Oil change
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by David18921, May 29, 2023.
  1. May 29, 2023 at 4:12 PM
    David18921
    David18921 [OP] New Member
    I recently got a 2020 tundra 5.7 v8. After I bought it I took a closer look at the carfax and found that although the old owner kept up to date on his oil changes(every 10000 miles) it looks like he went almost 14000 at one point. Do you guys think this will affect the reliability long term?
  2. May 29, 2023 at 4:15 PM
    AZBoatHauler
    So.Arizona
    Should be fine. I’d shorten the interval to 5-7K miles or yearly - whichever is first.
  3. May 29, 2023 at 4:18 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Go to religious 5k mile oil changes and send it.
    Tsm503 likes this.
  4. May 29, 2023 at 5:59 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    If the previous owner was an average driver and used good quality synthetic oil, you have absolutely nothing to worry about. But I, personally, would not make a habit of that.
  5. May 29, 2023 at 6:11 PM
    David18921
    Yea, I don’t know much about how he used the truck or what brand of oil he used, this is strictly judging off what I found on carfax.
    I know allot of people claim 7500, some even say as much as 20000. I personally agree though, I think 7500 is a better way to go
  6. May 29, 2023 at 8:27 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    5k/6mo whatever comes first…engine oil is cheaper than any oil related failures…
  7. May 31, 2023 at 6:44 AM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    with NORMAL Daily driving using a high quality oil, mobil or castrol etc..... is a no brainer 10,000 miles
  8. May 31, 2023 at 1:16 PM
    David18921
    the issue is that it was a lease, the guy went almost 14000 miles, assuming that the carfax is accurate, I’d be under the assumption he probably reved the sack off of it the whole time since it’s a lease
  9. Jun 23, 2023 at 5:55 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Carfax doesn't cover everything. I bet mine will only show the 2 dealer oil changes at 10K miles, I have always changed at 5K.
  10. Jun 23, 2023 at 6:36 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Agree on 10,000 , just change filter every 5000, stays real clean.
  11. Jun 23, 2023 at 7:18 PM
    2mchfun
    That 14k interval could have been a little bit hard on it, but I doubt it caused any significant wear. It really depends on use and the oil used. Long idle times, frequent short trips, weather, etc. all of it affects your oil and there is no way to be sure what happened to a lease return. As said above, minimum every 6 months is a good idea for the low mileage crowd. Also watch the oil level and keep it full between the changes.
  12. Jun 23, 2023 at 7:35 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    :lalala:
    stevesgraytundra likes this.
  13. Jun 23, 2023 at 7:48 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    OP how many miles on your truck?
    I do 3k/6mo. Most on here will say 5k/6mo which is universally recommended. 10k/1yr is just bonkers but y’all do your thing.
    BiggHertz likes this.
