OEM Bed Step?
Discussion in '3rd Gen Tundras (2022+)' started by geewizard, Dec 16, 2022.
  1. Dec 16, 2022 at 3:00 PM
    geewizard
    geewizard [OP] New Member
    E Washington/N Idaho
    2023 1794 TRD OR
    So.....how many of you have the OEM bed step? How high off the ground is it when down?
    Is it really worth it?
  2. Dec 16, 2022 at 3:28 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    I have it. It's about 12" off the ground when it's down. It's worth every penny in my book. Guess it just depends how nimble you are.
    22PlatWCP likes this.
  3. Dec 16, 2022 at 3:29 PM
    firehawk003
    firehawk003 New Member
    I have one and not really a fan. By the time I bend over and pull it out/down, I could just pull myself up into the truck. If it was the auto version I would probably use it more.
  4. Dec 16, 2022 at 3:34 PM
    4genRunner
    Southwestern MO
    You know you can just push it down with your foot, right? You don't have to bend over and pull it down.
    Dhust27, Unitdosed, Jongie123 and 3 others like this.
  5. Dec 16, 2022 at 4:02 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    I don't bend down, I kick it out with my foot. I believe is it's too low to the ground, 12" off the ground but 24" top of step to top of tailgate when open. Should of been designed to be a little closer to half way between ground and open tailgate. Like 18", right in the middle.
    Unitdosed and Jongie123 like this.
  6. Dec 16, 2022 at 4:11 PM
    firehawk003
    mine does not do that. Maybe it was installed incorrectly at the port. You have to move it out a bit before it will go down. Maybe I need to check underneath to see what they did.
    RickyBobbysTundra and Sean492 like this.
  7. Dec 16, 2022 at 4:22 PM
    R2theD2
    R2theD2 New Member
    Seattle
    2022 Tundra 1794 TRD Off-Road Lifted - Midnight Black
    TRD Lift Kit TRD Skid Plate TRD Running Boards Nitto Ridge Grapplers (35x12.5) OEM Bed Step OEM Toyota Tonneau Cover (Quad-Fold) 3M Window Tint (matched factory rear) Spray-On Bedliner
    Unlike other accessories or mods, I would say that the bedstep is a need, not a want. It works very well for me - simple - there when you need it and not when you don't. And yeah, you just push it down with you foot (not your hand silly).
  8. Dec 16, 2022 at 4:25 PM
    4genRunner
    Southwestern MO
    Are you trying to "pull" it down with your foot, i.e. standing facing the front of the truck and trying to "pull" the step towards you? You need to "push" it away from you and down from the back of the step. You should be able to just push the back of the step towards the rear of the truck and it will go out and down.
    Not sure what they could have done to keep it from going out correctly, it's a pretty simple armature.
  9. Dec 16, 2022 at 4:55 PM
    geewizard
    2023 1794 TRD OR
    $525 installed at my dealer. Ouch.
    RickyBobbysTundra likes this.
  10. Dec 16, 2022 at 5:56 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Bbgunasassin likes this.
  11. Dec 16, 2022 at 6:34 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Install it yourself. Easy diy.
  12. Dec 16, 2022 at 6:40 PM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    My build sheet for my allocated truck even states that it's "hands free" operation. I am curious to see what the issue is.
  13. Dec 16, 2022 at 7:25 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Why doesn’t Toyota notch a step into the bumper ends like Chevy?
  14. Dec 16, 2022 at 7:32 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Because there is a sensor in the corners, I believe it is Cross Traffic Detection...
  15. Dec 16, 2022 at 8:42 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I wish they did, it also should have come on every truck. It’s needed
    Beach Toy likes this.
