OEM 4 wire switch to three wire aftermarket lights
Discussion in 'Lighting' started by TomJRT, Jun 23, 2019.
  1. Jun 23, 2019 at 3:27 PM
    TomJRT
    TomJRT [OP] New Member
    Tom
    Tundra 2005 access cab 4.7
    Bull bar and extra fog lights
    TomJRTNew Member
    Today
    Tom
    Trying to use a 2001-2003 OEM fog light switch with four poles and wires for a three wire aftermarket fog light system on a 2005 Tundra. The switch fits the dash perfectly, I removed the blank for the non-existent power rear window. I get 13 volts from the blue and Red on that window pigtail.847ABD43-3A76-4D06-8A70-6FF90CA42C3B.jpg
    The wire colors on the switch (shown below) are confusing: red and yellow, white and blue, green and brown, and green- all with silver dots.
    From the lights, less confusing, I have a red (blue on pigtail) black, and white
    Any help?
  2. Jun 23, 2019 at 4:34 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    On the switch the red/yellow and green/black(brown) are what switches the lights. The other two wires should be for the switch illumination.
    So take your blue/red and wire it to the green/black then wire the red/yellow to terminal 86 on your aftermarket relay.
  3. Jun 29, 2019 at 1:59 PM
    TomJRT
    Tom
    That works!
    So, I put the red from the switch to an “ignition on” wire in the non-existent power window. Now, I need help with where to wire the black from the pigtail and the two leftovers on the switch.A599248C-1A09-451C-88AF-FEA5986236E5.jpg
  4. Jun 29, 2019 at 3:21 PM
    TomJRT
    Tom
    Here is the solution!
    Thanks for the help!FFBBA09E-0707-446D-A645-544A96A05890.jpg43653DE7-D37A-464A-9E21-6ECEF6248A0D.jpg
    Festerw likes this.
  5. Jun 29, 2019 at 3:49 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Good deal, glad you got it sorted out.
  6. Jun 29, 2019 at 4:41 PM
    TomJRT
    Tom
    Couldn’t have done it without you.
