Oil and filter change, what tools will I need?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Belroi1, Feb 15, 2020.
  1. Feb 15, 2020 at 7:18 AM
    Belroi1
    Belroi1 [OP] New Member
    2014 4X4
    I am new to the forum.
    I purchased the truck new, 5.7 SR5 4X4. The dealer has always changed the oil in the past. This will be my first time.
  2. Feb 15, 2020 at 7:28 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  3. Feb 15, 2020 at 7:29 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    10mm and 12mm socket and ratchet(s) to drop the factory steel skid plate.
    14mm socket or wrench (I believe that's correct. I have a Fumoto on mine now so I don't pull a drain plug) for the oil drain plug.
    A 3/8" ratchet short extension to insert into the oil filter canister lid drain plug----to spin it off.
    Probably the silly oil filter canister cap/lid Specialty Tool to pull this oil filter cap/lid off.
    Oil drain pan.
    Shop rags or paper towels.
    A can of brake clean is always good to have around.
    Smart money would have the specialty tool on hand that screws into the oil filter canister cap/lid to drain it off of its oil-----before you pull the canister lid off. Someone will be along to show you a link to that tool (I don't use one as I have Jowett Performance oil filter canister lid with built in Fumoto valve).
    Voyagermike likes this.
  4. Feb 15, 2020 at 7:53 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    One important thing is QUALITY filter and oil. Not to open posts of the past, but a nice WIX filter or OEM Toyota with a synthetic oil of proper weight. Walmart is a good place to find decent prices on oil.
    Also, a nice LARGE drain pan with cap and handle, so you can just cap it, clean it, and take it to your local oil recycling facility.
    I have this one https://www.walmart.com/ip/FloTool-42003MI-Drain-Container-16-quart/44580714
    and it has done me well for the past few years. Big enough to catch any other drips during a change AND it stands on one end for storage.
  5. Feb 15, 2020 at 8:38 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    tlpru, AZBoatHauler and Voyagermike like this.
  6. Feb 15, 2020 at 9:12 AM
    Belroi1
    2014 4X4
    Thank you for all of your replies. You have made my up coming task mush easier.
    Belroi1
  7. Feb 15, 2020 at 1:50 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Plenty of time.So many things to remove to do a simple oil change.
    Rocko9999 likes this.
  8. Feb 15, 2020 at 1:53 PM
    abpadilla1794
    abpadilla1794 New Member
    Alexis
    Black 2016 Toyota Tundra 1794 4x4
    I second what everyone else has said ^^
  9. Feb 16, 2020 at 5:59 PM
    smokey0810
    I’d also recommend checking the website of whatever oil mfr you choose. I know Pennzoil often times has $10 rebates, so if a 5 qt jug at Walmart is $21, ends up being $11 after rebate. Not a bad price at all.
    Belroi1[OP] likes this.
  10. Feb 17, 2020 at 9:01 AM
    Belroi1
    2014 4X4
    Thanks for the rebate info. Pannzoil has two now, $22.00 Shell gift card good until Feb 23, & $10.00 good for the rest of this year. I will need more than one jug.
  11. Feb 17, 2020 at 11:20 AM
    smokey0810
    With the Pennzoil though, just make sure your local retailer is listed on there.
    Oreilly is also have a PZ and Wix filter rebate. 5 quart jug of Platinum with Wix filter for $33 with $10 rebate.
  12. Feb 17, 2020 at 11:57 AM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    go ahead and buy you a FUMOTO valve.... its worth it in long run
  13. Feb 17, 2020 at 11:58 AM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
  14. Feb 29, 2020 at 8:25 AM
    Norseman64
    Norseman64 New Member
    Michael
    San Lorenzo, CA
    2015 Barcelona red SR5 4x4 crewmax
    K&N air filter, EAG 86” vicious steps, center console organizer, Husky floor liners, yellow fog lamps, debadged, President CB radio w/ k40 antenna, pine scented air freshener tree.
    Do yourself a favor! If you have a plastic filter cap get a metal one off Amazon or eBay and switch it out at your first change (the plastic ones are insanely hard too get off because they get way too tight). I actually got the Toyota brand metal cap for around $21.00 off of Amazon. The biggest problem is plastic mating up to a metal base.
  15. Jul 11, 2021 at 9:22 PM
    clauderdale001
    clauderdale001 New Member
    Cody
    Hernando, MS
    2017 White Tundra TSS
    Which Fumoto valve is the correct one?
  16. Jul 13, 2021 at 6:37 PM
    smokey0810
