OEM Bed Mat - Anyone using it?
Discussion in '2.5 Gen Tundras (2014-2021)' started by LastCanadianExit, May 22, 2017.
  1. May 22, 2017 at 8:21 AM
    LastCanadianExit
    LastCanadianExit [OP] The dude abides...
    Bucks County, PA
    2018 Platinum
    ReadyLift 8" Lift Fuel Trophy Wheels Yokohama 37s
    Anyone using the Toyota bed mat? I am getting my Tundra with a spray in liner but was thinking of adding the mat for protection. Seeing it runs for like $86 it seems lik a safe bet.
    r4z0r51o likes this.
  2. May 22, 2017 at 8:29 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    I've got a spray in liner and still use a bed mat as added protection. Figure it doesn't hurt to do so, especially while I'm dragging something across the bed. I highly recommend having one!
    14burrito and Y0TA PR0 like this.
  3. May 22, 2017 at 8:33 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I have line x and use my old bed mat from my Taco if I need to keep stuff from sliding around. For the most part, line x has taken a beating and not had the need to add extra protection.
    HUTCHJ, JC303, Law323 and 1 other person like this.
  4. May 22, 2017 at 8:42 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I need to get one probably... Every time I accelerate, the bricks and sheet metal slam/slide around in the bed.
  5. May 22, 2017 at 8:45 AM
    r4z0r51o
    Dave
    Ouch, I don't like the sound of that.
  6. May 22, 2017 at 8:48 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yea, I like my bed mat, it's a little easier on my old knees and helps keep things from sliding around.
  7. May 22, 2017 at 8:58 AM
    pbcolt
    pbcolt New Member
    San Diego
    2022 SR5 TRD-OR CMSB Lunar Rock
    Linex + bed mat user here. Like the combo of the linex protection all around but the mat to help things not slip. Also not certain but it seems like line-x could scratch stuff that's put in the bed, it is pretty abrasive material. Bed mat prevents that.
    Tundraplatinum likes this.
  8. May 22, 2017 at 9:11 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I have a bed mat as well, it's not OEM but functions just the same. I bought it used from a friend and figured I would give it a try. I love it. Even if I had Line-X, I would still go with one. It keeps stuff in place and protects the bed and your cargo. Win win.
  9. May 22, 2017 at 9:35 AM
    15whtrd
    15whtrd Mr. Blonde
    Yep I have linex and the tundra bed mat. It keeps stuff from sliding around, easier on the knees and a little more protection for the bed. At 86 bucks I felt like I couldn't go wrong. Plus it says Tundra on it LOL
    LastCanadianExit[OP] likes this.
  10. May 22, 2017 at 9:44 AM
    millerstone
    millerstone New Member
    2017 TRD Pro DC Cement
    I have one and the spray in factory liner. I feel like the liner may scratch whatever I have in the bed so I like the bed mat as added protection. Plus it keeps things from slipping around. Can't go wrong with it.
    15whtrd and MotoTundra like this.
  11. May 22, 2017 at 9:48 AM
    TheBeast The Beach
    same here: line x + bed mat.
    MotoTundra likes this.
  12. May 22, 2017 at 9:55 AM
    kenomouth64
    Tetrus
    I guess I need to get with the game... I guess I am going to at least buy a mat.
    MotoTundra and TheBeast like this.
  13. May 22, 2017 at 11:01 AM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Thanks all!
  14. May 22, 2017 at 11:43 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Good info. I'll have to get one.
  15. May 22, 2017 at 12:06 PM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I have the spray in liner, and factory rubber mat they work as a great team
  16. May 22, 2017 at 12:20 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    No spray in just the OEM bed mat. Helps keep things from sliding around and when you get it really really muddy, spill something nasty, etc. just drag it out and hose it down.
  17. May 22, 2017 at 12:46 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Mine is lined and I still have the bed mat as not to destroy the lining. I negotiated my bed mat free, due to an issue with my brakes.
  18. May 22, 2017 at 1:40 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I have the factory spray in liner in mine and I went with a Westin bed mat I purchased through Amazon. It was cheaper then what I could get an OEM for and looks good and has been durable so far.
  19. May 22, 2017 at 1:49 PM
    ubserved
    ubserved New Member
    Michael
    2017 Toytota Tundra Platinum Crewmax
    Grillguard, front LED light bar, Leer Tonneau cover, rear LED bars
    I went with a full bedrug setup. Granted I have a tonneau cover so that's what made the most sense for me.
  20. May 22, 2017 at 3:21 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    For you guys with the OEM bed mat are you just getting them from your local Toyota dealer? I want one.
  21. May 22, 2017 at 3:46 PM
    15whtrd
    15whtrd Mr. Blonde
  22. May 22, 2017 at 6:53 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
  23. May 22, 2017 at 6:55 PM
    996scott
    996scott New Member
    Scott
    Salt Lake City, Utah
    i have been wanting to get one but the cheapest i can find is $120 from my local dealer. They are $86 from Roman but $61 in shipping.
  24. May 22, 2017 at 6:56 PM
    15whtrd
    15whtrd Mr. Blonde
  25. May 22, 2017 at 6:57 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    They can be had for 86$ if you search online but then shipping gets you and your back up to or greater then the local dealer pricing, that's what led me to purchase the Westin mat I posted above.
  26. May 22, 2017 at 7:02 PM
    996scott
    996scott New Member
    Scott
  27. May 22, 2017 at 7:29 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That's the one I ordered and it fit great in my shortbed. 20170404_214820.jpg
  28. May 22, 2017 at 8:22 PM
    Tacogrande
    Jeremy
    15whtrd[QUOTED] likes this.
  29. May 23, 2017 at 7:38 AM
    996scott
    996scott New Member
    Scott
    That's interesting, under questions a guy asked if it would fit a 6.5ft bed and someone replied yes it fit his perfectly. Isn't the short bed 5.5ft?
  30. May 23, 2017 at 5:49 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Some people consider a short bed 6ft compared 2 an 8ft. Westin only has two part # for the tundra, the one I posted above for the 6.5ft and then one for the 5.5ft bed.
    15whtrd likes this.
