Oil Change
Discussion in '2nd Gen Tundras (2007-2013)' started by KornCobb, Mar 22, 2016.
  1. Mar 22, 2016 at 10:17 AM
    KornCobb
    KornCobb [OP] New Member
    Joshua
    Just wondering what kind of oil & oil filters everybody else uses on their Tundra's. I am approaching my first oil change on my 2012 Tundra since buying it. This is the first truck I have owned to use such a light weight oil (0w-20). I also wanted to know others opinion on full synthetic oil also. i.e. how many miles would you put on a full synthetic oil? what brand? and would you even use full synthetic vs. the regular oil? Thanks!!!!!
  2. Mar 22, 2016 at 10:19 AM
    Mike Tread lightly.
    south carolina
    Toyota oil filter and Mobil 1 only.
    FirstGenTundra likes this.
  3. Mar 22, 2016 at 10:21 AM
    x2
  4. Mar 22, 2016 at 10:39 AM
    bigsapz
    bigsapz New Member
    Beast
    I use a fram filter and Castrol High Mileage 5w30 out here in SoCal. Been good for 150k miles. (158k now)
  5. Mar 22, 2016 at 10:59 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    I did my own oil change a month or two ago. It was a BIOTCH!! Make sure you have a good metric socket set with extensions ( to remove skid plate) and the oil filter shaped special service tool.
    A few other tips I learned.
    1. make sure you have a big oil catch pan, I had a 7 qt pan and had to put the bolt back in so it didn't overflow
    2. the little plastic tool to drain the filter housing will come with the new filter
    Edit: I used Mobil 1
  6. Mar 22, 2016 at 11:38 AM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    toyota filter with either mobil 1 or toyota oil. Sometimes the toyota oil is cheaper from the dealer than mobil.
    Sefferston likes this.
  7. Mar 22, 2016 at 12:41 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    X5 on Mobil 1 Full Synthetic and Toyota oil filter only
  8. Mar 22, 2016 at 3:47 PM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    Make it X6 for M1 and Toyota filter.
  9. Mar 22, 2016 at 5:53 PM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    are you guys using that 0w20 mobil eco synthetic? has a green cap. I haven't been able to find any just straight 0w20 synthetic.
  10. Mar 22, 2016 at 6:47 PM
    X3
  11. Mar 22, 2016 at 6:50 PM
    I'm not sure. How more eco can M-1 synthetic get?? I just went with M-1 but didn't pay too much attention about the cap. Now I'm curious as to what the diff is.
  12. Mar 22, 2016 at 6:55 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Just a new cap.. And x how ever many we are up too now! I use the trd filter tho. :cheers:
  13. Mar 22, 2016 at 7:05 PM
    I got a good deal on some factory filters off Craigs 'List. Probably came out to a little over $3 bucks a piece for 8. Never bought a TRD filter but no doubt better than the factory ones, which don't exactly suck.. I used K&N's on my Taco. WIX is supposed to be a decent filter too.
  14. Mar 22, 2016 at 7:09 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    What type, size of filter wrench do you need for the filter housing on a 2012 Tundra (non flex fuel) 5.7.
  15. Mar 22, 2016 at 7:12 PM
  16. Mar 23, 2016 at 8:55 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I use Toyota filter and Mobil1 0W-20, Extended Performance.
  17. Mar 23, 2016 at 9:59 AM
    Tundra212x
    Tundra212x New Member
    Rick
    2012 Tundra TRD
    I just purchased a 2012 Tundra CrewMax with 54k miles. The previous owner used extended filters and changed the oil every 10,000 miles. I'm looking for opinions/experience for help in determining if I should continue that frequency or do it more frequently.
  18. Mar 23, 2016 at 10:16 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I have always been a Mobile 1 filter and oil guy. I buy extended life because you get another 8k miles between changes for the same price. I dont know anything about Toyota filters. My truck is new so the dealer is paying for the next 2 years of service :)
    My question to you Toyota veterans is what is so good about the Toyota filter? I'm curious because if its better than Mobile 1 I will be willing to switch.
  19. Mar 23, 2016 at 10:24 AM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    I don't know if it is the same for toyota, but i started using factory filters back when I had my 6 liter powerstroke. Heard a ton of horror stories of filters degrading and being sucked into the engine and messing shit up. However, the motor-craft filters stood up and never had a problem. Plus the price isn't that big of a difference, so I just use factory filters. I'm sure somebody will chime in about filtering allowance too, how many microns it filters.
  20. Mar 23, 2016 at 1:56 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    I'm in the same boat as Joshua, coming up to my first oil change. The Baldwin oil filter was recommended to me (25 years ago) by a drag boat racer. They are the number one choice in the trucking industry. I used them in my Taco and 7.3 diesel. I believe these are not better than the TRD but better than the Toyota regular filter. I plan on using the Baldwin with M1 0w20 every 5 thousand miles. Part number P7406.
  21. Mar 23, 2016 at 2:29 PM
    bigsapz
    bigsapz New Member
    Beast
    Someone explain the difference between Toyota OEM and Fram oil filters because I am unable to find any. Thanks
  22. Mar 23, 2016 at 3:18 PM
    Red Freighter
    Oregon City
    All I can tell you that my son in law bought the cheapest Fran (canister type not a Tundra type) and it didn't have a one way valve in it. Meaning that each time the engine was turned off the oil would drain out of the engine. Making every start with no oil in the engine until it was pumped up from the pan. I believe that most people view the Fran as a inferior filter to the OEM. The filter only cost around $5 so it makes sense with the large investment you have in your truck. This is just my suggestion.
  23. Mar 24, 2016 at 8:03 AM
    csuviper
    Broomfield, CO
    Red Freighter likes this.
  24. Mar 24, 2016 at 9:30 AM
    Oper8r
    Oper8r New Member
    Stuttgart
    Sold my 2016 TRD PRO - Currently in BMW 535d Wagon
    In my Tacoma I went with Toyota Filter (mostly due to the comparison video mentioned^) and Mobil 1 synthetic.
    Quick question: should I be using Mobil 1 synthetic with my FFV engine?
  25. Apr 4, 2016 at 6:29 AM
    Ericsopa
    Ericsopa Old man and the sea
    Amsoil Signature Series full synth, and Amsoil filter. Otherwise, ANYthing but Fram if you care about your engine.
    Wynnded likes this.
  26. Apr 4, 2016 at 8:02 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I just purchased my 2014 tundra and am going to follow this mans advice on oil changes. Quite a few of members are using this combo.
    Mike, do you use the green bottle high fuel mileage or the gold bottle? Both are full synthetic.
  27. Apr 4, 2016 at 9:02 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Your manual trumps any anecdotes we might offer. That said, I use the Toyota filter and Mobile 1, and change the oil every 10k miles or 1 year, whichever happens first.
    Black Wolf likes this.
  28. Apr 12, 2016 at 8:38 PM
    Mike Tread lightly.
    south carolina
    I use the silver bottle on all my engines miles is nothing but a number to the oil.
    Some of the newer engines you need to run the green bottle.
    Always follow the manual for your temperature on cold starts where you live.
    Sorry I didnt see this early..
