Odd cruise control behavior, stuck in 4th gear
Discussion in '2.5 Gen Tundras (2014-2021)' started by tnine, Oct 8, 2020.
  1. Oct 8, 2020 at 3:18 PM
    tnine
    tnine [OP] New Member
    Todd
    2016 TRD Off Road
    ADS External Reservoir Shocks Deaver Leaf Springs 35" Tires C4 Fabrication Bumper Warn Winch Baja design LP9
    Hey all,
    I just did a 3,400 mile road trip from CO to PA and back. I experienced some very odd behavior with my cruise control. If it had to downshift to accelerate up a hill, it would eventually just stay stuck in 4th gear regardless of engine load. Below are some examples to reproduce this.
    Re-create the issue
    • Cruise at 75 mph in 6th gear
    • Engage cruise control
    • Drive up the first hill, it will downshift, then go back into 6th
    • Drive up the second hill, it will downshift to 4th and remain in 4th gear
    Work around the issue.
    • Enter sport mode and set to 6th gear
    • Repeat steps above. Shifting returns to 6th gear when cruising on a level surface.
    I noticed this quite a bit in Kansas and Iowa. It seems very odd, and I've never had a Toyota do this (my previous vehicle was a 4Runner). I have a 2016 SR5 Crewmax with the tow package and hence a lower gear differential. When driving without cruise, I can easily maintain 75 mph without applying much throttle. Any ideas what may be going on?
    Thanks,
    Todd
  2. Oct 8, 2020 at 3:25 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    :monocle: When driving in hilly terrain I usually kill the cruise to take advantage of gravity going downhill and momentum going uphill. I hate the "kick it in the a$$" response when a vehicle's cruise control thinks it has to get back up to speed as fast as possible. Therefore, I have probably never given my truck the chance to act like this.
    Cpl_Punishment likes this.
  3. Oct 8, 2020 at 8:35 PM
    tnine
    Todd
    2016 TRD Off Road
    Thanks @graysquirrel I run 87 octane, and I find that seems to run well. What's surprising about the elevation is after I figured out the shifter trick, I was in 6th gear going uphill slightly. From Iowa City to Denver the altitude increases from 1k to 5280 feet. I was very slowly going uphill. My truck did so in 6th gear without any issues. As soon as I put it back in D, after the next hill it would stay stuck in 4th gear. Put it in S and set the max to 6th, and it would shift back into 6th after climbing the hill.
  4. Oct 8, 2020 at 9:47 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Yup, I think it's a pretty common issue. Mine does that, I usually just do S6 and leave it there which seems to convince the trans that it actually has 6 gears instead of 3 or 4.
