Obd gurus, Carista, and obd fusion…..?
Discussion in '3rd Gen Tundras (2022+)' started by Oldandfat, Feb 26, 2024.
  1. Feb 26, 2024 at 12:26 PM
    Oldandfat
    Oldandfat [OP] New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    I have the veepeak adaptor and have downloaded the Carista, and obd fusion apps.
    Carista is subscription based, whereas fusion is a purchase option.
    1. are they more or less the same? Carista has “customizations” I.e seatbelt chimes, and a few “gauges” I.e coolant temperature.
    fusion may or may not have the same, or different features BUT since I have to buy add ons I don’t know until I buy, which leads to my next question….
    2. Do I buy the “Toyota 2021”, or “Toyota 1996-2021”?
    I think it was 20 bucks for one, and 100 for the 96-21 package.
    can someone explain what the differences are, and what do I get/not get with the 20 or 100 dollar fusion add on?
  2. Feb 26, 2024 at 12:35 PM
    Hella Krusty
    Hella Krusty New Member
    Carista is a monthly pay service. Buy the year, or buy a month. Also buy the year, get a free month , make your changes then cancel it
  3. Feb 26, 2024 at 12:41 PM
    Oldandfat
    Cannuckastan
    I’m in Canada. We only get a free week with a year sub.
    what are the differences,between the 2?
  4. Feb 26, 2024 at 1:54 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    For Carista, you select 3rd Gen since you have a 2024. I don’t know about the other software.
  5. Feb 26, 2024 at 1:59 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    The $20 version gets you compatibility with only one year. The $100 version gets you compatibility with the wide range. If you only have one Toyota, just get the $20 version.
    doublethebass likes this.
  6. Feb 26, 2024 at 2:58 PM
    Oldandfat
    Cannuckastan
    I kinda figured that. As to “settings” can fusion alter settings or is it just a monitor thing?
  7. Feb 26, 2024 at 3:01 PM
    Oldandfat
    Cannuckastan
    Actually just looking at the options, there isn’t a 2022+ for Toyota. Seems like 2021 is the latest.
  8. Apr 2, 2024 at 4:26 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    I have been studying the Carista app, its capabilities, and am ready to download it. I have a current and up to date model of the OBDLink MX+. Carista says it is compatible to use the OBDLink MX+ as the adapter / dongle to interface for the customization. Anyone know of any problems to use this setup. Thanks.
    EDIT: I jumped in and subscribed to the app for 90 days, $6/mo. Connected to the OBDLink MX+ adapter with no problem. Made several desired adjustments. However, there appears some dealer Customizable Features are not available to be adjusted in Carista.
  9. Apr 2, 2024 at 10:27 AM
    CactusTundra
    CactusTundra New Member
    FU
    I have one of these as well - were you able to do the -2 degree Air Conditioning adjustment??
  10. Apr 2, 2024 at 10:51 AM
    JohnWhicker
    JohnWhicker New Member
    I did it in a 2021 but not sure about 2024 if that what you have.
    PGW85706 likes this.
  11. Apr 2, 2024 at 3:17 PM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    Yes. Connected and made the -2F adjustment with no problems.
  12. Apr 3, 2024 at 3:55 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    For the Carista app, I programmed the Seat belt warning ding (driver) to Disabled but it still dings when starting up the truck with belt unlatched. With the belt latched, it does not ding. Is this normal?
  13. Apr 3, 2024 at 4:42 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    No. Mine does not ding. Only the icon on the dash lights up. Yo may want to re-check it. Maybe you didn't save it.
    PGW85706[QUOTED] likes this.
  14. Apr 3, 2024 at 4:52 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    Thanks. I have done it twice and will give it another try.
  15. Apr 3, 2024 at 5:21 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    I wish I had a screen shot of it for you. I did mine a while ago. I think it saves it as soon as you change it. Go in and see what the setting is set at. Try this thread - it has a lot of extra ppl asking questions and stuff, but there's screen shots just so maybe you can compare what you're seeing to these.
    https://www.tundras.com/threads/carista-obd2.109929/page-8
  16. Apr 3, 2024 at 5:28 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    Thanks guys. I just gave it another go. It is disabled, saved, and still chimes when switched on. I downloaded from the app the current settings and attached is the relevant ones for the seat belt. i am starting to get a little disappointed. Maybe I will contact Carista help.
    The following settings were available specifically to your vehicle using Carista:
    Chassis & Engine:
    Active Noise Cancellation (ANC)
    *ON* / OFF
    Engine Sound Enhancement (ESE)
    ON / *OFF*
    Dings & Warnings:
    Warn when doors opened with headlights on
    *ON* / OFF
    ENABLED / *DISABLED*
    Seat belt warning ding (front passenger)
    Seat belt warning ding (rear right passenger)
    Seat belt warning ding (rear left passenger)
    Seat belt warning ding (rear center passenger)
  17. Apr 3, 2024 at 7:05 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    That's just weird. I'd wonder what the truck would do if a dealer with techstream adjusted those settings. Should make no difference how those settings get changed. It would be how the truck acts on those changes.
    ChucklesToy likes this.
  18. Apr 7, 2024 at 7:20 PM
    wildmank99
    wildmank99 New Member
    Arizona
    22 Tundra Limited
    I use my Mx+ not just on my tundra but my 07 Silverado
  19. Apr 7, 2024 at 9:08 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Just ordered one today. Eager to give it a whirl when I get home. Going to use it in other vehicles also.
  20. Jun 6, 2024 at 9:28 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    Looking at all the things Carista can do like changing settings. Can these settings changed by just using the settings menu on the truck or are these more of dealer settings that can't be changed unless using Carista.
    I use OBD Fusion for my 08 and had to program in PIDs for the trans temps, are there any PIDs for the 3rd gen?
    Anyone tried this one on the 3rd gen?
    Amazon.com: Veepeak OBDCheck BLE Bluetooth OBD II Scanner Auto Diagnostic Scan Tool for iOS & Android, Bluetooth 4.0 Car Check Engine Light Code Reader : Automotive
  21. Jun 7, 2024 at 6:45 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    I can answer part of your question...The settings affected by Carista are in addition to those in the Settings menu and yes, they are more of dealer settings which can be changed by the dealer or by using Techstream. Carista just makes it easier by walking user through each category. Using the Carista dongle, it took me all of 10 minutes to go through all of the settings and make the changes. While Carissa has a monthly usage charge, you can use it for a month free and then cancel. You can also use Carista to see status and error codes. If you want to see all of the settings and reports available, just go to Carista.com and select your vehicle.
    Some members used a Veepak ODB dongle to connect to Carista. There is a whole thread on Carista which explains it in detail.
    Someone else would have to answer the PID question. I believe there are based on comments on the forum, but I don't know details.
  22. Jun 7, 2024 at 4:41 PM
    Rockpig
    08 Limited
    Thanks Chuckles, super helpful and glad to hear the Veepak should work, only saw this thread after I ordered it. I use OBD Fusion on my 08 Tundra to monitor temps while towing. Hopefully I'll find some PIDs to do the same for the '24 as I'm retiring the 08.
    ChucklesToy[QUOTED] likes this.
  23. Jun 7, 2024 at 11:38 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Just a note - I had the Veepeak WiFi version from my Tacoma as I didnt want to interfere with the Bluetooth. It worked great in the new Tundra but WiFi interferes with Apple CarPlay. So for the hell of it I bought the cheapest Bluetooth dongle on AMZ. I think it was $12. It works perfectly too. - Don’t pay a lot for an OBD dongle !!
    ChucklesToy and Rockpig[QUOTED] like this.