  16. Dec 16, 2022 at 8:55 PM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    yes
  17. Dec 17, 2022 at 2:34 AM
    wing-2
    wing-2 New Member
    I've had my truck for six weeks now, and have been considering it. I am probably going to pass. Like many people, I live in an area where we insist on spending our tax dollars on applying corrosive materials to the roadways to deteriorate our expensive vehicles. When I consider the cost of the step, the fact that it is in a likely spot to collect the aforementioned corrosives, and the amount of times my fat old ass actually has to climb in the bed, particularly now with the cap added, I will pass. It can certainly be added any time if there is a need. I keep a 1970's Fisher snow plow hook in my trucks for retrieving out of reach things in the bed. :):cool:
  18. Dec 17, 2022 at 5:31 AM
    4genRunner
    Southwestern MO
    Except it’s out of stock and to the best of my knowledge has been for many months. I waited months for it to become available and it never did.
    Wound up getting the OEM step for slightly cheaper from https://parts.toyota.com. Part number is PTS3034000. Search around on that site. Each dealership you click on to buy it from will have a different price. I got it for just under $290 shipped from Toyota of Topeka.
    mayan and wing-2 like this.
  19. Dec 17, 2022 at 7:35 AM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    I used the bed step in the tailgate of my old rig all the time, I ask myself why I didn’t get this option for my Tundra
  20. Dec 17, 2022 at 10:29 AM
    Tb2
    Tb2 New Member
    James
    I have it use my foot to deploy and retract it too low . Getting up and in is fine but getting down it’s a bit of a reach to the step . I would buy again because not a better solution at this point
  21. Dec 17, 2022 at 10:42 AM
    lrtexasman
    lrtexasman New Member
    Larry
    Rockwall, Texas
    2023 Tundra Crew Limited 4x4
    I have it and love. I use it everyday. Takes a minute to learn how to push it down (right big toe on inside corner). The paint protection film is also worth it.
  22. Dec 17, 2022 at 1:06 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    GMC has a patent on it, so no one else can use it
    Dhust27 likes this.
  23. Dec 17, 2022 at 1:49 PM
    lrtexasman
    Larry
    Rockwall, Texas
    Honestly I prefer the step over the bumper insert. When getting out of the truck it’s nice to step down onto something closer to the ground.
  24. Dec 17, 2022 at 5:50 PM
    jamieshaw06
    jamieshaw06 New Member
    Jamie
    South Louisiana
    2023 Toyota Tundra SR5 TRD Sports Premium Lunar Rock
    Installed mine today and love it. Makes it a lot easier getting in the bed.
  25. Dec 17, 2022 at 6:20 PM
    earlwright239
    earlwright239 New Member
    2022 Army Green Tundra SR5 TRD Sport
    New Ford Superdutys have corner bumper steps and one on the side. Not sure if option or standard. Saw the review on TFL
  26. Dec 18, 2022 at 7:43 AM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    That may be true. But having worked with patents for many years, all I can say is "there is another way". Toyota should have found it without resorting to this stupid add on step.
    My neighbor has it on their 2021 Tundra and forgot to retract it while backing down the driveway and almost tore it off because it hangs so low. That's the major reason holding me back from getting it on our 2023.
    Jongie123 and RickyBobbysTundra like this.
  27. Dec 18, 2022 at 11:02 AM
    lrtexasman
    Larry
    Rockwall, Texas
    People do dumb stuff all the time. Wouldn’t let that stop you from getting one. I heard so much complaining about the step I was certain I didn’t want one. Truck had it as a mandatory add on and I love it. It works so much better than an insert as you can step out of the bed looking forward. If loading a dirt bike or something tall/heavy it’s actually a lot safer and better to have a full step.
  28. Dec 18, 2022 at 1:33 PM
    Paul Moll
    Paul
    Idaho
  29. Dec 18, 2022 at 2:25 PM
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    Serra Toyota has it for $250 pretty much always and I got it for even less during Black Friday. Free shipping too!
  30. Dec 19, 2022 at 7:33 AM
    DexterL
    DexterL New Member
    someone else on here has a much lower profile ladder like that that mounts along the length of the tailgate and flips open- looks good and easy to use
