anything is better. I can’t even loosen or tighten much yet . Too much for my neck. Or I would do it myself.
    I have fusion 3 levels in the front, and a full cage in the back over 6 levels. I can do a lot now but limited movement, and lift about 25 lbs. hoping I can start exercising my neck in about 6 months. Can’t wait to go back to work. (Funny thing is I have bought a lot of things for my Tundra, but keep forgetting I can’t install anything yet) by myself.
    WAtundra4x4, 15whtrd, gosolo and 2 others like this.
  21. Apr 16, 2018 at 7:49 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Wishing you a speedy recovery. Hoping you get stronger and your mobility back.
    15whtrd and Leo's first like this.
  22. Apr 16, 2018 at 7:53 PM
    kcaustin66
    kevin
    Thanks so far a lot better, was stuck in bed or a recliner for about 3 1/2 years, now no pain
  23. Apr 16, 2018 at 7:55 PM
    Trooper2
    JR
    You get a "pass" on doing your own oil changes............
  24. Apr 16, 2018 at 8:14 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m able to understand well what you have gone through. I had a vertebra removed and my back fused all the way down into my hips. Do what you can and stay as active as possible but let nobody push you past what you’re able to comfortably do. I installed my sliders alone but it took me 2 days. I expect my first oil change will take all day.
    WAtundra4x4 and 15whtrd like this.
  25. Apr 16, 2018 at 8:25 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    David
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Wow!
    And I thought my back was sore. That changes that.
    Good luck with recovery and continuous health for years to come.
    gosolo likes this.
  26. Apr 16, 2018 at 10:26 PM
    WAtundra4x4
    Den
    Wet side WA
    That’s some serious hardware guys. Best of healing to you all. I hit a horse one morning at 4:30am a couple of years ago, several got loose and ran out I front of me while doing 40 mph. Took a chunk out of one, totaled my motorcycle, BMW 12GS, but my gear saved my life, albeit 9 days in hospital with 4 broken ribs, self healed spleen, partial detached lung. I feel quite safe in my Tundra for sure.
    gosolo likes this.
