Octane ?
Discussion in 'Performance and Tuning' started by Ike74, Apr 11, 2018.
Which grade do you use
  1. 85
    12 vote(s)
    8.9%
  2. 87
    94 vote(s)
    69.6%
  3. 91
    29 vote(s)
    21.5%
  1. Apr 11, 2018 at 11:43 AM
    Ike74
    Ike74 [OP] New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    Hey guys, quick question. The manual states we need 87 Octane in the truck. In every state I've been in that is the low grade, but here in CO, that is the mid grade. So two questions really, can we get away with 85? And why 85 in CO?
    I also want to mention that part of my hesitation to use mid grade fuel is based off of a fact I learned from my uncle, who sells fuel pumps for a living. He explained that mid grade is not regulated, and it is a simple mixture at the pump of high and low grades. The mixtures are very often off, so it may be closer to low grade then it is to high grade most of the time. I don't want to pay the difference if I my just be getting 86 to begin with.
    Thoughts?
  2. Apr 11, 2018 at 11:47 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I run 87 in mine, never knew about the mixture at the pump deal.
  3. Apr 11, 2018 at 11:50 AM
    Rica25
    Ricardo
    Tulare
    I run 89
  4. Apr 11, 2018 at 12:05 PM
    Ike74
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    So, I did some research and found this:
    What is 85 octane, and is it safe to use in my vehicle?
    The sale of 85 octane fuel was originally allowed in high-elevation regions—where the barometric pressure is lower—because it was cheaper and because most carbureted engines tolerated it fairly well. This is not true for modern gasoline engines. So, unless you have an older vehicle with a carbureted engine, you should use the manufacturer-recommended fuel for your vehicle, even where 85 octane fuel is available.
    https://www.fueleconomy.gov/feg/octane.shtml#85
  5. Apr 11, 2018 at 12:05 PM
    BayRunner
    2017 Tundra Platinum
    You are correct, mid grade is a mixture of high and low. It's controlled by the controller software that provides a 50/50 mixture. I'm in the biz and it's a close mix. Not enough variance to make a difference
  6. Apr 11, 2018 at 12:24 PM
    Wait until you can only run premium fuel. That can get spendy.
    jewsNbrews, 15whtrd and Black Wolf like this.
  7. Apr 11, 2018 at 12:28 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    What does 91 do to our engines?
  8. Apr 11, 2018 at 12:31 PM
    Ike74
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    when that happens I'll have another motorcycle to commute on ;-) :benchpress:
  9. Apr 11, 2018 at 12:33 PM
    Nothing just burns a hole in your wallet...... I use 87 pure dino most of the time.
    toyofan87, Sas, jewsNbrews and 2 others like this.
  10. Apr 11, 2018 at 12:37 PM
    That should be interesting from Oct-April. :thumbsup:
  11. Apr 11, 2018 at 12:39 PM
    NWHmoob
    NWHmoob New Member
    2014 Tundra SR5 DC TRD Offroad
    Nothing! Been running 92 octane for the last year. There is definitely a difference. The engine runs smoother, quieter, and quicker throttle response. Is it worth it? No, but it's hard going back to something less superior.
    jewsNbrews likes this.
  12. Apr 11, 2018 at 12:41 PM
    buckeyes1975
    Kevin
    OH-IO
    2008 Limited Double Cab
    I use 87 up to 93 just depends. Never used 85.
    jewsNbrews, Black Wolf and ColoradoTJ like this.
  13. Apr 11, 2018 at 12:43 PM
    Not needed. The 5.7L motor is 10.2:1 compression ratio. Mid grade is sufficient.
    Now like my beater with a heater is 11.8:1 compression ratio, premium is required.
  14. Apr 11, 2018 at 12:45 PM
    Ditto X100000000^^^^^^^^^^^^^
    jewsNbrews and ColoradoTJ like this.
  15. Apr 11, 2018 at 12:47 PM
    Our trucks are factory tuned to perform best with 87. There really is nothing super about premium grade gas. It all depends what your tune is.
    jewsNbrews and Ike74[OP] like this.
  16. Apr 11, 2018 at 12:56 PM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    I know around here some places carry ethanol free in 91 octane, so it is only on premium. So if you ran premium that was ethanol free you might notice it run better than regular, and get better MPG.
    jewsNbrews and Black Wolf like this.
