OEM jack with 34" tires?
Discussion in 'Recovery & Gear' started by Stig, Jun 5, 2020.
  1. Jun 5, 2020 at 8:33 AM
    Stig
    Stig [OP] New Member
    Just got new tires. 295/70-18 and about 2.2" lift in front and 1" back.
    How much extension does the OEM jack give for on road tire changes?
    I've been meaning to check this physically myself but need to remove a baby seat. I need to relocate the jack because of that anyways but if it's already too short of just look into other options.
    For now I have a block of wood in the bed just in case
    So, does the OEM jack lift high enough to change out up to 34" tires?
    equin likes this.
  2. Jun 5, 2020 at 8:44 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I had a 2015 SR5 with a lift/level and oversized tires (can't remember the size) and it pushed the limits of the jack and what I was comfortable using. I ended up keeping some of the leveling pads I used for my travel trailer in the cab under the rear seat.
  3. Jun 5, 2020 at 8:47 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I dont think it'll have enough reach, unfortunately.
    I changed 275/70/18s (no lift) with my oem jack and it was maxed out completely.
    After I lifted it, I grabbed a harbor freight bottle jack and kept some 2x6s in the bed. I got tired of the wood sliding around and bought a hi lift not too long ago.
  4. Jun 5, 2020 at 9:18 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I measured this the other day, max height is 19.25".
  5. Jun 5, 2020 at 9:23 AM
    RobertD
    Robert
    DFW, Texas
    How do you like your high lift? I've never used one but I've been curious and tempted to get one
  6. Jun 5, 2020 at 9:28 AM
    I would carry a 6” long 2x6 in the bed.
    Smart to think of these possible issues before you have a flat.
    Squatting Pigeon likes this.
  7. Jun 5, 2020 at 9:34 AM
    Had a 6" lifted Tun with 35' , I cut 2x10x10 screwed 4 of them together, OEM Jack sits about inch away from rear axle, and a bit tight on front end
  8. Jun 5, 2020 at 9:42 AM
    Squatting Pigeon
    Holden
    North Texas
    I havent needed to use it yet, so I dont quite have an opinion. I've seen them in action, and for the money they sure do get the job done!
  9. Jun 5, 2020 at 10:30 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I keep a plastic "milk carton" in the bed that has various 2x6's 1x4's, etc. in it. Than I got a 3 ton bottle jack and put it in the back. My theory? If I have to pull off to the side of the road and the diagnosis is that a wheel has to come off then I'm already gonna be pissed (and I live in the deep south where most of the year it's hot as hell). So I want a quick and easy Fo Sho solution.
  10. Jun 5, 2020 at 4:15 PM
    Stig
    I haven't look into aftermarket bottle Jack's yet. But is it better to buy a new one with enough reach or keep OEM and just use blocks?
    I just remembered I have some of those levelinm blocks for RVs that I could use. Maybe that's my best solution.
  11. Jun 5, 2020 at 5:28 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I had a similar question in this thread:
    https://www.tundras.com/threads/jacks-for-off-road-tire-changing.67275/
  12. Jan 6, 2022 at 3:44 PM
    OGT242
    OGT242 Always know if the juice is worth the squeeze
    Oscar
    Marana, AZ
    2016 Tundra TRD Pro Quicksand CrewMax
    I have a 3 to 1 Kings lift with 35x12.5R17 and was able to use the OEM jack to lift my rear driver tire off the ground to change. I used the rear axle, close to the tire, to lift up the rear driver tire off the ground. I maxed out the jack and was able to have about 1 to 1.5cm of clearance. Not going to lie, the OEM jack scares me with that small area of contact that it has. I will be getting a bottle jack with an axle cradle attachment in the future.
  13. Jan 6, 2022 at 5:02 PM
    biebs96
    PA
    I have 285/75/18s (35” tall) with a 1” rear lift and 2” front lift.
    I can safely remove the rear tires using the stock jack on level ground. For the front I have 2 square cut pieces of 5/4 decking screwed together that I place under the stock jack.
    I store the block of wood inside my spare tire which is flipped upside down underneath the truck.
    D4x4TRD and Tundra234 like this.
  14. Jan 6, 2022 at 5:11 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Get a Hi-Jack Extreme. My truck was beyond the limits of any OEM jack (37" Tires, 3"lift) and I have N-Fab Rock Rails, which provide multiple jack points. It's about the only setup I can use, but I've been happy with the Hi-Lift. Very well built and the lift capacity is awesome. :thumbsup:
  15. Jan 6, 2022 at 5:16 PM
    I'm wondering about something like this...
    https://www.summitracing.com/parts/...AHUQOYB9BqmMAoXKHHz_6xo9qKoerZFkaAk5bEALw_wcB
  16. Jan 6, 2022 at 5:19 PM
    biebs96
    PA
  17. Jan 6, 2022 at 5:23 PM
    Plenty of room in my bed...not an issue for me :thumbsup:
  18. Jan 6, 2022 at 5:26 PM
    biebs96
    PA
    I’ll stick with my blocks of wood for now.
  19. May 2, 2022 at 2:51 PM
    2017_Tundra_AZ
    2017_Tundra_AZ New Member
    I have the same set up and my OEM barely works also. I'll be upgrading eventually to Pro Eagle or something.
  20. May 2, 2022 at 3:59 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    I use a block of 4x6 wood with the oem jack. I have 2” up front and 1” in the back. I’m only on 33” tires at that.
  21. May 2, 2022 at 4:49 PM
    Sunnier
    Sunny
    San Diego, CA
    Trailer Supply Co. has a 3 ton bottle Jack for cheap that works well and can lift 35”. I vote for one of those. Never hurts to carry a block too though.
    grave likes this.
  22. May 2, 2022 at 6:33 PM
    2017_Tundra_AZ
    Yea, that is a good solution. Those Pro Eagles are so expensive it's just not worth it almost.
  23. May 2, 2022 at 7:42 PM
    What is everyone using as a jacking point? If it’s the rear axle or front knuckle, then only the tire diameter affects the reach.
  24. May 2, 2022 at 8:22 PM
    2017_Tundra_AZ
    Exactly, I am using those jacking points... not the frame or anything else
  25. May 2, 2022 at 8:52 PM
    What the!?
    What the!? New Member
    2017 Pro
    Get a 6 ton bottle jack. It’ll fit right behind the rear passenger seat.
    if you prefer to use a jack, get a harbor freight jack and get the Pro Eagle extension to use on it.
  26. May 3, 2022 at 9:50 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    FWIW I recently jacked up the front of my truck several times with the OEM scew jack, and it has plenty of travel for 37s. Used a 3/4" plywood base (I was on gravel), and on top a piece of aluminum plate, 3/4" ply, foam... under the frame cross member.
    equin likes this.
