Occasional white smoke at cold start up...Help?
Discussion in '2nd Gen Tundras (2007-2013)' started by JtTundra87, Oct 4, 2021.
  1. Oct 4, 2021 at 4:42 PM
    JtTundra87
    JtTundra87 [OP] New Member
    Justin
    North Carolina
    2007 Crewmax Limited
    Ok so I have an 07 with the 5.7 in it and when I crank up my truck on the first start up of the day Ive noticed a medium sized cloud of white smoke out the exhaust which I know is most likely oil being burnt somewhere. Smells like burnt oil too. But it only happens on the days after I floor it for fun or maybe even 3/4 throttle. Its done this since I bought it 2 years ago and I didn't notice it when I test drove it or I might would've reconsidered getting it.
    I assume it could be a head gasket leaking through but I'm not positive and Im not a mechanic just a DIY guy so I could use some insight. Anyone have an ideas of what this could be? Any help is much appreciated!
    I bought this truck with the intent on keeping it for a couple decades so I want it to last.
  2. Oct 4, 2021 at 5:05 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    1.) oil getting low on the dip stick or coolant getting low in the reservoir
    2.) go ahead and run a combustion gasses test for the coolant and oil
    3.) check the spark plugs for oil on the end find out witch one is the worst
    4.) preform a compression test of all cylinders and leak down
    take notes and lemme know what the results are so we can go from there. :)
    2mchfun likes this.
  3. Oct 4, 2021 at 5:48 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    White smoke is usually water, dark smoke is usually oil.
  4. Oct 4, 2021 at 5:53 PM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    baraynavab likes this.
  5. Oct 4, 2021 at 6:06 PM
    timsp8
    NY
    Temps change in your area recently? Could just be condensation.
    2mchfun likes this.
  6. Oct 4, 2021 at 6:57 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I would definitely do this ASAP.
  7. Oct 5, 2021 at 5:15 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    You don't say how many miles are on the truck, how often you drive the truck or how far it's driven between starts. Two years later, and only after a "spirited" drive, not sure it's an issue I would be too concerned about.
  8. Oct 5, 2021 at 5:20 AM
