Offset confusion
Discussion in 'Wheels & Tires' started by Gasparr597, Mar 26, 2020.
  1. Mar 26, 2020 at 9:04 AM
    Gasparr597
    Gasparr597 [OP] New Member
    mike
    2017 SR5 double cab Quick Sand
    Rough Country 3/1.5 level lift
    So I have heard multiple people say the sweet spot for the 3rd gen tundras aftermarket wheel offset is between +30 and +18 with not having to do a bmc now iam confused by this because when coming to offset the lower you go in number when it’s still positive the more the wheel will stick out away from the fender example +20 will stick out less than +1 now I have a 3/1 lift in my 17 tundra. I was told by multiple people when doing wheels do the +20 rather than the +1 I wanted to run for more poke because if I went with the +1 I’d have to do a bmc but I don’t understand how because the +1 would push out further. Please explain if you can.
    2010bigdog likes this.
  2. Mar 26, 2020 at 9:16 AM
    TXTundra2722
    2015 Black Tundra
    The further your rim "pokes" out, the wider the path the outside edge of your tire travels when you turn the wheel. The outside edge(when turning) is what hits the body mount.
    Backslider and joonbug like this.
  3. Mar 26, 2020 at 9:22 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Not trying to confuse you further, but offset only talks about the wheel. And a +20 offset on a 8.5" rim is different than a +20 on a 9" rim. I suck at explaining it, but do yourself a favor and look up backspacing. You will need 5.5"-5.75" of backspacing no matter the rim width. Then you can get the correct offset on a rim width you want.
  4. Mar 26, 2020 at 9:26 AM
    Look up customwheelsoffsets.com they can help you
  5. Mar 26, 2020 at 9:35 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    50mm on an 8 wide clears 35s with a good alignment. Those are rock warrior specs.
    Look up icon wheels for proper 8.5 wide specs, their wheels clear 35s with proper alignment as well.
  6. Mar 26, 2020 at 9:39 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I’m a little confused too. I currently have 20x9 with a +20 and Like how they stick out but looking to get 22x9.5 or 22x10 so was wondering what offset I would need to get the same look as my current setup?
  7. Mar 26, 2020 at 11:00 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    26mm per inch. Extended .5-1" will require an about 6-13 offset increase to have the same backspacing as your current setup.
  8. Mar 26, 2020 at 11:35 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    25.4mm to 1in ;)
  9. Mar 26, 2020 at 11:52 AM
    TXTundra2722 likes this.
  10. Mar 26, 2020 at 11:56 AM
    Mnorris1206
    08 tundra
    I personally would check out custom offsets there galley and info from other owners helped me alot.
  11. Mar 29, 2020 at 5:14 AM
    Ebayollis
    Ebayollis New Member
    Josh
    Spruce pine NC
    2020 Voodoo limited
    When you say they clear 35s, do you mean without having to do a BMC?
  12. Mar 29, 2020 at 6:32 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Offset caluculator and converter Convert Backspacing/Offset
    jewsNbrews likes this.
  13. Mar 29, 2020 at 6:40 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    What size tires you running? Here’s mine 295/70/18 0 offset and didn’t need the BMC. It took the same amount of trimming as my old +18 wheels needed. Little bit on the inner fender liner up front and removal of front mud flaps
    TwistedTad and 1lowlife like this.
  14. Mar 29, 2020 at 7:12 AM
    Gasparr597
    mike
    wanted to run a +1 offset vs the +20 I went with but I figured I’d rather be safe than sorry and possibly run spacers if I need more poke
  15. Mar 29, 2020 at 7:26 AM
    xtyfighterx
    Ty
    North Idaho
    Ya you would of been fine with +1. Either way it will look great
  16. Mar 29, 2020 at 7:39 AM
    Gasparr597
    mike
    with the +1 how much are you clearing the body mounts by at full lock
  17. Mar 29, 2020 at 7:44 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Did you look up the Icon or research the rock warriors a little at all?
    Yes, you'll still have an unmodified OE cab mount.
    I still have my cab mount, and all the plastics in my wheel well. Only thing I don't have are mud flaps.
    Noting to note: with rock warriors and 1.25" spidertrax - I would have had to do a CMC, but rather I decided to take the spacers off and problem solved.
  18. Mar 29, 2020 at 12:42 PM
    xtyfighterx
    Ty
    North Idaho
    Idk I’d have to look it clears tho lol
  19. Mar 29, 2020 at 12:59 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    IIRC full locks not the issue, you actually rub mid turn. 1st pic mid turn, 2nd almost full.
  20. Mar 29, 2020 at 1:11 PM
    JohnHilton5.7
    JohnHilton5.7 New Member
    2019 black Tundra Limited
    Leveling kit, window tint, 3rd brake light, wheels and tires, line of fire, all LED interior lights, remote start, stubby antennae, LED front turn signal bulbs, bed cover, dash cam, TRD exhaust, spray in bed liner
    I am running 20x10s with a -19mm of offset with a 275/55/r20 tire and all I had to do was remove the splash guard off of the front bumper...it just barely touches the mud flap but clears the body mount by a mile, I love the stance of my truck now and I put it in the CustomOffsets gallery if you want go check out all the pics
  21. Mar 29, 2020 at 1:22 PM
    Gasparr597
    mike
    Gotcha I see mid turn your very close are you running 295-70-18 with a +1 as well?
  22. Mar 29, 2020 at 2:22 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    35x12.5
    50mm offset 8 wide
    I was more so trying to note that full lock, while it can be an issue, mid turn comes sooner (offset variations considered).
