Offset/Backspacing Confusion
Discussion in '1st Gen Tundras (2000-2006)' started by Peediz, Nov 22, 2020.
  1. Nov 22, 2020 at 8:00 PM
    Peediz
    Peediz [OP] New Member
    I'm looking at new wheels and seeing different offset/backspacing options and I'm not sure which to choose for my 06 DC.
    I'm browsing 17x8 and would probably pair them to a 285/70 17. Currently I have a stock suspension but plan on getting 5100s and an add a leaf or possibly a new leaf pack.
    How do I know which offset/backspacing to choose to make sure the tire/rim isn't tucked in too far or bumped out too much?
    Anyone running a similar set up that I described above? What offset/backspacing did you choose? How's the fit? Any rubbing or other issues? Pics would help a bunch.
    Thanks.
  2. Nov 24, 2020 at 5:23 AM
    Motopilot
    Motopilot New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    A7062D27-595B-4CC1-8F37-D962600B190A.jpg CC95D438-1E8D-4E39-90D1-03ABD8A07F26.jpg I just put 285/75R16 with bilstein 5100 on 4th position. I also put new wheels 16x8 with 4.5 backspace and have zero rub issues In either direction.
    Weagle, Kimosabe and Peediz[OP] like this.
  3. Nov 24, 2020 at 9:02 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    On an 8" wheel aim for 4" backspacing. 4.5" works but depending on tire and amount of lift you may slightly rub frame. Not a big deal, it won't hurt anything but can be annoying, I have 4.5 backspace and 285s.
    3.5" backspacing is a bit more aggressive, going that far you'll not hit frame but will hit body at turn/reverse. 4" is the happy place.
    I have pics and more info in this thread
    https://www.tundras.com/threads/how-big-is-yours-measure-up.46186/
    Peediz[OP] and Motopilot like this.
  4. Nov 24, 2020 at 11:20 AM
    Peediz
    Thanks guys
    Darkness likes this.
  5. Nov 24, 2020 at 1:34 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I currently am running 16x7 wheels with +35mm offset (5" BS I think) and just ordered some 16x8 wheels with +0 offset (4.5" BS) to help stick the wheel/tire a little further away from the spindle and frame. I'm running 285/75/16 tires.
  6. Nov 24, 2020 at 2:39 PM
    Professional Hand Model
    Hand Protectors
    The Sweet Spot tire and wheel size. :yes:
    Peediz[OP] and Kimosabe[QUOTED] like this.
  7. Nov 25, 2020 at 7:57 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    @Professional Hand Model that's what I'm hoping. I'll report back when I get them mounted. I'd prefer to not run spacers if possible.
  8. Nov 25, 2020 at 8:01 AM
    Hand Protectors
    Yeah. You’ll probably rub a little on the inside frame with a hard full turn like going into a tight parking space. Other than that no problems. The other option is spacers, which I avoid as well, but lead to another rub problem at the wheel wells.
    I have Michelin Defenders which is an awesome tire.
  9. Nov 25, 2020 at 8:08 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I could be totally off, but my hope is that once I adjust the UCA settings and get my caster right I should be okay. I'm going to take the heat gun to the plastic liners and mold them to give more space. I'm also relocating my washer fluid bottle on the passenger side to make more room.
