OBD Connected Performance Upgrade Products
Discussion in 'Performance and Tuning' started by Finfinder, Aug 4, 2023.
  1. Aug 4, 2023 at 1:36 PM
    Finfinder
    Finfinder [OP] New Member
    2016 Tundra 1794
    Air Lift bags, upgraded Bilstein shocks
    My 2016 1794 has 130K miles on it and I am not planning on getting rid of it. But I would like to improve my fuel economy so I would like to ask if anyone has any experience with these products they wouldn't mind sharing.
    I would greatly appreciate your response.
    Thanks
    Finfinder
  2. Aug 4, 2023 at 4:18 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Will only work in your mind for a week...your computer will relearn around it and you'll be back to normal...pedal command can help as it retards your pedal and you can augment how fast you accelerate, etc...no lift, factory-sized tires that are aired up and an easy foot will get your best numbers...if you have money to burn, long tube headers and a tune will be the most improvement you could make...
    Saltyhero13 and Finfinder[OP] like this.
  3. Aug 5, 2023 at 4:42 AM
    Finfinder
    2016 Tundra 1794
    Thank you for your reply, I appreciate it.
    HulkSmurf14 likes this.
  4. Aug 5, 2023 at 8:40 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    What device are you asking about specifically?
    I doubt there is anything on the market that impacts MPGs significantly more than driving behavior. Less likely if your truck is modded with a higher lift and larger tires than what comes stock. Even less likely if you drive in city stop and go traffic. Driving around laden also hurts MPGs
    A throttle controller might help but will net you very marginal gains if any at all. You wont get the "up to +20%" gains some claim. They can also throw your truck into limp mode.
    Without knowing your specifics I would think highway tires and driving behavior will net you the most MPG impact.
  5. Aug 5, 2023 at 11:26 AM
    Finfinder
    2016 Tundra 1794
    Thanks for your reply.
  6. Aug 5, 2023 at 12:51 PM
    Saltyhero13
    @dirtydeeds made a post about mods that benefit MPGs recently, I'll see if I can find it for you.
    Also a note about the throttle controllers some of them can trigger a limp mode. Pedal Commander specifically, its been noted in a few threads.
  7. Aug 5, 2023 at 12:56 PM
    Saltyhero13
