Occasional Hard to start
Discussion in '2nd Gen Tundras (2007-2013)' started by whvoth, Jul 6, 2021.
  1. Jul 6, 2021 at 5:39 PM
    whvoth
    whvoth [OP] New Member
    Wesley
    2007 Tundra 4WD dual cab, Long Box 4.7L V8
    I have a 2007 Tundra 4.7L. Occasionally, (maybe once a month), I will go to start it after stopping to pick something up, and it will crank over and over, and not start. In fact, when this happens, if I let the ignition key back one notch, it keeps turning the starter motor. Usually, after it sits for a half hour, it will start. Any body else have this issue? What could this possibly be?
  2. Jul 6, 2021 at 5:52 PM
    15whtrd
    15whtrd Mr. Blonde
    My first thought is ignition switch, battery going bad and maybe needing to clean the throttlebody and MAF. I would probably start with the cleaning as it should only cost you a can of throttlebody and MAF cleaner. Also if the battery is older replace or at least have yours load tested. Start small and free/cheap.
  3. Jul 7, 2021 at 5:57 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You have an older truck so there could be many things that need maintenance. It seems that your battery may be going out.
    also if you have not changed spark plugs in the last 50k or so, they probably need replacement.
    15whtrd likes this.