  17. Apr 11, 2018 at 12:58 PM
    Then there is that Tow/Haul mode problem........:burnrubber:
    Kilos, ColoradoTJ and T500 like this.
  18. Apr 11, 2018 at 12:59 PM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    It’s a good problem to have
  19. Apr 11, 2018 at 1:06 PM
    Ike74
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    I drive like a grandpa because my one income cannot support a family and my lead foot :bananadead:
  20. Apr 11, 2018 at 2:31 PM
    TundraRunner481
    SB
    So. Oregon
    I don't see the "problem," lol the wife does! :thumbsup:
  21. Apr 11, 2018 at 2:52 PM
    15whtrd
    15whtrd Mr. Blonde
    I run 91 but I’m tuned. It runs real nice! To compensate I have a Costco card so I can get their Arco prices with Chevron gas LOL so I’m pretty much paying 87 prices.
  22. Apr 11, 2018 at 2:54 PM
    Ike74
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    Wait, if you have a costco card you can get a discount at Chevron? Never heard of that, I need to check this out
  23. Apr 11, 2018 at 3:02 PM
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    Here in FL the three octanes are 87, 89, and 93. I run 87 in the Tundra because that's what the manual specifies. However, I run 89 in the Mercury I have because it sits for long periods of time and I've read gas loses some of its octane if it sits over time. Plus I've also heard that the Ford 4.6 develops a knock eventually if 87 octane is run through the life of the engine. Apparently the 89 helps with that.
    Any reason I should be using the 89 on the Tundra? Is it better for performance or throttle response? Does it burn cleaner? Just figured I'd go by the manual but now you've got me wondering.
  24. Apr 11, 2018 at 4:23 PM
    Nick T
    Nick T New Member
    Nick
    85 is fine in Colorado and wherever they sell it, parts of Utah etc. They sell 85 where the elevation is higher, less dense air, less likelyhood of detonation. Just don't fill your 38 gallon tank and drive to Phoenix and then promptly beat it to hell in lower elevation heat, your ecu will pull timing and you won't be happy with the performance. Unless you are towing or want every last once of hp run the least expensive fuel.
    A Land Cruiser is tested on 87 and makes 381hp, a LX570 is tested on premium and is rated at 383hp, so you will gain 2hp running premium fuel
    15whtrd likes this.
  25. Apr 11, 2018 at 6:40 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, one tank of highest octane one lowest. Mid grade, 91 or 89 around here, mixed as you pump.
  26. Apr 11, 2018 at 6:40 PM
    Bl@ckBea$t
    Bl@ckBea$t New Member
    12 Blk Dbl cab
    Dual 12x6 BaMuffler's, Rear-cat Delete, TRD Sway Bar
    If y'all don't know, running 87 on a stock motor actually pulls 10-13 degrees of timing, 6-8 on 89, and 0-2 degrees on 93. Food for thought. This is on stock tuning. The data logs are on Facebook from DAP tuning. The 4.6 and 5.7 hate 87, run the best on 93. Don't believe me, go do your on research Facebook with the guy who actually data logs the knock sensors. 91 or 93 is the best on these trucks under load. Anyone who disagrees with me, well you can; but you're wrong.
  27. Apr 11, 2018 at 6:48 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I did try a tank of 93 on my Taco pulling 5000lb boat from LaFayette to Dallas. Same conditions. 70-75 mph on IH and light winds. Measured MPGs were +1 on about 15 gallons of gas. So higher octane may provide better MPGs under heavy load. Tried same in Tundra over shorter trip but strong headwind killed the experiment. Got my worst MPGs ever towing boat in to a 25 mph head wind. Pic is rig in Alexandria.
  28. Apr 11, 2018 at 6:53 PM
    Yep. That’s why we run mid grade in our Subaru, Jeep and premium in the Lexus.
  29. Apr 11, 2018 at 6:56 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    I use 91, with DAP tune
    ryanwgregg and Ace402 like this.
  30. Apr 11, 2018 at 7:27 PM
    15whtrd
    15whtrd Mr. Blonde
    No I’m saying because Costco is top-tier and I would say it’s probably the equivalent to Chevron. At least that’s what the guy told me LOL But we get it at Arco prices. They said they keep track of what all the gas stations are selling their fuel for in the area and try to be cheaper than all of them even Arco.
    Toyota10s likes this.
