OD Off 2005 AC 5SP
Discussion in '1st Gen Tundras (2000-2006)' started by Tundraip, Jul 15, 2023.
  1. Jul 15, 2023 at 8:41 PM
    Tundraip
    Tundraip [OP] New Member
    Currently I only turn it off when loaded up with camping gear and mt bikes (not towing), and it’s lugging up a steep grade. I’ve always wondered though if that is necessary and what gear it shifts to. The rpm’s jump quite a bit, so maybe 3rd, but not sure. Thoughts? Thank you
  2. Jul 16, 2023 at 6:33 AM
    2005-2006 auto should be 5AT, so I'd expect it's dropping to 4th.
  3. Jul 19, 2023 at 9:27 PM
    Tundraip
    I tested it this weekend loaded up, on steep climbs and I think it does drop to 4th. Rpm’s shot up about 500. Thanks!
  4. Jul 20, 2023 at 4:05 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While "what gear it shifts to" is a valid question, it was more important to me when I finally understood OD better. While I don't tow that often, I do use cruise pretty much regardless of speed limit, which means when approaching hills I would apply pressure to accelerator to keep rpm's at or above so the eng does not spaz out dealing with torq converter. I'm also getting better at utilizing OD off when approaching a hill, knowing a torq convertor won't stay locked with OD on.
    This is one of many posts that helped me understand better....
    bmf4069, shifty` and w666 like this.
  5. Jul 20, 2023 at 12:47 PM
    Tundraip
    Great info and thankfully that’s what I’ve been doing. As soon as it starts lugging up a grade, I’ll slow down a bit and turn off OD.
    BubbaW[QUOTED] likes this.
