Official Gas Mileage Thread
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, Oct 3, 2019.
  1. Oct 3, 2019 at 9:09 PM
    Darkness
    Darkness [OP] Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Let's stop spamming up other threads.
    What model truck? (RC/AC/DC)
    2WD or 4WD?
    Tire and/or hearing different from stock?
    Bed cap or cover?
    Just for fun, what octane gas?
    Go.
    tacoguybill, TX-TRD1stGEN and bmf4069 like this.
  2. Oct 4, 2019 at 3:28 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I'm thinking we need the year also and at least the altitude, if not the location.
    Location/ altitude- Utah at around 5000-5200' above the drink
    2006 double cab
    2WD or 4WD?
    4wd
    Tire and/or gearing different from stock?
    315/75/17 (about 35x12.5) bfg at with factory 4.10 gears. +3.5" width each side suspension with about 2-3" of lift in front and factor rear.
    Bed cap or cover?
    Nope
    Just for fun, what octane gas? 87 which is our mid grade
    Extra weight? Some recovery gear, 5-7 gallons each of water/fuel, and a pretty heavy front suspension.
    Performance parts?
    Reusable dry filter(aem I think), magnaflow knockoff muffler dumped before axle, and intake tube rerouted to bumper(probably less flow than stock)
    Avg mph 14.5-15.5
    Tricks
    . I lock out od quite a bit when I'm going between lights at less than 50. Saves the brakes and there's less gear searching. I also listen to classical music which calms the soul. I don't race to every light unless I'm really late or need to change lanes or what have you. It's not a rocketship so I pretend it's a gocart and carry momentum.
    Type of driving- about 20-30% in town and the rest highway driving from 60-80mph. Mostly flat with regular wind.
    A pic for reference.
  3. Oct 4, 2019 at 4:48 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Can I just state that to me, the only thing that matters is what you average. At the end of the day, that's what we pay based off. Getting 18MPG for short bursts doesn't accomplish much. I'm adding my year also since some claim the 05-06's get better MPG.
    Also, I don't believe your scangauge. Do the math at the pump.
    Location-East TN. Mix of hills and flat roads.
    What model truck? (RC/AC/DC) 2002 Access Cab
    2WD or 4WD? 4x4
    Tire and/or gearing different from stock? 285/75/17 BFG K02's
    Bed cap or cover? Cap-weighs roughly 150lbs
    Just for fun, what octane gas? poor mans 87
    Prior to moving to bigger tires I was getting around 15.5MPG with a mix of city and highway driving and lots of hills here in TN.
    I'm averaging around 14.5 now. Calculated at the pump after filling up. I stay around 65mph on the interstate.
    lsaami, TX-TRD1stGEN, bmf4069 and 3 others like this.
  4. Oct 4, 2019 at 5:34 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    Good idea for a thread to include the specs. I'd also recommend including the calculation methodology.
    Location/ altitude: Coastal South Carolina (generally less than 100 ft above sea level)
    What model truck? (RC/AC/DC): 2005 Double Cab
    2WD or 4WD: 4wd
    Tire and/or gearing different from stock: 275/70R17 (about 32x10.5) KO2s (E-Load) with factory 3.90 gears (I'm almost positive this is the only gear ratio for 05/05 DCs) on 4Runner alloys
    Height/Suspension Mods: Rancho Quicklifts in the front (+2.25") and Rancho 1.5" block in rear
    Bed cap or cover: None
    Just for fun, what octane gas: 87 (with an octane booster/fuel injector cleaner every now and then)
    Extra weight: Some hand tools, hitch ball, and straps, etc. (Probably less than 100lbs)
    Performance parts? K&N Drop-In Air Filter
    Avg mpg: 13.8-14.2 (Basically 14 no matter what)
    Driving Habits/ Notes: Mine is basically a fun truck/ weekend warrior...trips to the hardware store, hauling the kayak for fishing, taking the kiddo and family around town, dirt trails, trips to the dump, and road trips when hauling stuff, etc. Basic truck stuff, but not my daily so I don't tend to worry about mpgs too much. I do have a slightly heavy foot (and my kiddo likes to zoom!), and interstate travel around here is usually closer to 75 than 65. I don't use cruise control on the highway with larger hills...it's too aggressive on the downshift and it revs a lot if left on. Oh, and engine maintenance is pretty up to date in the last 10K (new plugs, new timing belt kit, and new drive belt and pulleys)
    MPG Methodology: I will get about 275-ish until the light comes on. But I highway verified I travel 108 miles when the odo reads 100. So I add 8 percent to my mileage total before dividing by gallons. As noted, it's always around 14 (except towing when I got 9mpg at max weight w/ o/d off over lots of hills).
  5. Oct 4, 2019 at 3:35 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    2002 Tundra 4.7 2wd
    Volant Intake
    JBA Short tube headers
    4.30 gears
    3 inch OME lift
    Wheels = 17x9
    Tires = 285 70 17 (sidewall also says 33x11.5)
    In town driving = at or close to the speed limit.
    Highway Driving (not much) = 70-75mph
    Mpg (tank average) = 13
    Oddly some 05-06 double cabs came with 3.62 gearso_O
    I’ll post the mpg for my 06 later.
    Darkness[OP] likes this.
  6. Oct 5, 2019 at 9:52 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
  7. Oct 5, 2019 at 3:09 PM
    Aerindel
    Aerindel New Member
    Montana
    4WD
    Access cab. No topper or cover. Stock sized tires.
    3500 feet.
    87 gas
    14.5 Average. Mostly highway at 70 MPH with 1/2 mile of what most people would call off road on every trip.
    Once I got 15.5 but that is unusual.
    Darkness[OP] and Filthyphil like this.
  8. Oct 5, 2019 at 5:07 PM
    Professional Hand Model
    Hand Protectors
    Always running as light as possible at sea level on 285/75/r16s
    City/Hwy mix = 12-15 MPG.
    Straight long trip HWY trips = 18-19 MPG.
    TOWING = 9-10 MPG.
    revtune and Darkness[OP] like this.
  9. Oct 6, 2019 at 8:44 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    2000 Tundra AC 4x4
    265/75/16
    No topper/cover
    85 octane
    mixed highway/city
    Avg: 16.2mpg
  10. Oct 6, 2019 at 8:49 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    That’s a sweet BLUE truck! :muscleflexing:
    Darkness[OP] and SC T100[QUOTED] like this.
  11. Oct 7, 2019 at 4:55 AM
    SC T100
    SC T100 New Member
    Thanks!
    Y0TA PR0[QUOTED] likes this.
  12. Oct 7, 2019 at 7:04 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    4.7/4WD/87octane/265's/drive moderately/2000ft elevation= 14.5mpg mix
  13. Oct 7, 2019 at 7:39 AM
    Casper421
    In the woods
    06 DC
    2006 DC
    4x4
    285/75r17 St Maxx
    87 or 91
    1600’ elevation
    Tonneau, bed rack and Tepui, two full swing cases and tool bags weighing around 350lbs. Full skids and sliders.
    14mpg average(90% highway)
    beretdra, Darkness[OP] and Y0TA PR0 like this.
  14. Oct 17, 2019 at 5:40 PM
    Hand Protectors
  15. Oct 17, 2019 at 7:45 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I think the 4x2 was only 1 mpg better. adding larger/heavier all terrain tires and a lift kit will knock those estimates down 2-3 mpg:oops:
  16. Oct 18, 2019 at 2:05 PM
    Hand Protectors
    Lots of idle time along with ‘spirited’ driving due to 2 SeaFoam Spray manifold cleanings and some towing yields 11MPG City this week.
    This coming week, I’ll granny the throttle and see what happens. My guess is 13.5 City (my usual city average).
    Weighed out the truck today and its sitting at 4790lbs with 1/2 tank o’gas.
  17. Oct 18, 2019 at 3:15 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Haven't been watching a number of things with my ride in last few years, so I filled up today after plugs replacement, MAF/Throttle body cleaning and entered my numbers in the Fuelly app. We'll see where I fare next fillup !
    Darkness[OP] and Black Wolf like this.
  18. Oct 19, 2019 at 9:43 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Location- gulf coast Texas (flat)
    What model truck? (RC/AC/DC) 2000 Access Cab
    2WD or 4WD? 4x4
    Tire and/or gearing different from stock? 285/75/17 nitto Terra grappler load E
    Bed cap or cover? None
    I'm averaging around 12.5 now. Calculated at the pump after filling up. This is commuting to work 5 miles each way (ac always on)Not highway driving. When I was highway driving I was getting closer to 17.
    300 miles since last fill-up.
  19. Oct 19, 2019 at 10:14 AM
    LGTruckWesternSlope
    LGTruckWesternSlope New Member
    2019 Super White Tundra Limited Double Cab TRD Off-Road 4x4
    What model truck? (RC/AC/DC) --- Double Cab
    2WD or 4WD? --- 4WD
    Tire and/or hearing different from stock? 18" Wheels Stock
    Bed cap or cover? -- NO
    Just for fun, what octane gas? -- 83 Lowest in Western Slope Colorado
    First three full tanks overall average 17.64 MPG Combined City/Hwy
    Elevation 5,800 - 9,000 ft., weekly mountain driving
    Light throttle, cruise control when possible. Very pleased to date.
  20. Oct 19, 2019 at 10:21 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Not bad for mostly stop and go short commutes. 285/75/17 is a true 33 inch tire.
  21. Oct 19, 2019 at 2:24 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Yup. And I didn't calculate for tire size in calculations.
  22. Oct 19, 2019 at 4:33 PM
    Hand Protectors
    For my 285/75/R16 I’ve assumed plus 8% on my MPG.
    You are probs around 13.5 city and 18.5 highway with the added %, which is about what I average.
  23. Oct 21, 2019 at 6:28 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Lol.
  24. Oct 22, 2019 at 3:57 AM
    Hand Protectors
  25. Oct 22, 2019 at 4:14 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm 100% stock and that was 75% highway.
  26. Oct 22, 2019 at 4:17 AM
    Hand Protectors
    Brutal. Increase tire pressure!
    bmf4069[QUOTED] likes this.
  27. Oct 22, 2019 at 4:33 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Will check and report back.
  28. Oct 22, 2019 at 5:51 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Haven't you stated you spend most of your time over 3500 RPM's? I don't think there is any mystery here. :D
  29. Oct 22, 2019 at 9:20 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    75mph+ on any v8 truck is gonna hurt mpg. On these trucks we’re pushing about 2300-2400 rpm at that speed with stock tires.
  30. Oct 22, 2019 at 1:08 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That's my shift point! And highway speeds are about 80. And 317k miles. Skid plates missing. Torn cv boot. Why is my mpg shitty!? :rofl:
    Filthyphil and TX-TRD1stGEN like this.
