Oem Wheels 2000 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by RR60, Oct 12, 2021.
  1. Oct 12, 2021 at 7:47 AM
    RR60
    RR60 [OP] New Member
    2003 SR5 Tundra long bed
    Well have another post on wheels. Trying to find for a friend after he noticed my new ones on my 2003 Tundra. 1 st choice is go up to a 17" wheel from 16"
    And he likes the Split spoke oem 2006 wheels. But really any oem wheel besides the ones that looked like the hubcaps.
    Anyone know what OEM wheel will fit on a 2000 base model V6 Tundra.
    Gets confusing. Since I see wheels that state will fit a 2003 to 2006 then others 2000 to 2004.
    And thought I remember there was some difference with the 2000 vs my 2003 tundra.
    thanks
  2. Oct 12, 2021 at 7:51 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If the suspension is stock and tires are stock size then any will fit. You can even venture into Tacoma/4Runner/FJ wheels. As long as they are 6 lug they will fit.
    DaWhiteTundra and FirstGenVol like this.
  3. Oct 12, 2021 at 8:25 AM
    RR60
    Great. Think he wants the dark hyper color with a lighter color truck. He is older does not do anything online. So I will feel safe ordering for him.
    Also just to give him another option. The link below. Looks like a great deal. Do you happen to know if these fit with no problems.
    https://www.ebay.com/itm/324604670369
  4. Oct 12, 2021 at 11:04 AM
    DaWhiteTundra
    DaWhiteTundra New Member
    Anthonee
    Sacramento, Ca
    White 2002 sr5 v6 Rwd
    Lsd, 5100’s all around, lift springs, 1inch rear block, extra leaf, 13wl caliper swap, slotted drilled rotors, ss brake lines, 27mm sway bar, rear addco sway bar,
    yes
  5. Oct 13, 2021 at 3:04 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I would like to get some of these OEM Toyota wheels for my 05 DC to replace my Helo chrome wheels but my tires are 285/70/17 and per Nitto, the recommended wheel width is 7.5-9.5 inches and those are only 7 inches wide. Do yall see any issues with mounting those tires on a rim 1/2 inch narrower than the recommended size? Thanks
  6. Oct 13, 2021 at 9:44 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I mounted Mickey Thompson’s 35’s on these exact rims and never had a problem with the tire/rim relation. Keep in mind that OEM wheels generally have a more positive offset (tucks wheel in), while most aftermarket wheels generally have a more negative offset (pokes wheel out). So…. Switching from aftermarket to factory OEM wheels, you may notice rubbing where you had clearance before and need to add spacers. Just a heads up
    artsr2002[QUOTED] likes this.
  7. Oct 13, 2021 at 11:05 AM
    RR60
    This is a strange one. Not what I would like. But my older friend wants these for his 2000 Tundra V6. Chrome split spoke.
    https://www.ebay.com/itm/253138941098?epid=671624825
    So I assume they will fit. Look like other ones. I cant figure out why the center caps are raised and not like stock ones. Did these raised center caps come on any oem wheel?
  8. Oct 13, 2021 at 6:42 PM
    ToyoLife
    ToyoLife New Member
    06 DC Limited 4x4
    Check marketplace there is a member selling a set there.
  9. Oct 13, 2021 at 8:26 PM
    artsr2002
    'Yonder
    Yeah I figure there might be an issue regarding the back spacing.
  10. Oct 14, 2021 at 9:14 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Check craigslist and Facebook, tons of takeoffs for cheap. Lots of people buy new 4runners and Tacoma's and take the wheels off right away. With or without tires.
  11. Oct 14, 2021 at 11:35 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Yep. I just bought a set from a wheel shop that posts their takeoffs on FB. They were from a 2021 Tacoma and not a scratch on em. yet. They had tires mounted, which I didn’t want, so they removed them and dropped the price from $9 to $6. 3C1C910F-04FB-4361-AA71-F6AC2D91BFD4.jpg
  12. Oct 15, 2021 at 7:09 AM
    Zimm13
    Zimm13 New Member
    Zimm
    I have these from a 2006 Double cab 4wd limited…
    In Dana Point CA
