Oil Change Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Major, Dec 30, 2019.
  1. Dec 30, 2019 at 8:45 AM
    Major
    Major [OP] TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Can’t get the nut out of the housing, I don’t know who torqued this. I literally took the filter off using it. Can I buy a new one from a part store? Any suggestions on how to get it off?
    Tango in advance.
  2. Dec 30, 2019 at 8:55 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I would leave it alone and put it back on the Tundra. Then I would order a new aluminum filter housing. Then on your next oil change, you can apply some force to the plastic housing to get the drain plug out and then use the aluminum filter housing.
    parkerbows, rodm1, equin and 7 others like this.
  3. Dec 30, 2019 at 8:57 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I would think you could hold the canister with a pipe wrench or large pliers and use the 3/8 ratchet drive to remove.
    Many have upgraded to the aluminum canister.
  4. Dec 30, 2019 at 8:57 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Why do you want to get the nut out? I purposely torqued the shit out of the nut so it'd stay in, then you don't need any special tools to remove the housing. Just throw an extension up there and hold a drip pan under it and the whole process is painless and easy.
    Mnorris1206, Durania and MacCTD like this.
  5. Dec 30, 2019 at 8:58 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    ^ this. Many swap out this plastic housing for the aluminum. I did on my first oil change.
    BTBAKER likes this.
  6. Dec 30, 2019 at 9:01 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    By removing that nut, it allows you access to drain the oil filter housing using the “nipple” that comes with the new oil filter, making the job so much cleaner. Yes, you can just remove the whole housing like the OP had to do, but that’s far more messy, from my experience (mine was over-torqued as well and I went thru this).
    15whtrd, BTBAKER, classiccat and 2 others like this.
  7. Dec 30, 2019 at 9:04 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Had the same issue on my Tacoma and my moms rav4. The dealers seem to be using that to tighten the canister
    I replaced mine with the aluminum housing. I had to clamp the plastic one in a vice and eventually got it out. I’m amazed nothing broke, the torque spec is 10 ft lbs and it was more like 100
    monaco730 likes this.
  8. Dec 30, 2019 at 9:07 AM
    snivilous
    SW UT
    Yea I've seen all the posts where people go to huge lengths to avoid getting a drop of oil on their hands. To each their own, I've never had a huge mess and would rather make the whole process quicker and more efficient.
    Sundown5oh, MJoeP and jerzeedivr like this.
  9. Dec 30, 2019 at 9:24 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    As suggested by @gdiep, get a new aluminum housing with the plug and install at your next change. Don't forget to swap the center tube out of your original plastic housing.
    That drain plug is definitely in there to stay, as evidenced by deformation of the sides of the 3/8" square drive. If you buy the Toyota filter, it will come with the o-rings for the drain plug and the housing (and, of course, it also comes with the drain spigot, which I found next to useless).
    https://www.amazon.com/Genuine-Toyota-Housing-15620-31060-15643-31050/dp/B07984MX2G/ref=sr_1_8?crid=1G0VAHU46U10X&keywords=toyota+oil+filter+housing&qid=1577725901&sprefix=Toyota+oil+filter+%2Caps%2C174&sr=8-8
    https://www.amazon.com/Set-Toyota-0...2V3765XZBWJ&psc=1&refRID=2764RGJSP2V3765XZBWJ
    DR132 and gdiep like this.
  10. Dec 30, 2019 at 2:04 PM
    Major
    Josh
    NC
    Stock.
    This
    Jrharvey02[QUOTED] likes this.
  11. Dec 30, 2019 at 2:07 PM
    Major
    Josh
    NC
    Stock.
    I got the aluminum housing just didn’t come with that nut hence why I was trying to remove. Tried everything but it forged to the previous plastic. Ended up going to the dealership and buying the nut. Want it removable for my next as I put the Fumoto valve in. Can’t wait to change again
    Thanks all for the input.
  12. Dec 30, 2019 at 2:48 PM
    JohnLakeman
    You plan to screw the Fumoto valve directly into the filter housing drain hole? Assuming that the drain plug and the Fumoto valve has the same thread, does the Fumoto valve have enough threaded length to depress the spring-loaded check plate? If it doesn't, the Fumoto valve isn't going to drain any additional oil not already drained by simply removing the drain plug.
  13. Dec 30, 2019 at 2:52 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Just changed the oil this weekend, already installed the fumoto valve and aluminum housing. Quick, easy and no mess. Open valve above 5 gallon pail and drain oil out of aluminum housing. By the time filter area is cleaned off, new filter and installed. Oil valve closed and time to add new oil. Not a drop on the concrete. Fumoto valve is the way to go along with the aluminum housing. Keep the original plastic one in a ziplock bag on the shelf as a replacement ( I don't know why). Well worth the money for those upgrades
    15whtrd and NewImprovedRon like this.
  14. Dec 30, 2019 at 3:54 PM
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    I think I’m gonna have to give that Fumoto valve a try!
  15. Dec 30, 2019 at 4:26 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    When you need to remove the drain cap and it wont come off just leave it on and give it a zap with an impact gun if only a 1/2 inch, get an adapter to 3/8.
    It is advisable to replace that oring evey now and then because it gets hard and flat then leak. Just saying
    johnnyskullface and Drew05 like this.
  16. Dec 30, 2019 at 4:29 PM
    @Prostar 190 what's the one you have? Thought I'd tag you in on this, I know you have a different filter housing
    Prostar 190 likes this.
  17. Dec 30, 2019 at 4:44 PM
    Jowett Performance
  18. Dec 30, 2019 at 4:47 PM
  19. Dec 30, 2019 at 10:15 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Oh my my, where can I buy?
  20. Dec 31, 2019 at 2:29 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    When I bought mine it was to tight that a 1/2" breaker bar and the housing in a vise couldn't get it off.
    I bought one of these and its awesome. Mine came with the socket.
    https://jowettperformance.com/products/coming-soon-billet-oil-cap-for-filter
    He's sold out at the moment but he is really good at customer service and getting things to you fast..
  21. Dec 31, 2019 at 2:45 AM
    I don't know when he's going to run another batch but Jowett Performance is who makes them.
    Bravohook likes this.
  22. Dec 31, 2019 at 7:17 AM
    Major
    Josh
    NC
    Stock.
    Oh my my...I need that! Thanks fellas!
  23. Dec 31, 2019 at 7:45 AM
    Major
    Josh
    NC
    Stock.
    Nah, just the pan. I would like one like the Jowett Filter Housing though.
    Prostar 190 and georgiey22 like this.
  24. Dec 31, 2019 at 8:41 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    I think the plastic ones swell up. I couldn't believe how much effort it took to remove the cover that is only supposed to be tightened to 20 or so lbs.
    Major[OP] likes this.
  25. Dec 31, 2019 at 9:35 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I switched mine out with a metal one. I leave the filter drain plug in and spin the whole assembly off like a regular filter.
  26. Dec 31, 2019 at 10:41 AM
    I've been waiting since March 2019. Brian told me he would be restocking soon and to text him.
    I texted him in May, August, September and December...........No response :notsure:
  27. Dec 31, 2019 at 10:53 AM
    Trooper2
    JR
    Maybe we could approach with a group buy.
    rodm1, P-Factor, jdh564 and 1 other person like this.
  28. Dec 31, 2019 at 10:59 AM
    That would be nice but he stopped replying. :(
  29. Dec 31, 2019 at 11:17 AM
    Trooper2
    JR
    Just emailed Brian fro website. Will see if he responds.
  30. Dec 31, 2019 at 11:22 AM
    :fingerscrossed:
