OEM diff fluid?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kingranch, Mar 28, 2023.
  1. Mar 28, 2023 at 12:56 PM
    kingranch
    kingranch [OP] New Member
    Looking to swap the fluids out. I am a former seadoo tech and have always been a big fan of OEM parts. That being said its time to change out the fluids on my front and rear diff on the 2014 tundra. I see 75wt being the gear oil spec.... 75/85 and also 75/140?
    Do these come with LSD additive?
    anyone have the part numbers and capacities?
    Thx!
  2. Mar 28, 2023 at 1:00 PM
    kingranch
    Look at that.
    Much appreciated ryan!
    ryanwgregg likes this.
  3. Mar 28, 2023 at 1:09 PM
    kingranch
  4. Mar 28, 2023 at 3:40 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    No need for "LSD additive" since the 2.5 gen Tundras don't have a traditional limited slip differential.
    TTund16 and FrenchToasty like this.
  5. Mar 28, 2023 at 3:52 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
  6. Mar 28, 2023 at 3:59 PM
    txtundra311
    txtundra311 New Member
    While it’s expensive, i recently had both diff and trsfr case done with toyota oem oil and noticed a 2mpg uptick. I also had air filter replaced, trans drain & fill, and added one bottle of lucas fuel system cleaner for a fair evaluation of everything done.
    norma30a likes this.
  7. Mar 28, 2023 at 5:19 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    The dealers I spoke with about changing the front, rear and differential and transfer case they all said they use 75-90 unless it a warranty repair. I changed all of mine with 75-90 synthetic. I have had no problems going into or out of 4 wheel drive.
    equin likes this.
  8. Mar 28, 2023 at 6:26 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    If it must be OE, then 08885-02506, which is 75W-85 Differential Gear Oil LT.
    The LT gear oil is a little more reasonably priced at $33 per liter at my local dealer, as opposed to the LX gear oil which is much higher. It is used for limited slip differentials.
    If your 2014 is 4x4, be prepared for sticker shock when you ask about the Toyota Genuine Transfer Gear Oil LF at the dealer.
  9. Mar 28, 2023 at 6:52 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    75w90 from Walmart in front and rear. Only one you need OEM for is the 75w transfer case.
    equin likes this.
  10. Mar 28, 2023 at 6:58 PM
    Joe333x
    Joe333x Member
    Boston
    Did you supply them with the oil? Every dealer i have seen just uses bulk 75w90.
  11. Mar 28, 2023 at 8:39 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    You might check out this link for a complete diff/transfer case fluid replacement using Ravenol. Much cheaper than OEM (especially the TC oil) and meets Toy specs. While I haven't done this yet (I'm barely at 30K) I will use Ravenol when the time comes. I'm just not looking forward to having to remove my cat plates to do it.
    Tigereye likes this.
  12. Mar 28, 2023 at 9:53 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I did it at my buddies shop.
    Joe333x[QUOTED] likes this.
  13. Mar 29, 2023 at 2:26 PM
    kingranch
    My specs list from toyota website... i think it does have lsd or is the the auto trac
  14. Mar 29, 2023 at 2:29 PM
    Joe333x
    Joe333x Member
    Boston
    Theres no LSD. Its automated by using the brakes.
  15. Jul 2, 2025 at 12:09 PM
    DMBfan
    DMBfan 2015 Tundra SR5 CrewMax
  16. Jul 2, 2025 at 12:31 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Any of those should be fine. Just make sure you get the right one for the transfer case. Not sure if Amsoil offers a compatible fluid for that.
    Y'all are making this too complicated. For a 2014+ Tundra:
    These trucks have plain old differentials in them, so anything is fine. You could go heavier if you tow a lot or whatever.
    Front Diff: Any Flavor/brand GL5 in 75W85 or 75W90
    Rear Diff: Any Flavor/brand GL5 in 75W85 or 75W90
    Transfer case is a special fluid so selection is limited. Personally I stick with the Toyota stuff here.
    Toyota 08885-81080
    Ravenol MTF-3
    Red Line MT-LV 70W/75W GL-4
    Liqui Moly Top Tec MTF 5100 SAE 75W
  17. Jul 2, 2025 at 1:02 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    From Toyota to one of our members.
    Tunrod likes this.
  18. Jul 2, 2025 at 3:15 PM
    Joe333x
    Joe333x Member
    Boston
    Yeah if you live in a warm climate, probably going to be okay but the 75w is much thinner than 75w90. Forums members have reported poor shifts in and out of 4wd when they used 75w90. Also the Toyota brand engagement probably is not super educated on the matter, BorgWarner is the one who came up with the spec for their transfer case from what I understand, I believe a forum member contacted them as well.
  19. Jul 2, 2025 at 3:46 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I have no problem with going in and out of 4WD,I used synthetic 75-90 in transfer and differentials.
  20. Jul 2, 2025 at 3:56 PM
    DMBfan
    Dang! You guys are on point! Its greatly appreciated. I will pick k up Amsoil/Liqui Molly or Ravenol ASAP. I have 120k miles without changing diff/transfer fluids. That includes towing a 30ft Toyhauler across country.
    WILLINH likes this.
  21. Jul 2, 2025 at 4:00 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Amsoil Severe Gear 75w-90 is $33 / quart. Order 6 of those and you're good. I have a case in the garage about to do my 60k oci.
    What OCI, brands, and weight I've been using:
    Oil & Filter: 5k miles or 6mo. -- Pennzoil Ultra Platinum 5w-30
    Transmission Fluid (drain/fill): 30k or 6yrs. -- OE Toyota Brand.
    Coolant: 50k miles or 5yrs. -- OE Toyota Brand.
    F/R Differential: 30k (OE or aftermarket). -- 75w-90 Amsoil Severe Gear
    Transfer Case: 30k (OE or aftermarket) -- 75w Ravenoil
    Power Steering Fluid (OE or aftermarket Fluid) -- OE Toyota Brand.
    Brake Fluid DOT 3, inspect at 3 years (aftermarket)
    Sparks Plugs: 120k (OE)
  22. Jul 2, 2025 at 4:02 PM
    Joe333x
    Joe333x Member
    Boston
    That's good to know. I know most dealers just pump 75w90 in the transfer case as well. I did a bunch of research on the forum before I changed mine and since it's a seldomly changed fluid, I do mine every 30,000, I figured I'd stick with the 75w from Toyota. Shifts smooth as butter in and out and want to keep it that way, especially in the winter when I need it most.
    WILLINH[QUOTED] likes this.
  23. Jul 2, 2025 at 4:03 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Ravenol 75w is a good substitute for OEM.
    DZ_ likes this.
  24. Jul 2, 2025 at 4:07 PM
    Joe333x
    Joe333x Member
    Boston
    Yes many here use that as well. I go down rabbit holes and found a VOA of the Toyota vs the Ravenol and they are very different fluids, not that that means one works better than the other but it's seems so far no one really matches the VOA of the Toyota stuff.
    WILLINH likes this.
  25. Jul 2, 2025 at 4:14 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Ah, makes sense and perhaps some truth behind it. Those type of rabbit holes can be a good time. I've seen no known issues on and a lot of others use it here, as you said, and no issues reported out that I've seen. I got most of my advice from CCN youtube and jotted down his recommendations, seemed reasonable enough to follow. Only items he recommended to remain Toyota OE brand; Transmission Fluid, Coolant, Power Steering Fluid. Been sticking to that.
  26. Jul 2, 2025 at 4:42 PM
    Joe333x
    Joe333x Member
    Boston
    Haha yeah people think oil threads here are bad, jump on bitog lol people really get into it there
  27. Jul 2, 2025 at 4:48 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :thumbsup: In the camp of never going to turn down learning something new.
  28. Jul 4, 2025 at 6:03 AM
    Bham TRD
    Bham TRD New Member
    Birmingham, AL
    2017 Tundra Platinum 4WD CrewMax
    Hate I missed that video.
    Used Prestone Platinum Asian coolant & Valvoline MaxLife for power steering fluid.
    I did however use Toyota WS for the tranny.
    Too late now…
  29. Jul 4, 2025 at 7:36 AM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining Cooper Discoverer ATP II LT275/70R18 TRD Pro dual exhaust with TRD exhaust tips Lund 5" Cab Length Oval Curved Tube Steps RealTruck TruXedo Pro X15 Tonneau Cover RealTruck Elevate FS Bed Rack Rhino-Rack Carriers Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
  30. Jul 6, 2025 at 11:18 AM
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    Ravenol on sale at Blauparts through 7-7-25.
    10% off $100 orders.
    https://www.blauparts.com/toyota-tundra-transfer-case-differential-fluid-change-kit.html
    WILLINH likes this.
