Off road air bag jack
Discussion in 'General Tundra Discussion' started by bfd300, Jun 20, 2019.
  1. Jun 20, 2019 at 7:49 AM
    bfd300
    bfd300 [OP] New Member
    So I bought this a while back and never really played with it. Using the air compressor in the garage it lifted the whole side with no problems. Can use trucks exhaust also. I used a board under the frame. As you can see the bag did not inflate straight so I had to chock the wheels to keep it from going forward. I am impressed it lifted the whole side.
  2. Jun 20, 2019 at 8:05 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    How much $$$? Also how high is the max lift?
  3. Jun 20, 2019 at 8:13 AM
    That the Bushranger?
  4. Jun 20, 2019 at 8:18 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    That seems like the most dangerous way to lift a truck
  5. Jun 20, 2019 at 8:21 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Are you gonna try it with the truck’s exhaust? Reason I have doubts is because my friend Axel shoved a couple of bananas in some undercover cops’ tailpipe and the exhaust didn’t even have enough pressure to push out the bananas. Curious if it can lift a truck. And yes, that also looks unsafe.
  6. Jun 20, 2019 at 8:21 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    is that a true story?
  7. Jun 20, 2019 at 8:23 AM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    I don't think it's intended for repairs, more for a quick lift to get wheels out if the sand or something similar.
  8. Jun 20, 2019 at 8:25 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    in the sand, stuck on the trail, is exactly the time you want to lift in the safest way possible
    AZTundra and joonbug like this.
  9. Jun 20, 2019 at 8:26 AM
    bfd300
    I have used the exhaust yes it works. It tough to hold the hose cone over the tail pipe tho
    joonbug[QUOTED] likes this.
  10. Jun 20, 2019 at 8:26 AM
    bfd300
    Yea if your stuck. Quick lift
  11. Jun 20, 2019 at 8:28 AM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    Not disagreeing about the safety, but if you're just trying to break the tires out of the sand or whatever this will do the trick. Giving you enough time to throw some boards down or whatever.
    I would never lay under it.
    bfd300[OP] likes this.
  12. Jun 20, 2019 at 8:28 AM
    bfd300
    I paid $130 last year. 4 tons
  13. Jun 20, 2019 at 8:31 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
  14. Jun 20, 2019 at 8:33 AM
    bfd300
    Front view
  15. Jun 20, 2019 at 8:45 AM
    RowBee
    RowBee New Member
    Oklahoma
    2010 DC 4.6
    unless you have onboard air i doubt a person would have the capacity to fill that huge thing up. and i doubt the exhaust would have the psi to lift the truck. or the coupler would come off the tailpipe.
  16. Jun 20, 2019 at 8:48 AM
    Sounds good to me........
    osidepunker[QUOTED] likes this.
  17. Jun 20, 2019 at 9:10 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
  18. Jun 21, 2019 at 5:56 AM
    bfd300
    The exhaust does work but it’s a little hard to hold the hose cone to the tail pipe
  19. Jun 21, 2019 at 6:30 AM
    gladecreekwy
    J
    Jackson Wyoming
    Sorry, I mean how high will it lift? Wondering if it would get my tire off the ground
  20. Jun 21, 2019 at 6:47 AM
    bfd300
    2 feet
    gladecreekwy likes this.
  21. Jun 21, 2019 at 6:59 AM
    It was in a movie...Beverly Hills Cop.
