OEM Rotors and Pads
Discussion in '2.5 Gen Tundras (2014-2021)' started by pvn.beluga, Sep 12, 2021.
  1. Sep 12, 2021 at 9:37 PM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Recently driving, I’m noticing that when I’m braking that the steering wheels starts vibrating a bit.
    Seems to happen more so when slowing down on a decline.
    I’m wondering when you guys changed out your OEM rotors and pads and what brands you guys went with that would be comparable or even better than OEM rotors/pads?
  2. Sep 13, 2021 at 2:19 AM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    Unless you have 60k miles or more it should be warranty issue?
    Or its tire balance issues, oem should be top notch although when comparing my 20 Tundra with my 20F150, the best brake feel and response goes to the ford hands down.
    pvn.beluga[OP] and FrenchToasty like this.
  3. Sep 13, 2021 at 4:56 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    OE rotors are good stuff. Either that or spring for some cryos. EBC yellow stuff or Hawk LTS pads make for a nice upgrade. Make sure you’re torquing your wheels to spec as well.
    pvn.beluga[OP] likes this.
  4. Sep 13, 2021 at 7:02 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Almost 30K on my 2020 and my front rotors are warped. I can feel them pulsating when braking.
  5. Sep 13, 2021 at 7:24 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I’m barely reaching 20k and that was what I was feeling too.
  6. Sep 13, 2021 at 7:30 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Yeah I've been feeling it for a while too. Just haven't got to the point to replace.
    IIRC, there's been some posts on here regarding early warping of OEM rotors.
  7. Sep 13, 2021 at 7:30 AM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    I had the same issue at 28k…. I replaced my rotors and brake pads. I wasn’t going to go through the hassle with the dealership on it. Since I replaced them I have no issues.
  8. Sep 13, 2021 at 7:32 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I doubt the dealership would touch it anyway under warranty. They're wearable items.
    Black Wolf and AZBoatHauler like this.
  9. Sep 13, 2021 at 8:14 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    You want to know why that happens? If rotors that are hot are cooled down too fast, BINGO..
    Iron is not too bad with this but SS units are notorious for it.
    Drilled n slotted are sensitive to it also.
    Think if you are washing your truck after a lot of towing or heavy braking on a continuous basis.
  10. Sep 13, 2021 at 8:18 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Makes plenty of sense. But with normal driving though?
    For me as example, I have normal driving habits. 50/50 city highway mix. No steep grades on a normal basis and occasionally towing a 350lbs boat trailer with a 100 boat lol
  11. Sep 13, 2021 at 8:21 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    My truck just hit 15k, no pulsating at all. Just rotated tires yesterday, rotors are nice and smooth.
  12. Sep 13, 2021 at 10:38 PM
    HONEYBADGER
    HONEYBADGER New Member
    Fox Coils Camburk Kinetik Uppers Stealth Customs Cooper AT3
    2019 with 41k, mine are as bumpy as Rosy Odonnel. Have to replace them soon.
  13. Sep 13, 2021 at 11:32 PM
    Blue By U
    Blue By U New Member
    Like all brakes if you drive them hard and just park them they will warp the rotor because the pads will cool at a different rate causing the rotor to warp. That's why they call it a cool down lap. I always use sintered pads (full metal) and the will wear the rotor down. Breaking is positive and will handle heat better. My rule is the third pad change needs new rotors. Stay away from stainless, it's a weak metal.
  14. Sep 14, 2021 at 2:44 AM
    AZBoatHauler
    So.Arizona
    I tow 6k lbs through 8% grades frequently. Stock front pads lasted 60k and had 20% left. Still on stock rear pads and all four rotors. You guys should have learned to drive on a ‘68 Jeepster with no power brakes and drums on all 4 corners…
    :anonymous:
    Mike59 likes this.
  15. Sep 14, 2021 at 5:08 AM
    Saab95v6
    Saab95v6 New Member
    Mine is a 2020 with just passed 10k , have been feeling the vibration sometimes, I was considering changing rotors and pads .
  16. Sep 14, 2021 at 5:41 AM
    StopTech cryo treated, slotted only rotors. I got mine through someone here who used to work for a company that sold them. :D
  17. Sep 14, 2021 at 7:17 AM
    This is the way
    This is the way New Member
    Rthur
    i am also getting the vibrations when braking at 50k miles.. i guess will have to replace em..
  18. Sep 14, 2021 at 7:28 AM
    Nowhereman
    Al
    Monterey Bay area
    Why? you might as well poke a stick in your eye. lol
  19. Sep 14, 2021 at 7:32 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Unfortunately, brake shimmy/vibration is common with Tundras.
  20. Sep 14, 2021 at 7:35 AM
    Nowhereman
    Al
    Monterey Bay area
    Major cause of that is wheel balance and warped rotors.
    Their suspension joints are first class. Also, how many experiencing this phenomena are running very very large wheel tire combo setups?
  21. Sep 14, 2021 at 9:29 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    It's my experience that warped rotors is an all to common problem with most manufactures front brakes. Of course proper wheel nut torque is important.
    I'm at 8900 miles and no noticeable braking issues, hopping things stay that way for another 50,000.
