Off road worthy spare
Discussion in 'Wheels & Tires' started by Noob Saibot, May 20, 2024.
  1. May 20, 2024 at 3:49 PM
    Noob Saibot
    Noob Saibot [OP] New Member
    Lehigh Valley, PA
    2008 5.7 Crewmax Ltd
    Hi guys
    As my name implies, although I've taken 1 cross country trip with my Tundra and I've had it almost 3 years, I still am a noob.
    I'm prepping for another trip this summer. Going out west. No crazy technical stuff but roads that have sharp rocks where you need all-terrain tires. I just bought 4 Toyo ATIII's to replace the worn out and not up to the job Michelins (fine for what I did last time pulling a camper and driving Forest Service roads, etc.)
    My question is would you get a 5th for "just in case" (the 4wd place I got the new tires at asked about it), will it fit under the truck (posts I searched up seem to suggest it will) and do I buy an OEM wheel to stick this 5th tire on (a cheaper one online considering it's "just in case" and going to live under the truck) OR do I use the steelie the spare is mounted on.
    Thanks this is a great place even though I mostly just lurk.
  2. May 20, 2024 at 3:55 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Food for thought; 2 spares let’s you keep wheeling, one just gets you home
    ATV25 and Elevatorguy like this.
  3. May 20, 2024 at 4:08 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    I would look for a used wheel on the face, list, or bay you might get lucky and find one with a decent tire for a just in case spare
    If you get a new tire I would still find a used wheel and plan on putting it in your rotation schedule
    FrenchToasty likes this.
  4. May 20, 2024 at 4:28 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    The tires and rating matter. I haven’t looked in a while but are those toyos 3 ply sidewalls? In the past very few tires (even e rated tires) had a 3 ply sidewall.
    e rated doesn’t mean what it did in the past. Old school e rated meant 10 ply thick on the tread. Most today are not more than 3 ply’s on the tread surface, much less on the sidewall.
  5. May 20, 2024 at 5:37 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    I always carry a plug or tire repair kit and a compressor plus a spare tire.
    My approach is usually look for an inexpensive used tire same size as my ither tires. If you run oversized tires and also need wheel to offset, just look for inexpensive one the correct size & offset you need. I found a wheel on clearance for 125 last year and reused an old spare Nitto i had laying around.
    ATV25 likes this.
  6. May 20, 2024 at 5:40 PM
    Totmacher
    Daniel
    West TN
    Some
    Will also add that i have been on a trail where guy ripped sidewall on 2 tires in same hole. He had to borrow someone elses spare plus his own. No repairing a sidewall.
    So if you are riding solo on trails to remote areas, 2 spare might be good idea. Can be worn tires. Just enough for you to baby it back to civilization for replacements is all you usually need.
    ATV25 likes this.
  7. May 20, 2024 at 6:14 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra SC'D AWD RCSB
    Supercharged All Wheel Drive Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Not sure what size Toyo's you purchased, but my 35" tire fits between the leafs without issue. Although a tight fit..
    Depending on your budget, it's nice to have an actual spare replacement in case an original wheel is damaged beyond repair or is hard to replace due to availability.
    Like others have said, have a tire repair kit handy and access to air. Enjoy the trip!
  8. May 20, 2024 at 6:24 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I bought a couple used TSS wheels (chrome, ew) and slapped a used 37" tire I got for $75 from a Mexican tire shop. It doubles as weight in my empty bed as I cannot fit it underneath.
