OEM Suspension Longevity
Discussion in '2.5 Gen Tundras (2014-2021)' started by GPJoeyD, Jul 15, 2021.
  1. Jul 15, 2021 at 9:17 AM
    GPJoeyD
    GPJoeyD [OP] Super Duper Cool Guy
    Joey D
    Middle Tennessee
    2015 SR5 TSS CrewMAX
    Hey Guys!!! So I'm lookin for some feedback. I have 130K on the clock on the my 2015 SR5 CM TSS. It still has stock suspension and I'm wondering how long do you think it'll hold up?
    I ask because I'm also do for Tires. I was considering getting a leveling kit to go with larger tires BUT, if there's not all the much life left in the stock suspension, I might as well go and get a 4" suspension lift 1st and then get me so bigger sneakers to put on it.... But if the suspension can easily go another 50K, then maybe just a level and lift it next time I need tires...
    What say you????
    Here's a pic since I just detailed it and it looks good :)
    panicman, ColoradoTJ and Fotnot like this.
  2. Jul 15, 2021 at 9:18 AM
    Taco-Spike
    Two Trucks
    Should be fine for a long while unless repetitive excessive speed bumps and off roading over years and years
  3. Jul 15, 2021 at 9:42 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I would not put a spacer lift on a 100+k mile suspension. In my experience the factory shocks start degrading around 60-80k miles, less depending on usage. So at the least with 130k on the clock you would benefit from new shocks, certain of that unless they have already been replaced. And if you are replacing shocks, may as well do a coilover with the lift you want.
    ejes, Oey12, 2mchfun and 1 other person like this.
  4. Jul 15, 2021 at 10:12 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    depends which shocks you have, the black one is junk, the yellow is an OK junk, red one is marketing junk, only the fox is good.
    SouthWestGA, 2mchfun and GPJoeyD[OP] like this.
  5. Jul 15, 2021 at 11:33 AM
    GPJoeyD
    Joey D
    Middle Tennessee
    Naaaa... I Work from home (Computer programer) and it's used 99% as a secondary vehicle... and it's mostly on-road... even when I do get off road, it's mostly groomed trails. I do pull a trailer about 5 times a year, but it's only loaded with a couple of Motorcycles, nothing crazy.
    Taco-Spike[QUOTED] likes this.
  6. Jul 15, 2021 at 1:28 PM
    2mchfun
    130k, shocks are done, ball joints are also starting to become a concern. I'd be getting busy on suspension upgrades. Only problem, right now there is a whole bunch of shortages, so make sure you have everything before you start. Do lots of homework and remember the small details like rear brake line relocate kit, front bump stop extensions, sway bar drop kit, diff drop kit, Carrier bearing drop, etc. Since you also tow and discuss a 4" lift I would also use traction bars to control axle wrap under the load in order to preserve pinion angle and u joints.
    GPJoeyD[OP] likes this.
  7. Jul 15, 2021 at 2:54 PM
    nopsFU
    nopsFU New Member
    2019 Tundra TRD Pro
    I was in the same boat three years ago (with a different truck). I bought new tires before finding out an axle seal had started leaking and a front coil spring broke at the bottom mount.
    My two cents: take 20 minutes and have a really good look underneath. Inspect each corner thoroughly, look for leaks or anything out of the ordinary. Next one is weird but tape measure your tire-to-wheel-arch gap for each corner. Make sure the fronts match each other, same for the rear. Had I known the amount of work I would have made a different plan.
  8. Jul 15, 2021 at 4:02 PM
    The Fox shocks weren't available on in the OP's model year, and they don't have a Pro.
  9. Jul 15, 2021 at 4:17 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    If you're just looking for an excuse to upgrade, look no further. You absolutely need to fully replace your suspension, it is dangerous to drive it one more mile on that stock suspension.
    You're welcome.
    argtexas, panicman and GPJoeyD[OP] like this.
  10. Jul 15, 2021 at 4:45 PM
    GPJoeyD
    Joey D
    Middle Tennessee
    There's What I'm Looking For!!!!!!!!!!!!!
    :woot: :yes: :cheers:
