Offset question
Discussion in 'Wheels & Tires' started by Tdog408, Feb 19, 2021.
  1. Feb 19, 2021 at 1:54 PM
    Tdog408
    Tdog408 [OP] New Member
    T
    2020 Cement Tundra Limited TRD Off Road/ 2017 BMW M4
    Hello everyone.
    Looking to get some Methods MR305 NV for my 2020 tundra. Would a 0 offset or 25mm offset be better? My apologies for the noob question.
  2. Feb 19, 2021 at 2:01 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Depends- running stock suspension or lifted? Tire size?
    Stock wheels are +60. The more negative offset the more the tires stick out from the truck. With a 0 offset your tires could rub the body mount. 25mm is a good middle of the road and a popular offset used by many- offer more clearance than stock for the UCA but usually does not cause rubbing on body mount, but again, that depends on the tire size.
    Check the stickies in the wheel and tire section on this site. There is some good info on wheel offset, what tires fit stock/lifted, etc.
  3. Feb 19, 2021 at 2:03 PM
    Tdog408
    T
    Truck is lifted 3”. Will be running 285/75/18
  4. Feb 19, 2021 at 2:09 PM
    frichco228
  5. Feb 19, 2021 at 2:17 PM
    Tdog408
    T
  6. Feb 20, 2021 at 7:29 PM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    Get +25 offset. I have same wheels. The tire and wheel offset what will allow clean fitment or rubbing.
    Tdog408[OP] likes this.
  7. Feb 20, 2021 at 7:35 PM
    Tdog408
    T
    Wheels and tires on order. Got the 25mm offset
  8. Feb 20, 2021 at 7:39 PM
    Tdog408
    T
    Would you have pictures of your truck with the wheels?
  9. Feb 21, 2021 at 11:52 AM
    Mill72
    Mill72 New Member
    California
    The only picture I have at the moment. If you want more of different angle let me know.
    TRDblvd and AggiePhil like this.
