Oil change torque spec question?
Discussion in 'General Tundra Discussion' started by cornwall325, Aug 3, 2019.
  1. Aug 3, 2019 at 10:05 AM
    cornwall325
    cornwall325 [OP] Work in Progress
    2018 Tundra TRD Offroad Limited Crewmax
    I’m getting two different torque recommendations for the oil drain plug. One article says 22 ft pounds and the other says 30 foot pounds. In the middle of the oil change now and would like clarification on all torque values if you guys could help out.
    Thanks
  2. Aug 3, 2019 at 10:20 AM
    cornwall325
    Also tricks on removing stuck on drain plug gasket without damaging.
  3. Aug 3, 2019 at 10:27 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
  4. Aug 3, 2019 at 10:38 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    30 ft/lbs is correct. As far as the stuck gasket, a razor blade scraper should pop out off.
    BTBAKER likes this.
  5. Aug 3, 2019 at 10:39 AM
    Campesino
    Campesino New Member
    2014 Tundra CM Off Road
    These are the torque specs I use :
    Drain plug bolt: 30 ft/lbs
    Filter housing: 18 ft/lbs
    Filter drain plug: 9 ft/lbs
    Though I switched my oil pan drain out with a valve so I don't worry about that part any more
    If you're interested:
    https://www.amazon.com/dp/B01AMXAR8O/ref=cm_sw_r_cp_apa_i_5xCrDb8A3TZKK
    As for the stuck drain plug gasket maybe a thin metal spatula or razor blade to pry it apart.
    Good luck!
    hllacea20 likes this.
  6. Aug 3, 2019 at 10:45 AM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Cab
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    Is that the right size for the drain?
    M12x1.25x12mm
  7. Aug 3, 2019 at 10:49 AM
    cornwall325
    Thank you sir for the quick tip. Didn’t have a scraper but did have a razor knife and it came right off. I guess it’s somehow like that from the factory. Thanks again so much! Now on to the oil change again.
    duece292 likes this.
  8. Aug 3, 2019 at 10:49 AM
    duece292
    Greg
    Green Bay, WI
    Yes, that's the correct size.
  9. Aug 3, 2019 at 10:49 AM
    Rustedfenders
    Wally
    Rosedale Md.
    Thanks.
  10. Aug 3, 2019 at 12:57 PM
    cornwall325
    Torque specs for skid plate bolts and front screws?
  11. Aug 3, 2019 at 3:28 PM
    duece292
    Greg
    Green Bay, WI
    I'm probably a little late but...
    21 ft/lbs for the skid plate bolts and
    48 in/lbs on the screws
  12. Aug 3, 2019 at 4:33 PM
    cornwall325
    Got it all done. Had a get together to go to so all that’s left to do is check oil level is good and reset the maintenance light. All this is new to me but thank you guys for all the help. I’m gonna do some more reading about all of this once I get back home.
  13. Aug 3, 2019 at 5:10 PM
    duece292
    Greg
    Green Bay, WI
    Nice job! 8 quarts should get you right where you need to be. Remember to check the level when the truck is warm. Get it up to operating temp, shut it off and let it sit for about 5 minutes and then check the level.
  14. Aug 3, 2019 at 5:57 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Not that is getting a little OCD. Torque is not critical on those bolts.
    wakeboarder likes this.
  15. Aug 3, 2019 at 8:06 PM
    cornwall325
    Is there a source somewhere online where we can purchase something that has all of the torque specs for our trucks?
  16. Aug 3, 2019 at 10:36 PM
    duece292
    Greg
    Green Bay, WI
    Haynes and Chilton manuals include torque specs. Both are available as a paper manual and Haynes has an online version.
  17. Aug 3, 2019 at 11:02 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Dude, that’s sh*t was funny, my side ache from laughing.
  18. Jan 26, 2021 at 7:02 PM
    bwana
    bwana New Member
