Oil change
Discussion in 'General Tundra Discussion' started by Oldrosetattoo, Feb 20, 2016.
  1. Feb 20, 2016 at 12:07 PM
    Oldrosetattoo
    Oldrosetattoo [OP] New Member
    Eric
    2001 tundra SR5 access cab
    Gonna change the oil in my 6cyl 2001 tundra it has 154,000 miles on it runs like a champ conventional or synthetic. High mileage or synthetic blend help!
  2. Feb 20, 2016 at 12:40 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    I'd recommend Royal Purple, its a full synthetic. If you don't go with that then I'd suggest staying with a full synthetic like Mobile 1 or something similar.
  3. Feb 20, 2016 at 12:52 PM
    Oldrosetattoo
    Eric
    Why synthetic ?
  4. Feb 20, 2016 at 12:54 PM
    Oldrosetattoo
    Eric
    Synthetic because of miles? I thought synthetic was more of a regional thing like harsh weather and such?
  5. Feb 20, 2016 at 12:59 PM
    Nor7
    There are several good articles that can explain it better than I can but here's a good summary.
    Synthetic oil is not only refined but also distilled, purified and broken down into its basic molecules. This process not only removes more impurities from the crude oil but also enables individual molecules in the oil to be tailored to the demands of modern engines. These customized molecules provide higher levels of protection and performance than conventional oils. But the synthetic base oil is only half the story. The correct blend additives must go into the mix to create the oil.
  6. Feb 20, 2016 at 1:22 PM
    Oldrosetattoo
    Eric
    So the filter should follow suit then correct? Synthetic filter such as K&N or such? Thanks for the replies.
  7. Feb 20, 2016 at 1:30 PM
    I used to royal purple but Mobile1 is a more solid choice (synthetic) IMO.
  8. Feb 20, 2016 at 5:52 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    I use Valvoline 0w-20 full synthetic in my truck, with a toyota filter, no problems so far!
  9. Feb 20, 2016 at 6:52 PM
    Nor7
    Curious to know why you prefer Mobile 1? I used to use Mobile 1 and now I only use Royal Purple, they're both full synthetic.
  10. Feb 20, 2016 at 6:53 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    If you have 154,000 on the blend then keep it the blend. Not worth trying to make the change now. Shouldn't hurt though, but have heard its bad to go the other way; synthetic back to blend or the old fashion stuff.
  11. Feb 21, 2016 at 5:14 PM
    Oldrosetattoo
    Eric
    I went with Mobil 1 full synthetic with a K&N filter. That oil filter was a lol devil getting out without an oil wrench. Choose the K&N for the wrench off feature. So much easier. Thanks to all for the input.
  12. Feb 21, 2016 at 5:22 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I would stick with Toyota filters only. I use the trd but have read plenty to only use Toyota filters.
  13. Feb 22, 2016 at 11:19 AM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    I also run Toyota filters. I have read way to many horror stories of bad filters.
