Offset of spare?
Discussion in 'Wheels & Tires' started by Pillslinger, May 8, 2021.
  1. May 8, 2021 at 8:45 PM
    Pillslinger
    Pillslinger [OP] New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Does anyone know what the offset of the factory 18" spare wheel is for a 2018 TRD OR? Is it +60 like the TRD rims?
  2. May 8, 2021 at 9:10 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I used a good resource, I'll try to find it.
    Try this:
  3. May 8, 2021 at 9:21 PM
    Pillslinger
    Rollin
    SWMO
    Looks like they have all the details on the factory sizes, but I dont see where they discuss the spare specifically. I may just drop it tomorrow and see if its stamped on the rim. Thanks!
  4. May 8, 2021 at 9:21 PM
    alb1k
    Left Coast
    It's good
    Hmmm, that may not help with the spare, but It has to clear, so maybe it does help.
    Edit, just read your post. I imagine the spare is a steel wheel but at a minimum, has same or more backspace and same diameter, could be narrower affecting offset.
  5. May 8, 2021 at 9:23 PM
    Pillslinger
    Rollin
    SWMO
    I appreciate it!
  6. May 9, 2021 at 4:27 AM
    biebs96
    PA
    I’m interested in a definitive answer as well since I have recently added a 35 to my spare.
    One would assume it would match the factory wheels offset.
    2mchfun likes this.
  7. May 9, 2021 at 5:12 AM
    Pillslinger
    Rollin
    SWMO
    Ya, my tires are a tight fit. I was planning on replacing my 32in spare tire with an appropriate size to match my 34s. My 34s are on a +25 offset. If that spare is a +60 I'll need to choose my spare size very carefully.
  8. May 9, 2021 at 5:59 AM
    Pillslinger
    Rollin
    SWMO
  9. May 9, 2021 at 8:29 AM
    alb1k
    Left Coast
    It's good
  10. May 9, 2021 at 8:34 AM
    TheBeast The Beach
    are you trying to match the other 4 ? Should fit no issues.
    If you bend or remove the guides you can fit a 35" there.
    Anytime you change tire size or offset /lift etc, matching spare is best.
    grave likes this.
  11. May 9, 2021 at 8:58 AM
    Pillslinger
    Rollin
    SWMO
    So I've got 305/70 17 on a +25 offset. I'm not looking to use a tire/wheel combo as a 5 point rotation or anything. Just as an emergency backup. So I figured I could use the stock 18 spare and match up a tire size that would be equal to the overall diameter (or closer than the 275/65 that's on it now) even if just until I can find a decent deal on an equivalent wheel. That's what started me down this path searching for the spare wheel offset. However with that +60 offset I dont think I will be able to match diameter with a 33.8 tire for an 18in wheel that I can reasonably expect to fit without rubbing. Unless I planned to use it as a rear tire only and shuffle the others accordingly if necessary.
    TheBeast[QUOTED] likes this.
  12. May 9, 2021 at 9:01 AM
    TheBeast The Beach
    yes makes sense.
    However if you stuck far away from any roads, matching spare is worth it imo. even if its a used rim/tire but at least correct offset/size. my 0.02.
    Pillslinger[OP] likes this.
  13. May 9, 2021 at 10:23 AM
    biebs96
    PA
    That’s what I did. Picked a used tire, in the same size as my current larger then stock tires for emergency use.
    cut off the guides and the 35 fit right up there.
  14. May 9, 2021 at 10:28 AM
    biebs96
    PA
    Using the stock spare wheel and a 285/70/18 (an odd size to find easily available) will be almost the exact size you want.
  15. May 9, 2021 at 1:15 PM
    Pillslinger
    Rollin
    SWMO
    Spot on buddy. Thanks for the help on this! I've been living on that tire size website for months while choosing my tires. Looks like some TRD PRO guys run 285/70 on a +60 offset with no added lift (beyond the 2 extra inches already on the PRO) with no problems. I'm at 2.5 upfront so that's a winner!
    biebs96[QUOTED] likes this.
  16. May 9, 2021 at 2:05 PM
    biebs96
    PA
    you’ll be fine. I’m on a 2” front lift on stock wheels with 285/75/18s and they fit well.
  17. Jun 30, 2021 at 6:25 PM
    shdwkeeper
    shdwkeeper New Member
    2013 Magnetic Gray Tundra 4x4 Limited CM
    Diamondback Bed Cover (Line-X) Bed Rug Mirror Caps (Paint Matched) Door Handles (Paint Matched) 2020 Sequoia TRD Grill Conversion Morimoto XB Fog Lights Alpharex Pro Jet Black Headlights HIKARI 2021 Acme-X H7 LED Bulbs 6112 (top setting) / 5160 Combo @Coachbuilder1 Differential Drop Kit 1.00" @Coachbuilder1 Coilover shims (2 drive-side 1 passenger side) @Coachbuilder1 Front Bump-stop extensions @Coachbuilder1 Front Bumper Shims @Coachbuilder1 +3 Shackles Fuel Vector 18" +20 Wheels 35x12.50x18 Nitto Ridge Grapplers RCI Off-road Engine Skid plate Desert Eagle Off-road transmission/catalytic converter protection plate Interior: VLEDs 5K cabin interior + LED strip footwell Coupe Custom Battery Mount WeatherTech Floor Mats
    I have 35x12.5x18 Nitto Ridge Grappler on a 18x9 +20 offset rim. Are you saying I can put a 285x75x18in tire on the stock +60 offset spare wheel and I should be fine? I'm worried I'll rub in the front, as it was mentioned earlier.
  18. Jun 30, 2021 at 6:44 PM
    biebs96
    PA
    that’s the size tire I have, on the factory black steel wheel.
    it fits, you will have to cut off the two “tabs” that are under the bed. But after that, a slow raise and careful placement will get that big ass tire tucked up under there.
  19. Jun 30, 2021 at 7:26 PM
    shdwkeeper
    I'm just wondering if it's safe to drive on the spare and will it fit without rubbing with that offset until you get the main tire fixed.
    I dont want to have major rubbing issues in the front if all of sudden I have a flat in middle of no where.
  20. Jun 30, 2021 at 7:30 PM
    biebs96
    PA
    I am currently running 285/75/18 on stock wheels (which are the same offset as the spare, +60) and I have zero rubbing issues or suspension conflicts.
  21. Jun 30, 2021 at 9:59 PM
    shdwkeeper
    ok, thanks. Maybe I put it on and test it
  22. Jul 5, 2021 at 5:09 PM
    shdwkeeper
    I put a 285/75/18 Terra Grappler G2 (used) on the stock spare wheel and tested out the fit and it cleared everything, than stuck it up in the stock location under bed. I think overall diameter is 34.84in. Thought this would be a great spare for my 35x12.5x18 Nitto Ridge Grapplers. I also have the Coachbuilder +3 shackles. Had my tire shop air hammer out the stock tire guides, than I painted it with black Rustoleum spray paint. Here are some pics.
    20210705_120636.jpg 20210705_122018.jpg 20210705_144038.jpg 20210705_150118.jpg 20210705_150044.jpg 20210705_150147.jpg 20210705_150101.jpg 20210705_150129.jpg
    biebs96 likes this.
  23. Feb 14, 2023 at 11:44 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Ok kill me and talk bad about for opening an old thread. But I'm looking at put a bigger spare under here(285/65/20) and I was wondering if anyone has done this that the TRD dual exhaust. It looks like my hangers will be in the way. I didn't want to cut the tabs if they will be. Hopefully these pictures will help. 20230214_144026.jpg 20230214_144013.jpg
