Oem diy painted matte dark bronze
Discussion in 'Wheels & Tires' started by Brocksw, Jun 29, 2019.
  1. Jun 29, 2019 at 5:38 PM
    Brocksw
    Brocksw [OP] New Member
    Spruce Mica 2012 SR5 Off-road DC
    Elka 2.5 reservoir front(+3") and rear, JBA UCAs, toytec +1.5" shackle, Falken Wildpeak 285/75r18.
    Anyone painted the gen 3 TRD offroad wheels a matte dark bronze similar to the SCS color?
    Posts pics please if you have... Along with paint color used.
    Thanks
  2. Jun 29, 2019 at 5:46 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I plasti dipped mine a color called brass monkey. Then wanted a more bronze or gold look to them so I went and added some gold pearl and gold metalizer dip on top of that. I don't mind the gold, I think I liked the brass monkey color better though but would like something in between the two, a true dark bronze.
    JoshuaA, Berdine and Brocksw[OP] like this.
  3. Jun 29, 2019 at 6:23 PM
    Brocksw
    Color desired for reference.
    Pudge likes this.
  4. Jun 29, 2019 at 6:31 PM
    Pudge
    CT
    I like that color alot. I bet you could get them painted or powder coated that color. Maybe even a set of vinyl overlays to covered the machines faces to test itout, the vinyl can last years on the wheel faces, Bronze and black would look good.
  5. Jun 29, 2019 at 8:04 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    51480B92-D981-4FCA-92A0-0699F5AF8654.jpg Color desired for reference. Good luck. D
    Pudge likes this.
  6. Jun 30, 2019 at 9:38 AM
    Spaceiscool
    Spaceiscool Something something.. danger zone?
    JL
    Ontario
    2008 White Tundra CM TRD
    Spray painted rims
    Just painted my OEM stock alloys. Went with Rustoleums Metallic Carbon Mist. Its a dark gray/bronze colour. Really impressed with how well it sprayed and bonded. When i go to do my winters im planning to use the same paint but a more true bronze colour.
    snarkscarbine, myt1, sf319 and 3 others like this.
  7. Jun 30, 2019 at 9:43 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Nice! What kind of prep work was required?
  8. Jun 30, 2019 at 9:55 AM
    Spaceiscool
    JL
    Ontario
    Spray painted rims
    The plastic clear coat was bubbling so i used my Dewalt orbital sander with diablo's 80 grit sand paper to smooth it down to the metal. Then used a wire brush for the nooks and crannies. Quick 600 grit hand sand followed by soap and water wipe down. About 45 minutes for each wheel including the center caps. Did the old deck of cards trick to stop over spray. Hit each rim with 5-6 coats 10 minutes apart.
  9. Jun 30, 2019 at 11:10 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Those wheels look beautiful.
    Rex Kramer and Pudge like this.
  10. Jun 30, 2019 at 3:50 PM
    Pudge
    CT
    Agreed. I'd definitely consider painting mine thos color
    Rex Kramer likes this.
