OD Off Indicator on Dash?
Discussion in '1st Gen Tundras (2000-2006)' started by tvpierce, Mar 1, 2020.
  1. Mar 1, 2020 at 4:45 AM
    tvpierce
    tvpierce [OP] Formerly New Member
    Maine
    Is there supposed to be an "OD Off" indicator on the dash?
    I rember my wife's 2003 Sienna had a indicator on the dash that would illuminate when the OD Off button was pressed. That van used the same column shifter as the Tundra, and although it's been a few years, I could have sworn the switch worked the opposite of the way the Tundra works: when the switch was in the "extended" positition (for lack of a better term), it was in normal drive/OD was active. You'd push the swith "in" to de-activate OD.
  2. Mar 1, 2020 at 5:17 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    On my 2004, the O/D indicator is under the L(low) gear selection indicator even tho the face plate of the Instrument Cluster has the words Fuel Door !
  3. Mar 1, 2020 at 5:21 AM
    tvpierce
    Maine
    I just went out and looked... sure enough it's there on my 2000 as well. The bulb must be out. Thanks!
  4. Mar 1, 2020 at 5:37 AM
    Professional Hand Model
    Hand Protectors
    Fuel Door Arrow indicates which side of the vehicle accepts the fuel. Its a universally accepted practice in all vehicles.
    Black Wolf and BubbaW[QUOTED] like this.
  5. Mar 1, 2020 at 5:54 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
  6. Mar 1, 2020 at 6:13 AM
    Hand Protectors
    Overdrive off fuel door is a great option on any vehicle. :D
  7. Mar 1, 2020 at 7:06 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Almost as useful as the "shift-l" button on the 05 and 06.
  8. Mar 1, 2020 at 7:37 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Does the button actually work? As in does your truck actually kick out of OD when you press it.
    Mine currently does not, one of the wires in the shifter broke and I haven't gotten around to repairing it.
  9. Mar 1, 2020 at 9:37 AM
    tvpierce
    Maine
    Yes it works as it should.
  10. Mar 1, 2020 at 3:05 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Reminds me of last summer when my O/D light kept going on and off when I get close to button. After googling for a bit, found it was a common failure point whereby the insulation wears off wire over time, grounding wire and simulating button being pushed. Once I got things removed to check and repair, found that the previous owner had already been there o_O
    15whtrd likes this.
