OBD II not communicating 2018
Discussion in '2.5 Gen Tundras (2014-2021)' started by jptshadow, May 23, 2022.
  1. May 23, 2022 at 11:20 AM
    jptshadow
    jptshadow [OP] New Member
    Hey, y'all so as I dug around, it seems like the fuse might be blown. What do y'all think?
    Also, do you know where is the fuse for OBDII port located at? Whaz the amp?
    Thanks, y'all
  2. May 23, 2022 at 2:33 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    What are you trying to connect to? You digging around tells me nothing about whats going on so its hard to think anything.
    7.5A , its in the interior fuse box under the dash on the drivers side.
    jptshadow[OP] likes this.
  3. May 23, 2022 at 2:36 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Do you have a pedal commander or similar hooked up. If so, try unplugging it at the pedal and plugging in the factory connector directly.
    jptshadow[OP] and Saltyhero13 like this.
