OEM BACKUP CAMERA AND MIRROR DISPLAY HELP PLEASE
Discussion in 'Towing & Hauling' started by HAPPYJACKGUM, Oct 10, 2017.
  1. Oct 10, 2017 at 11:48 AM
    HAPPYJACKGUM
    HAPPYJACKGUM [OP] New Member
    HappyJackGum
    2012 Tundra Double Cab 5.7L V8 with Tow Package
    I want a mirror display for a OEM handle handle cam I am going to buy. I was going to replace the Head unit but the radio I have works great and I have an extended warrenty for 2 years on all the electronics and don't want to void that by messing with a radio replacement. I just want to put the cam in the tailgate handle and the mirror display in the cab, plug into the prewired connectors (I want to use OEM as much as I can) and be done with it. Has anyone bought this kit lately?
    https://camera-source.com/2007-2013-tundra-oem-camera-kit-includes-gentex-657-mirror-1629.html
    It seems expensive but I don't want a Amazon piece of crap.
  2. Oct 10, 2017 at 12:04 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    That seems really expensive, a couple of years ago I bought a cmos camera for a 2013 Corolla For less than $20 and the resolution was fantastic. If you have the factory radio and your truck was not equipped with the camera feature, sometimes this function have to be enabled by the dealer.. But the rearview camera does make life easier
  3. Oct 10, 2017 at 12:11 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I've also been looking at adding a backup camera along with a pop-n-lock. So far, none of the Amazon offerings will work with the lock system. That tells me there's some big differences in design, and probably quality. The price on this one is higher than the knock-offs, but I'm keeping the link for consideration. I'd rather pay a little more now and get something that will last.
  4. Oct 10, 2017 at 12:19 PM
    HAPPYJACKGUM
    HappyJackGum
    That is what I was thinking. Get something that will last. I just want a plug and play. I don't want to splice wire at the tail light and who knows how to get power to the display. OEM may be worth the extra $$$$
  5. Oct 10, 2017 at 1:05 PM
    xj2202009
    x
    Lutz, Fl
    When I replaced my head unit, the wiring kit came with a plug and play that converted the factory harness to rca for the factory cam then you can just run this to your mirror, as far as power to the mirror goes tap into the reverse light fuse, these things are very low power consumption or use a relay. Do you want the mirror to be on while you drive or just during backing up?
  6. Oct 10, 2017 at 1:09 PM
    HAPPYJACKGUM
    HappyJackGum
    I JUST NEED THE MIRROR FOR BACKING UP UP TO HOOK UP MY TRAILER. MY BACK WINDOWS ARE TINTED SO DARK I CANT EVEN USE THE MIRROR TO BACKUP ANYWAY.
  7. Oct 10, 2017 at 10:13 PM
    HAPPYJACKGUM
    HappyJackGum
    I also want but can’t find is a display that I can set on the dash and run a cable around the window and it the overhead and plug into the OEM plug the mirror plugs into. For the life of me I can’t find anywhere on the internet on how to do this.
  8. Oct 11, 2017 at 4:47 AM
    xj2202009
    x
    Lutz, Fl
    I saw your link talked about that but I don't think the tundras are wired that way since the rear view camera is design to work with the head unit..maybe higher builds might come with a electronic. Mirror..thereforefore you might have to get the conversion plug and run rca and power cable up the pillars to power the mirror.
