Oil change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ubc2361, May 7, 2016.
  1. May 7, 2016 at 5:37 AM
    Ubc2361
    Ubc2361 [OP] New Member
    Tony
    Los Angeles
    Tundra crewmax 5.7 4x4
    I'm having a problem with my dealer. They don't want to change my oil! I have the extended warranty. I've had it for 11 months 7,000 miles they say no oil change needed till 10,000 miles. I don't drive it much so it could be 20 months before I hit 10,000. Is this true or am I going to mess something up? Yes it's synthetic
  2. May 7, 2016 at 6:47 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yea def talk to someone higher up. I'm sure they can change the plan to date range instead of miles
  3. May 7, 2016 at 6:57 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Is your truck a flex fuel? Only flex fuel trucks get a "free" oil change every 5k miles. Non flex get one every 10k. You can tell by looking at your VIN. If the fifth letter is a W, you have a flex.
  4. May 7, 2016 at 7:47 AM
    This, but be sure to rotate tires every 5k regardless of do the oil change on ur own or pay them to do it, or have them reduce it to every 5k instead.
  5. May 7, 2016 at 7:49 AM
    15whtrd
    15whtrd Mr. Blonde
    I won't even take advantage of the free oil changes. I don't want them touching my truck if I can help it. I'm sure they'll strip one of the front skid plate screws or something. They might even be too lazy and not change the filter or change the oil at all. At least if I do it I know I'll get it right.
    NewImprovedRon and Red Freighter like this.
  6. May 7, 2016 at 8:57 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I'd look in the owners manual about the oil change intervals. I'd be pissed about the 10,000 mile mark. One of my last cars recommended 10,000 mile changes and I wasn't comfortable with that thick ass oil running through my turbos (I'd change in my garage at the halfway mark.) I also have a problem with my local service department, they tend to forget to putting the oil cap back on after service, the clean and wipe of the interior is shit and inconsistent, among other things I've had problems with.
  7. May 7, 2016 at 10:00 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Your extended warranty likely only covers oil changes at the manufacturer recommended intervals. If you want it more frequently than that, it will be on your dime. The end.
  8. May 7, 2016 at 10:47 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    I did my first oil change at 8500 and sent a sample to black stone labs. The testing came back as normal with some high points typical of a new engine. I won't be taking advantage of Toyota care with my truck I like to do my own maintenance.
    I will be doing my next change next week at 13000 just to get rid of the high points in the test then up to my standard 7500 miles I do with synthetic oil that I do with all my vehicles. I send every few oil changes to black stone just in make sure everything is still in check.
  9. May 7, 2016 at 11:43 AM
    Ubc2361
    Tony
    Los Angeles
    Damn so if I want it sooner I have to pay. That sucks.. yeah I'm not comfortable waiting till 10,000.
  10. May 7, 2016 at 11:46 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Just going off the results of my test 10,000 is totally fine on your truck with synthetic oil. I drive like an ass tow at least three times a month and they were all within normal at 8500 miles. If you can't wait you will have to pay.
  11. May 7, 2016 at 1:30 PM
    Ubc2361
    Tony
    Los Angeles
    I just wanted to be sure it's fine with the truck. I don't trust the dealer and you guys always steer me in the right direction.
  12. May 7, 2016 at 5:47 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    My Amsoil Synthetic@ 7500 miles is as clean as it was going in. It's not the oil that fails first, you could run 10k easy. It's the filter that breaks down. Just my 2 cents.
    Ubc2361[OP] and jlee like this.
  13. May 7, 2016 at 7:32 PM
    53flattie
    53flattie New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    I have a Flex Fuel and my dealer changes every 5K under the Toyota Care (first 5 are free).
  14. May 7, 2016 at 9:16 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Possibly this could be the sales preference? I have a non flex and I get the first 5 or 25k/2year free service.
  15. May 8, 2016 at 6:28 PM
    Ditto pretty much on all of the above. Wouldn't hurt going a rival Toyota Dealer just to see what they say.
    trayday likes this.
