Oil change interval for my situation
Discussion in '2.5 Gen Tundras (2014-2021)' started by soobaroo, Dec 3, 2022.
  1. Dec 3, 2022 at 8:58 AM
    soobaroo
    soobaroo [OP] New Member
    Gene
    2019 Tundra SR5
    I may be too anal about oil changes so here’s my specifics. I only drive the truck 5000 miles or less a year. My job is less than a mile away and during the cold winters I do a lot of idling and short trips. Only do much highway driving in the fall during bird hunting season. I like to put fresh oil in at the start of winter and drain it out in the spring. I’m thinking one oil change a year in the spring would be enough. Am I just wasting money with the low miles being driven or is it a worthwhile precaution to do what I’m doing? Thanks
  2. Dec 3, 2022 at 9:11 AM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    Definitely. I have a car like this that gets driven about the same amount, all short trips. Oil gets changed yearly no matter the mileage.
    Oey12 likes this.
  3. Dec 3, 2022 at 1:28 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    If that was my use case, I’d be doing exactly what you are. Those short cold winter trips are tough on the oil. I’d want fresh oil come spring.
    MedCityMoto likes this.
  4. Dec 3, 2022 at 1:37 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I think you are right on. I keep to 5k mile oil/fitler changes on my vehicles.
    HulkSmurf14 likes this.
  5. Dec 3, 2022 at 3:19 PM
    soobaroo
    Gene
    2019 Tundra SR5
    What I’m wondering is if I change it in the spring should I leave it in for the winter rather than changing again in the fall. Seems dumb to be changing it at 2000 or so miles all the time
  6. Dec 3, 2022 at 3:21 PM
    soobaroo
    Gene
    2019 Tundra SR5
    If I did it would be one change per year rather than two. My dealers service advisor thinks changing it twice a year with the low mileage is unnecessary
  7. Dec 3, 2022 at 3:33 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Lots of sports car forums (BMW, Porsche, etc.) go with annual oil changes for low mileage cars.
  8. Dec 3, 2022 at 3:46 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    This! 6 months is fine for age and the cold weather short trip thing seals the deal for me.
    Oil's just not that expensive. Maybe just do the filter every 10k but I'd swap the oil for sure like OP's already doing
  9. Dec 3, 2022 at 3:49 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    I’d do 6months, just because of all the idling. Your engine is still running, and trace amounts of gasoline are getting into your oil. But then again, I plan on keeping my truck forever.
    Oey12 likes this.
  10. Dec 3, 2022 at 6:10 PM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    If you're paying a dealer to do this its overkill. I don't care for mystery bulk oil and Paper Toyota oil filters. With the money saved you can buy the best Amsoil filter and your choice of 0W-20
    Terndrerrr likes this.
  11. Dec 3, 2022 at 7:02 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Cheap to do 5k mile intervals LOF...cost of ownership. It'll be the last truck you own that way :hattip:
  12. Dec 3, 2022 at 7:10 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I'd stick with every 6 months regardless of milage, unless of course you didn't drive it for 6 months after changing it. Short trips are actually worse than long ones, especially in the winter. Its what Toyota refers to as "special operating conditions" along with idling.
    https://support.toyota.com/s/article/What-are-the-oil-chan-7604?language=en_US
    Oey12 likes this.
  13. Dec 3, 2022 at 7:22 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I would change oil every 6 months no matter what. Even if it's low miles. It's tough on your engine to do short trips. It's better to use conventional oil and change every 6 months rather than use synthetic and do once a year based on your usage.
    Oey12 and Black Wolf like this.
  14. Dec 3, 2022 at 7:32 PM
    Ditto^^^^ Make sense in this instance.......
    MadMaxCanon[QUOTED] likes this.
  15. Dec 3, 2022 at 7:47 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I average 5 to 6K a year and this is mostly highway driving (80%). I change at 5k or 1 year, whichever comes first.
    However, like many have stated prior, in your case OP I would change every six months regardless of mileage because of the short tripping.
  16. Dec 3, 2022 at 7:53 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I do 6k a year and change my oil every 12 months.
