Off road vs stock tires
Discussion in 'Wheels & Tires' started by MARLEYMARL, Mar 22, 2019.
  1. Mar 22, 2019 at 2:36 PM
    MARLEYMARL
    MARLEYMARL [OP] New Member
    2018 Black Tundra SR5
    Is it normal for off road tires to transmit a bit of vibration through the steering wheel at speeds between 55~65mph? Off road wheels ride fine below 55mph and above 65mph. Original stock wheels had no vibration. Just curious. Riding 275/55/20 Nittos on Helo HE900 wheels. Balancing is fine. Again, just curious.
  2. Mar 22, 2019 at 2:41 PM
    15whtrd
    15whtrd Mr. Blonde
    It can be normal. Is it audible? Are your new wheels hubcentric?
    OR18TRD likes this.
  3. Mar 22, 2019 at 3:14 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    If the vibration only happens at specific speeds, that’s a balancing issue.
    joonbug and OR18TRD like this.
  4. Mar 22, 2019 at 3:24 PM
    MARLEYMARL
    Nitto Tera grappler...non lifted. Hmmm ..not really audible, more of a feel, steering wheel buffeting then settles at lower speeds. Otherwise, trucks feels stable.
  5. Mar 22, 2019 at 3:25 PM
    Danman34
    Danman34 New Member
    Danny
    Def a balancing issue. Are the wheels hubcentric?
  6. Mar 22, 2019 at 3:26 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Most likely a balance issue. I have 35x12.5x18 Ridge Grapplers on mine and they're smooth as butter at all speeds. Make sure the tire shop is doing a road force balance on them. If the shop doesn't have the machine to do that, take them somewhere else.
    YeeYeeTundra likes this.
  7. Mar 22, 2019 at 3:26 PM
    MARLEYMARL
    Hubcentric? Forgive my ignorance, but what does that mean?
  8. Mar 22, 2019 at 3:28 PM
    Danman34
    Danman34 New Member
    Danny
    Does the hub bore of the aftermarket wheels match the hub on the truck. If not, that’s your source of vibration and is also a major safety hazard and the number one reason aftermarket wheels sheer off the studs and you lose the wheel while driving.
  9. Mar 22, 2019 at 3:29 PM
    MARLEYMARL
    @Sas , what exactly is a road force balance? Hows that different from a regular balance?
  10. Mar 22, 2019 at 3:32 PM
    MARLEYMARL
    @Danman34 , Im pretty sure they do...but again forgive my ignorance, what exactly would I be seeing if they werent hubcentric?
  11. Mar 22, 2019 at 3:34 PM
    Sas
    OKC, OK
    A road force balancer uses a roller to put a load on the wheel and tire to simulate the weight of the vehicle being attached to it. A regular balancer just spins the wheel and tire w/o any load.
  12. Mar 22, 2019 at 3:35 PM
    Danman34
    Danman34 New Member
    Danny
    No gap between the wheel and the hub when you pull the center cap. The wheel should fit snug around your trucks hub.
  13. Mar 22, 2019 at 3:35 PM
    MARLEYMARL
    @Sas , oh ok...cool thanks.
  14. Mar 22, 2019 at 3:39 PM
    MARLEYMARL
    @Danman34 , hmm...I believe that they fit around trucks hub, but Ill have to visually verify as I cant recall from memory. Say if it turns out theyre not, can some sort of hubcentric spacer be utilized?
  15. Mar 22, 2019 at 3:40 PM
    Danman34
    Danman34 New Member
    Danny
    Yes. They make hubcentric rings to make up the difference. If you need them, just make sure you get metal.
  16. Mar 22, 2019 at 3:41 PM
    MARLEYMARL
    @Danman34 , so if I understand correctly, if not hubcentric, the wheels actually rest on the studs and the wheel doesn't properly shoulder the trucks weight?
    Sunnier likes this.
  17. Mar 22, 2019 at 3:42 PM
    Danman34
    Danman34 New Member
    Danny
    Correct. You want the weight on the hubs, not the studs. If it’s not hubcentric, then your studs are carrying the full load....and that’s not what they are designed to do.
  18. Mar 22, 2019 at 3:44 PM
    MARLEYMARL
    Danman34 likes this.
  19. Mar 22, 2019 at 3:47 PM
    Danman34
    Danman34 New Member
    Danny
    Very welcome. Your hub is 110 mm. Check the hub size of your wheel. It should be a tenth or so larger than that to fit over the hub and be hubcentric.
  20. Mar 22, 2019 at 3:54 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    What psi are you running in those tires? Terra grappler g2 is a great tire and is pretty tame as far as tread pattern and road manners. Like others have mentioned, road force them suckers:thumbsup:
  21. Mar 22, 2019 at 4:03 PM
    MARLEYMARL
    @revtune , should be around 40psi...max i believe is 50psi. The road noise is actually minimal, will look into that road force balance, as well as hubcentricity mentioned by Danman34.
  22. Mar 22, 2019 at 4:06 PM
    MARLEYMARL
    @Danman34 , are wheel hub sizes published? Stamped on the wheel perhaps? Or do i have to measure this myself, if so, how?
  23. Mar 22, 2019 at 4:17 PM
    Danman34
    Danman34 New Member
    Danny
    May be stamped on the back. If not check the manufacturer website and it should be listed there.
  24. Mar 22, 2019 at 11:11 PM
    MARLEYMARL
    Looks like my balancing was slightly off. Truck runs & feels like stock now . Thank you guys for all your advice & suggestions. Man, love this truck so far
    Sas and Sunnier like this.
  25. Mar 22, 2019 at 11:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Glad it smoothed up.
    Are your new tires e rated? If so that will cause you to feel a little more of the road. The stock tires have sidewalls made out of playdoh compared to legit LT tires
  26. Mar 23, 2019 at 4:31 AM
    Danman34
    Danman34 New Member
    Danny
    So it was just a balance issue? Good to hear.
    Still check to make sure those wheels are hubcentric though haha.
