Oil Change Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by intr3nsic, Sep 14, 2020.
  1. Sep 14, 2020 at 8:36 PM
    intr3nsic
    intr3nsic [OP] New Member
    I am sure this has been asked a million times. For those of you who live in Canada, where do you find the best places and prices for your oil and filters? I am reading that Mobil 1 full synthetic is a favourite (I see much debate). I also need a 64mm tool for the oil change? I apologize, I just got the truck not too long ago.
    YardBird likes this.
  2. Sep 14, 2020 at 9:58 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Shop around different retailers for lowest prices, promotions and rebates. I was able to get 6 5 gallon jugs of valvoline for $66 from Walmart. Engine oil is all the same, if you change it within the manufacturers recommended interval. Oil filter and gasket I ordered from the dealer. Stock up since they charge shipping. It came out to like $3.86 for filter and $0.86 for gasket, each.
    Also make sure to update to the aluminum I'll filter housing, from the cheap plastic oil filter housing.
    I think 64mm is the correct size of the tool. Double check using Walmart or Amazon site and search by tundra or your engine size. See the reviews.
  3. Sep 14, 2020 at 10:08 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
  4. Sep 17, 2020 at 8:08 PM
    intr3nsic
    I had posted links to what I thought were the tools, I removed them. Am I allowed to do that? :O
  5. Sep 17, 2020 at 8:16 PM
    AZBoatHauler
    So.Arizona
  6. Sep 17, 2020 at 9:58 PM
    intr3nsic
  7. Sep 17, 2020 at 10:12 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Tundra14Platinum likes this.
  8. Sep 18, 2020 at 7:53 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Get the Motivx tools @AZBoatHauler recommended. The Motivx filter housing wrench is forged aluminum. Cheaper chinese imitations are cast aluminum and are not as strong. Members have experienced breaking of cast filter housing tools.
    https://www.amazon.ca/s?k=motivx+tools&i=automotive&crid=22Z3R7SVANHTJ&sprefix=motivx,automotive,179&ref=nb_sb_ss_ts-apa-p_2_6
    The plastic filter housing is also prone to breakage. If you're changing your own oil and not over-torqueing the housing, you may get by without breaking the plastic housing. If you change to the aluminum housing @TILLY recommends, you'll have to swap the longer center perforated tube from the plastic housing to the aluminum housing. The spring and valve plate in the bottom of the housing must remain. Many other threads here on this, do a search.
    AZBoatHauler likes this.
  9. Sep 18, 2020 at 1:43 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
  10. Sep 21, 2020 at 6:28 PM
    intr3nsic
