OEM Toyota Coolant
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dukhnt, Mar 12, 2023.
  1. Mar 12, 2023 at 2:45 PM
    Dukhnt
    Dukhnt [OP] New Member
    I keep finding different part numbers for OEM Coolat. Maybe they have pre mixed and non?
    Anywho, anyine know or have the part number for Toyota coolant? 2020 5.7 - pre-mixed would be nice.
    Thanks!
  2. Mar 12, 2023 at 3:57 PM
    737fixer
    737fixer New Member
    The correct P/N is 00272-SLLC2. This is the only correct fluid. There is no pre-mix available for any Toyota since I think around 2004. You're already on the right track by just sticking with OEM.
    bulldog93 and Dukhnt[OP] like this.
  3. Mar 12, 2023 at 4:12 PM
    Dukhnt
    Ty!
  4. Mar 12, 2023 at 4:15 PM
    Dukhnt
    chugs and WILLINH like this.
  5. Mar 12, 2023 at 4:39 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Henry1jg and WILLINH like this.
  6. Mar 12, 2023 at 8:42 PM
    Chip_Tundra
    Chip_Tundra New Member
    Pentosin Pentofrost A4 works with our cooling systems. Much cheaper than OEM SLLC.
    texasrho83 likes this.
  7. Mar 12, 2023 at 9:28 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Not the same stuff and is not rated for such long intervals, hence the red is "long life" and the pink is "super long life". How often are you changing coolant that you would notice the difference in price? There is one other correct option you can use, its part number is C0009-00120, its SLLC but 55/45 instead of 50/50. Its actually a Canadian "part" since it really would only be necessary in crazy cold temps. I'd stick with 00272-SLLC2 though.
  8. Mar 12, 2023 at 9:33 PM
    Joe333x
    Joe333x Member
    Boston
    CaptRussia253 likes this.
  9. Mar 14, 2023 at 6:23 AM
    Johnsonman
    Austin
    Sequoia
    Thanks for clarifying that for me, overlooked the 'super' part. Good info thanks.
    Joe333x[QUOTED] likes this.
  10. Mar 14, 2023 at 9:15 AM
    Rocko9999
    Rocko9999 New Member
    So the Red is not diluted, but the pink super LL is?
  11. Mar 14, 2023 at 9:20 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    That’s correct
    Rocko9999 likes this.
  12. Mar 14, 2023 at 10:27 PM
    737fixer
    737fixer New Member
    Toyota Red “Long Life Coolant”. From long, long, long time ago to 2003-04. 30,000 miles/3 years.
    Toyota Pink “Super Long Life Coolant”. 2003-04 until today. 100,000miles/5 years.
    Henry1jg, ekw_92 and chugs like this.
  13. Mar 14, 2023 at 11:22 PM
    Joe333x
    Joe333x Member
    Boston
    The only caveat is that they actually say to replace it at 120 months or 100,000 for the first change but then 60 months or 50,000 after that. So that being said I'm just going to do it at 50,000/5 years instead since theres gotta be a reason they dont want to to go past 50,000 after 100,000.
    From my 2019 owners manual
    Source:https://di-uploads-pod17.dealerinsp...fhomestead/uploads/2019/07/T-MMS-19Tundra.pdf
  14. Mar 15, 2023 at 12:59 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  15. Mar 15, 2023 at 1:19 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Any idea on how long these will "hold" for if the containers remain sealed and are stored in a garage???
  16. Mar 15, 2023 at 3:24 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Is this the same "they" that wrote 0W-20 on the oil fill cap?
    TTund16, JLS in WA, OHwendTrd and 2 others like this.
  17. Mar 15, 2023 at 4:27 AM
    737fixer
    737fixer New Member
    Sorry, my bad. Not sure why I wrote that.
  18. Mar 15, 2023 at 4:31 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    120 months or 100,000 miles, whichever your garage makes it to first?
  19. Mar 15, 2023 at 9:33 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    My 2019 will be 5 years in June, with 40,000 miles. I’m going to drain/fill the coolant this summer with the OEM pink stuff.
    Can someone share, how many of the OEM bottles do I need to purchase to complete the coolant service?
    WILLINH and Rocko9999 like this.
  20. Mar 15, 2023 at 9:44 AM
    Rocko9999
    Good question. I need to do this as well. 160k. Bought it at 156K. Not sure it was ever changed.
    georgiey22[QUOTED] likes this.
  21. Mar 15, 2023 at 11:28 AM
    Joe333x
    Joe333x Member
    Boston
    I believe it is 12.4 quarts, I bought 4 jugs. Have not done mine yet though.
  22. Mar 15, 2023 at 11:47 AM
    georgiey22
    My oil catch can is only 10 quarts, I’m going to need another to complete this job!
  23. Mar 15, 2023 at 12:25 PM
    Dukhnt
    Did you see what the shipping was?
    Tripleconpanna likes this.
  24. Mar 15, 2023 at 12:51 PM
    Tripleconpanna
    I just ordered some, and if you spend at least $75, shipping is free!!!!! So, I got a case for $109 shipped :thumbsup:
    Henry1jg and Joe333x like this.
  25. Mar 15, 2023 at 4:38 PM
    Joe333x
    Joe333x Member
    Boston
    Toyota has been offering free shipping over $75 for a long time now.
    Dukhnt[QUOTED][OP] likes this.
  26. Mar 15, 2023 at 4:41 PM
    Joe333x
    Joe333x Member
    Boston
    Could always drain the radiator first, then dump the fluid into a container. Then do the drains on the sides of the engine after, you can only do one engine drain at a time anyway unless you are using multiple pans.
  27. Mar 15, 2023 at 4:42 PM
    Tripleconpanna
  28. Mar 15, 2023 at 4:53 PM
    Joe333x
    Joe333x Member
    Boston
    I took pictures of the drain valves on the sides of the engine since they are hard to spot if you dont know what you're looking for. They are accessible through the wheel wells with some socket extensions.
    Leo's first, Dukhnt[OP] and chugs like this.
  29. Mar 15, 2023 at 5:23 PM
    ekw_92
    ekw_92 New Member
    Wisconsin
    2017 Super White Tundra 1794 TRD offroad CM
    2017 Tundra 1974 CM - Bilstein 6112/5100 1.9 with CB 2/1 shims. CB +2 shackles. 17x8.5 RRW wheels, 315/70/17
    If you do it every 50-60k you can just drain from the radiator and refill. This is how we do it. Ive yet to see SLL coolant go bad or not test good by 100k miles. Usually 2 gallons will do the job. If you want to take it a step further, then drain the block.
    Rocko9999, georgiey22 and chugs like this.
  30. Mar 15, 2023 at 9:20 PM
    Dukhnt
    No idea how I missed that huge red banner.
    Might be a good time to order the grille, too, if I can get over my fear of things not fitting and wasting 250 dollars.
