Oil change intervals
Discussion in 'General Tundra Discussion' started by robie56, Dec 11, 2014.
  1. Dec 11, 2014 at 12:27 PM
    robie56
    robie56 [OP] New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    I was told by the Toyota service department that my 011 tundra with full synthetic oil needs oil and filter change every 10,000 miles. How many miles do you other owners put on your oil?
  2. Dec 11, 2014 at 1:02 PM
    chphilo
    chphilo Tundra addict
    Western PA
    10,000 miles or 1 year, whichever comes first. I have changed oil (non-synthetic) every 6 month (5 non-synthetic oil change--free from Toyota), then two synthetic oil changes 1 year apart. So I got total of 7 oil changes so far. Since my mileage is always low, I just go by the months.
    By the way, I still haven't broken 13k miles yet.
  3. Dec 11, 2014 at 1:25 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    If its a flex fuel, its every 5k miles
  4. Dec 11, 2014 at 5:45 PM
    10k during the free changes...then I will change my own with synthetic every 5k..treat your engine good, and it'll treat U good.
    TruckyTruck likes this.
  5. Dec 11, 2014 at 6:07 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    7500 Amsoil Synthetic, they told me I can go 10,000+, but my filter would start breaking down, so I get it changed. Oil is almost as clean coming out as it was coming in.
  6. Dec 14, 2014 at 12:49 PM
    robie56
    Steven
    New Hampshire
    Thanx for your input guys, after reading your responses, I think I will put 10,000 miles or 1 year, which ever comes first. Then change the oil myself and see what it looks and smells like then decide if I will want to change it sooner. I use full synthetic in my bike and change it at the end of the season, with a new filter. I usually put 6-7000 miles a season on it, and the oil is still in good condition when I change it.
  7. Dec 14, 2014 at 8:11 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    You can also send an oil sample to blackstone for analysis. Then they send you a report back with comments/suggestions.
    MotoTundra and RingSteel like this.
  8. Dec 15, 2014 at 10:56 AM
    GQ 66
    GQ 66 (Input clever saying)
    Lake Jackson, TX
    2014 CM Limited
    Tinted Tails, hard wired passport escort, Magnaflow 50 series,
    I will be changing mine every 9,000 miles, but at the 3,000 and 6,000 mile marker, I will be changing the oil filter and topping it off. Fully synthetic may run for a long time, but the filter doesn't.
  9. Dec 15, 2014 at 11:08 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    For those that do their own oil change, how much do you typically lose with the filter?
    Lets say you run 15k mile oil but want to change out the filter every 5 - how much would you lose changing just the filter?
  10. Dec 23, 2014 at 8:36 PM
    RingSteel
    RingSteel CH-47 Super C Mainz-Finthen Army Air Field 73-75
    Texas Eagle-Ford Shale dodging crazy azz truckers
    14' SR5 CM TSS Barcelona Red, Blk rims & R/boards, tan seats
    I would follow the owners manual, period. You will be in right standing should any issues arise. The free 10k oil change is marketing hype. Only full synthetics are good for 10k. M1 used to advertise 25k back in the day before many here were born (jimmini i'm old!) But they lost in revenue. The sales pitch is 'free' and your truck should hold up for a while with marginal semi-synth. Oil and years down the line if you got problems it may be on you. Disclaimer I've run amsoil since 91 and only run the extended changes using their synthetic filters and UOA for trending; other wise I buy the 7500 mile/6 month oil changes and have peace of mind. I have even missed the mark by 3 to 4 months in my power stroke and the tbn numbers and wear metals were within normal range. So my peace of mind is if I miss my 6 month mark I will be ok, bit will get it done asap. Summary, use "bobistheoilguy" for tutorials, but would not blindly follow Toyota 10k reco just cause they market it as free.
